      07-10-2017, 09:05 AM   #155
jonboyglx
Drives: 2017 BMW X5 40e
Originally Posted by eggyacid View Post
Anyone know the coding in bimmercode for the following
- activate front camera when driving
- activate rear camera when driving
I know I can change the shut off distance and speed which I like. However, is there a way to quickly activate the camera while driving?
This is the next thing I am trying to do. The developer said that this is coming soon. Not sure if we can use the cheat sheets from the other coding thread and try to do this in expert mode.
      07-10-2017, 08:00 PM   #156
eggyacid
eggyacid's Avatar
Drives: BMW X5 F15
Yes thank you for reaching out to the developer. He is great at responding and there are many features I would love to see in the future
If you figure out how to perform it using expert mode, please let everyone know
Jeff
Current Ride
- 2016 Toyota RAV4 Hybrid
- 2014 X5 xDrive35 M
- 2013 ML-350 (Gone)
- 2012 Audi Q7 TDI (Gone)
      07-12-2017, 11:14 AM   #157
ramsal
Drives: 2017 X5 & 2018 M3
Has anyone tried other WiFi OBD adapters with the app? Would the VEEPEAK work?
      07-12-2017, 11:25 AM   #158
d_v_o_1
I don't believe so. Has to be Vgate version 2 or 3
      07-12-2017, 12:10 PM   #159
sigx5
Drives: X6
I have Vgate version 3... should I use version 2?
      07-12-2017, 12:39 PM   #160
d_v_o_1
I have read that it will work
      07-12-2017, 01:11 PM   #161
I purchased the 2, it didn't work, returned it for the 3 and it worked great. I've read on this thread that the two works as well, mine didn't. More than likely I received a defective unit.
Cheers!
      07-12-2017, 01:14 PM   #162
eggyacid
eggyacid's Avatar
Drives: BMW X5 F15
I use vgate3 and it works great, make sure slow communication is turn ON
Jeff
Current Ride
      07-12-2017, 03:04 PM   #163
Kr0m3assass1n
kr0m3assass1n
Kr0m3assass1n's Avatar
Drives: 22 X7 M50i
Cheers!
Yep I got a 2 and it worked like a charm. I read some of the reviews on the 3 on Amaz*n and a lot of people seemed to have connectivity issues with the 3 so I chose the other one.
Try one option at a time once or twice in the beginning so you know everything works great before doing a large set of changes. Some of the menus are heavily populated and require patience.
      07-12-2017, 05:17 PM   #164
sigx5
Drives: X6
does any one know if I can code Auto High Beam "ON" as default?
      07-12-2017, 05:21 PM   #165
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Negative. It can only be coded on vehicles with FRM (eg, F010 or F25).
      07-12-2017, 05:47 PM   #166
sigx5
Drives: X6
thank you for sharing... just don't get it why we have to manual turn it on every time ...
      07-12-2017, 06:17 PM   #167
Almaretto
Almaretto's Avatar
2374
Only BMW knows why.
      07-13-2017, 06:22 AM   #168
Kr0m3assass1n
kr0m3assass1n
Drives: 22 X7 M50i
Did they ever add the option to turn the corona rings on when you unlock the car during daytime? I have it on my F10 and love it. On my F15, they won't turn on unless the light sensor detects its dark out.
There's also this really cool feature on my F10 where the full LED headlights turn on when I short press the alarm (red) button on the fob. Works whether it's day or night too. Very handy when you need an ultra bright flashlight in your driveway or parking garage.
      07-16-2017, 09:43 PM   #169
zinengineer
zinengineer's Avatar
207
Drives: 2016 Space Gray X5 M Sport
Coded wife's X5, practiced all this on my F10. 30 min total time
Disabled all disclaimers
M splash screen
Phone ringtone thru car
Tire pressure AND temperature (I don't understand why this isn't standard)
HUD turn signals
Didn't do the digital speed in BC button (redundant with HUD)
X5 logo in console on start up (yea, pretentious)
Open/Close mirrors on comfort close or key fob close
Unlock doors on engine off
Turn off radio/GPS when opening door
DRL. Tail lights (where we live, we need all the visibility we can get!!)
Door handles LED's in reverse
Auto start/stop default off
Change number of blinks on lane change to 5
Best $75 ever spent - $25 adapter, $25 Bimmercode app, $25 Bimmerlink app. Cleared all errors when I was done.
2016 X5 35i Xdrive M Sport; Space Gray Metallic/Mocha Dakota
2014 535i Xdrive luxury line; Black Sapphire Metallic/Black Dakota
      07-17-2017, 10:23 AM   #170
jonboyglx
M splash screen
HUD turn signals
Please explain how you did the X5 logo in console and the change turn signals to 5.
Thanks!
      07-17-2017, 11:09 AM   #171
fromkrypton
Drives: 2015 X5 35d
2015 BMW X5 35d  [0.00]
Does bimmercode support enabling Enhanced Bluetooth?
      07-17-2017, 02:24 PM   #172
SCA
SCA's Avatar
Drives: Multiple BMWs
Originally Posted by jonboyglx View Post
Please explain how you did the X5 logo in console.
Thanks!
+1
What exactly is it? Specifics please.
      07-17-2017, 03:00 PM   #173
zinengineer
207
Originally Posted by SCA View Post
+1
I'll work on an answer later tonight after I get home
      07-17-2017, 03:47 PM   #174
d_v_o_1
+1
If I remember correctly, it is under the splash screen section and it gives you an option of about 5 different ones. They have the BMW screen, X5 screen, M screen and I thought one or 2 more (maybe i series screen) It will not give you a preview, so google search what each one is before you code one and exit the program. It is still under the easy code section of the head unit. Just a heads up for anyone who hasn't been into the app in a month or so, it has received one update in that time. That may explain why some previous weren't able to do this. Hope that helps a bit
      07-17-2017, 10:00 PM   #175
zinengineer
207
Thanks!
1. Logo in console is shows as X5///M50d; shows in the instrument cluster. I'll probably ditch it since I don't actually have a 50d. It is found in the KOMBI (instrument cluster) module - there are several choices
2. changing number of blinks is more straightforward, since it looks like a common change and the developer has accounted for it. It can be found in the BDC module and will show in the menu. I've done some screen shots.
I really don't want to steal the thunder of the group of coders that post detailed guides elsewhere in the various forums. They clearly have plowed ground for those of us "users" to follow. The combination of the various cheat sheets I've found, coupled with the app has given me the confidence to take this on. I now understand the layout and structure of the modules and codes, and it all makes much more sense. Granted, there are still some limitations with the app vs. using ESYS, but this gets me 95% of what I'm looking for. As I indicated earlier, I really wasn't too keen on the "windows in Apple environment" process, so this is a good compromise.
      07-18-2017, 09:42 AM   #176
artem123
artem123's Avatar
250
Drives: G30
Everything else is working for me, but 5 blinks. My car just refuses to take it.
