      11-30-2022, 12:50 PM   #45
spit
Drives: BMW F15 x35i
I may have found what I was looking for
The part number is:
61130007438
I know there are many different ways to do it, but I'd like to do it as close as possible OEM solution
helpful link below, for everyone who needs it
https://f30.bimmerpost.com/forums/sh....php?t=1575292
      11-30-2022, 08:50 PM   #46
SaNGRia
SaNGRia's Avatar
986
Drives: LCI E93 M3 + F85 X5M
Yeap. Thats the correct pin. I have E chassis fuse box from junkyard which cost me $5 I am using almost 6 years, still have plenty!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
      12-04-2022, 10:16 PM   #47
mitchbmw123
Drives: Bmw F15 3.0 N55
Hello guys
I need help because I have a problem. I installed the smart opener according to the instructions here. Unfortunately I have a problem, it does not work properly.
Everything has been coded, the rear trunk lid opens but does not close.
When the trunk lid is open and I want to close it with my foot, the lights blink but there is no reaction.
What needs to be coded for the smart closing to work as well?
I have bmw F15 from 10.2015 with NBT
      12-04-2022, 10:51 PM   #48
SaNGRia
SaNGRia's Avatar
986
Well Thats the only coding needs to be working. Since you are F15, i assume you coded 5E. If so, check your liftgate, make sure closed properly.
, F85 ACC Retrofit
      12-04-2022, 11:02 PM   #49
mitchbmw123
With the opening by kicking, no problem. It opens,but unfortunately won't close. The lights flashing, but the hatch stays open.
      12-04-2022, 11:06 PM   #50
SaNGRia
SaNGRia's Avatar
986
As i said, the liftgate bottom part might cause that. Or re check your coding. I cant think of any other solution.
, F85 ACC Retrofit
      12-04-2022, 11:14 PM   #51
mitchbmw123
Is there a possibility that the smart opener module is damaged? (installed used)
when you try to close it, you can hear the lower electric lock click. So information force close is received
      12-05-2022, 12:22 AM   #52
SaNGRia
SaNGRia's Avatar
986
in my experience, it makes clicking noise and doesnt close if liftgate is not closed all the way
, F85 ACC Retrofit
      12-05-2022, 07:55 AM   #53
Tomcat_F15_STL
Tomcat_F15_STL's Avatar
150
Drives: BMW F15
ditto.
If the bottom gate is not fully closed or the microswitch inside its lock is not functioning the upper will not go auto-down.
SaNGRia986.00
      12-05-2022, 09:27 AM   #54
smyles
Drives: '21 X5
Originally Posted by mitchbmw123 View Post
everything has been coded, the rear trunk lid opens but does not close.
When the trunk lid is open and i want to close it with my foot, the lights blink but there is no reaction.
3120 hkl_functions > func_smo = 01
      12-05-2022, 10:19 AM   #55
mitchbmw123
Bottom gate It's close for sure 100% I checked it several times
will I be able to code it via bimmercode with expert mode?
      12-05-2022, 11:45 PM   #56
mitchbmw123
Thank you !!!
now it is working !!
but the coding was wrong. I set it to the F16 model and the tail gate opens and also closes
      02-04-2023, 03:36 PM   #57
Tomcat_F15_STL
150
Drives: BMW F15
Originally Posted by Tomcat_F15_STL View Post
That F85 is sweet!
On the homefront, I did the E70, first... that one was pretty involved. The E70 never had the soccer-mom tailgate offered as a factory option.
https://www.bimmerfest.com/threads/s...#post-13097385
Then, added the option to wifey's F15. She hates it and said it is stupid. lol
Here's a parts list from the F15...
61-35-7-391-043 sensor -lower round style
61-35-7-391-045 sensor -upper round style
61-35-7-429-824 control unit $75.00 w/ above sensors
61-35-7-496-165 second control unit to replace cracked case on the other $14.00
61-13-2-359-997 connector $22.04
***61-35-7-391-042 sensor -upper flat style
***61-35-7-422-700 control unit
Controller Wiring:
.35mm Yellow/Green(pin 1), Red(pin 2), and Brown(pin 3)
Pin 1 to LIN Bus for LF mirror and driver's door switch block.
-Soldered into blue/yellow behind LF kickpanel wire leading to pin 42 on connector 258*4B on BDC
Optional LIN Connection: Instead of connecting to the LIN Bus on pin 42 of the BDC, I ran a wire along the left side of the vehicle and up into the drivers door where I connected it to the wire leading to pin 4 of the switch block.
Attachment 3027964
add-a-fuse and used 150 instead
Controller Pin1 - LIN wire on PIN 42 on connector 258*4B into BDC located in Passenger Footwell
Controller Pin2 - +12VDC from Fuse F150 behind tailgate fuse block
Controller Pin3 - GND to ground bus filled with brown wires located next to tailgate fuse block
Coding in BDC_Body Module:
CAH_SMART_OPENER_COD_FAHRZEUGTYP = 5e
VAM_SMART_OPENER = activ_HK
VAM_ENABLE_SMART_CLOSE = activ
Attachment 3027957
Attachment 3027958
Attachment 3027959
Attachment 3027960
Attachment 3027961
btw, I don't think it's stupid.
A bit of an update with my Smart Opener mod.
It worked on the F15, but not perfectly. I suspected it was mostly due to mismatched parts. So, I ordered a complete set including the bumper bracket...
I was correct. It works perfectly, now.
The lesson is, just buy these exact parts - or, much easier, buy a complete assembly off FleaBay! I chose one from an F30.
      11-21-2023, 09:34 PM   #58
garrypeterson
Drives: E60 M5
Just did this with (eBay) parts from a 2018 G12 760Li, including top sensor that is flat. I was initially disappointed since IDrive shows "open by foot"/"close by foot" options that can't be selected yet it works fine. Thoughts?
      11-22-2023, 08:46 AM   #59
SaNGRia
SaNGRia's Avatar
986
Simple answer is the BDC you have does not have option to activate the SMO on iDrive!
, F85 ACC Retrofit
      01-21-2024, 02:25 AM   #60
callmeorsan
Drives: bmw 335 range rover evoque
About to do this on my f15. I purchased all the parts you mentioned but I bought a newer smo module. Do you think it would work? P no
61357932682
      02-09-2024, 04:24 PM   #61
callmeorsan
Yeah seems very difficult to follow unfortunately. Have all these parts but no idea where to start
