      07-07-2017, 04:25 PM   #111
The only option that isn't working for me is the blinker from 3 to 5. Is anyone else having this issue? Recommendations?
      07-07-2017, 04:35 PM   #112
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Use expert mode as software might use old coding that does not work on newer firmware. See F15 Cheat Sheet in OP of Coding Thread.
Violator4587.50
      07-07-2017, 05:30 PM   #113
jonboyglx
Drives: 2017 BMW X5 40e
I enabled iDrive6-Lite and it works fine except the image of the car under My Vehicle shows a 5 series. How do we change that to be an X5?
      07-07-2017, 05:44 PM   #114
Almaretto
Almaretto's Avatar
2374
Only way is to update vehicle firmware through flash programming.
View post on imgur.com
      07-07-2017, 05:56 PM   #115
jonboyglx
That sucks
      07-07-2017, 09:00 PM   #116
m34door
m34door's Avatar
27
Drives: 2017 x5 35i, 2021 x5 msport, 2
My tailgate does not close via remote fob. Any ideas as to make it work via bimmercode?
      07-07-2017, 09:47 PM   #117
1coolF15D2017
Drives: 2020 X5 G05
Did you happen to set it with "no delay"?.
      07-07-2017, 10:39 PM   #118
Dirty Cash
USAF Retired
Dirty Cash's Avatar
Drives: F15.50i
Originally Posted by Kr0m3assass1n View Post
Sorry there are multiple options recommended in this thread. Which one worked for you? I'm not against either Mac/ Windows but mobile surely sounds way easier. Thanks!
Not sure if this is the answer you're looking for, but I went the mobile route with Bimmercode App (Bimmerlink App for clearing errors) and the Vgate OBD II reader.
      07-08-2017, 12:35 AM   #119
Marky Mark
Drives: 2014 xDrive35i
Hey everyone,
If you are using the BimmerCode App, you need to also use the free BimmerLink app and clear out all the errors.
This way you don't need your car to go to "sleep" and all of your options that you want to configure WILL all work... Remember that you have to clear the errors from both the 1) Error Memory & 2) Info Memory
It would be a good idea to go to clear errors in these two areas twice...
2014 X5 xDrive35i:
MPPK+MPE, Premium Package, xLine, Driver Assistance Plus, Driver Assistance Package, Lighting Package, Luxury Seating Package, Cold Weather Package, Night Vision w/Pedestrian Detection, ACC Stop& Go + Active Driving Assistant, harmon/kardon Surround Sound System, Space-Saver Spare, 4-Zone Automatic Climate Control, Poplar Wood Trim, towing package
      07-08-2017, 12:39 AM   #120
d_v_o_1
I really don't think bimmerlink is free, at least it wasn't for me?
      07-08-2017, 12:43 AM   #121
Marky Mark
BimmerCode you must pay for (to unlock and actually use), BimmerLink is free, or at least it was free.
2014 X5 xDrive35i:
      07-08-2017, 12:55 AM   #122
It cost me an additional $27.
      07-08-2017, 03:56 AM   #123
Kr0m3assass1n
kr0m3assass1n
Kr0m3assass1n's Avatar
Drives: 22 X7 M50i
Yeah I downloaded both apps last night and had to pay for both. BimmerLink was paid before download itself and BimmerCode was an in app purchase using the little gear/ settings icon on the bottom right of the apps home screen.
Still, paying ~$50 for both apps along with ~$25 for the OBD connector doesn't seem too bad considering all the things it'll allow me to do on both my F10 and F15.
Now, I'll be pissed if neither codes correctly lol. My dock should be here today so I'll report my results back later this evening hopefully.
      07-08-2017, 03:59 AM   #124
Kr0m3assass1n
kr0m3assass1n
Drives: 22 X7 M50i
That was exactly it mate, thank you. I folllowed that same process. I just ended up getting an icar2 adapter instead of the icar3. What about you?
Seems like the reviews for the 2 are better on Amazon dot com.
      07-08-2017, 08:04 AM   #125
m34door
m34door's Avatar
27
Yes did no delay
      07-08-2017, 08:54 AM   #126
Dirty Cash
USAF Retired
Dirty Cash's Avatar
Drives: F15.50i
You're welcome!
I went with the icar2 as well for the same reason that you did. The reviews I read were better, and they had the reader in Black/Green (I've been a Green Lantern fan for decades!)
Now the one thing I wish it could do, and maybe I just haven't seen the option within the App, but the ability to "batch code" would be nice. I made the mistake of selecting each item I wanted to code, then selected code only to find out it only coded one of the selections. This led me to believe that coding in bulk (batch) isn't possible with the App??? I haven't contacted the Dev since it's not a big deal for me.
Anyone know if batch coding is possible when using a computer?
      07-08-2017, 09:28 AM   #127
I initially ordered the iCar2, it was defective so I returned it and ordered the iCar3 and it worked great. I'm sure they both have defects, it's a crap shoot with these devices.
      07-08-2017, 09:30 AM   #128
You're welcome!
Now the one thing I wish it could do, and maybe I just haven't sent the option within the App, but the ability to "batch code" would be nice. I made the mistake of selecting each item I wanted to code, then selected code only to find out it only coded one of the selections. This led me to believe that coding in bulk (batch) isn't possible with the App??? I haven't contacted the Dev since it's not a big deal for me.
I was able to select many options within one module, then select code and it worked. The only option I can't get to work is the blinker to 5 from 3. I'm going to try the expert mode as advised in the post above.
      07-08-2017, 12:39 PM   #129
Dirty Cash
USAF Retired
Dirty Cash's Avatar
Drives: F15.50i
Ok, that makes perfect sense.
I was in and out of different modules trying to do the same thing.
      07-08-2017, 12:58 PM   #130
zinengineer
zinengineer's Avatar
207
Drives: 2016 Space Gray X5 M Sport
I had sent the developer a series of questions prior to jumping in. Coding one module at a time was one answer. I've done multiple items at once, but all in the same module.
I'm using my F10 as "test" runs. Plan to work on theX5 next. While not afraid of plugging my computer into the car, I just wasn't willing to deal with the "windows in Mac world". Best $75 spent ever
2016 X5 35i Xdrive M Sport; Space Gray Metallic/Mocha Dakota
2014 535i Xdrive luxury line; Black Sapphire Metallic/Black Dakota
      07-08-2017, 01:30 PM   #131
1coolF15D2017
Drives: 2020 X5 G05
Yes did no delay
I suggest to contact the developer. Tell him what the issue is and include your logs. Go to contacts and select contact support and it will include your logs once you send him your email. It is under "settings" lower right of BimmerCode App.
      07-08-2017, 01:36 PM   #132
1coolF15D2017
Drives: 2020 X5 G05
I've tried it on expert mode and change the value to a custom (maximum is 03 cannot go 04) of "PIA_DEFAULT_TIPPBLINKEN"-> "Tippblinken_fuenfmal (0x02). And I still get 3 blinks. Developer said that the value of 02 is correct and with newer iSteps it works for some and not for others. So I fall also on the others since it does not work for me. Oh well.
