      02-07-2024, 05:22 AM   #1
X5Brian
X5Brian's Avatar
873
Drives: 2017 BMW X5
Radiator support "plugs" name needed !
Can anyone pls tell me what these missing “plugs”
Are called to close off radiator cover. Pls !
      02-07-2024, 08:38 AM   #2
Qsilver7
Qsilver7's Avatar
I'm lost...I'm not seeing any missing "plugs". Are you talking about the oval air duct identified by the arrows in your amended pic below?
If you are, again, those are air ducts that are designed into the trim piece (see #13 in diagram below). They are not "plugs" that should be filled with anything...if you closed them off...you restrict air to the engine bay.
      02-07-2024, 03:13 PM   #3
CatalinP
Drives: BMW X5 F15 2014 3.0xd
The intake duct for 35d "plugs in" there...
      02-07-2024, 07:43 PM   #4
_ObiJon
_ObiJon's Avatar
Drives: 2015 428i xDrive
I looked too but it appears it's not illustrated. On my 35i, the passenger side cutout is filled with a blank.
eBay item
      02-08-2024, 01:26 AM   #5
mrrsharma@yahoo.com
Drives: BMW X5 35D F15
You should have an air duct hooked up there. Pictures of your full engine?
https://www.realoem.com/bmw/enUS/sho...diagId=13_1261
_ObiJon200.00
      02-08-2024, 10:57 AM   #6
Qsilver7
Qsilver7's Avatar
Great find. I guess we should have asked WHAT ENGINE first...since the OP didn't say...and doesn't have a signature or any other vehicle info.
That part (#7 in the diagram) is only used on the N55 engine based on the part database site.
      02-09-2024, 05:25 AM   #7
X5Brian
X5Brian's Avatar
873
Drives: 2017 BMW X5
I found them, no worries. Btw I don’t have stock air duct/intake as It won’t feed a stage 3 turbo…. I built a custom 4” intake … so I don’t use those holes. Found two plugs on eBay… ofcourse I couldn’t find the one I took out from stock.
