      05-24-2018, 01:29 AM   #23
CatalinP
Drives: BMW X5 F15 2014 3.0xd
That’s why it needs calibration using Ista D.
      09-16-2018, 09:54 PM   #24
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Originally Posted by Sedoy View Post
Got it working... After all I think Mr.47 was right... The system is "stupid" and only one the passenger's side level sensor engages the pump to inflate. So I manually adjusted passenger's sensor to the highest setting forcing it to deflate this side completely. Once it got low and in level with the drivers side I attached the sensor back to its original position, pump engaged and inflated BOTH sides equally to the normal level. So it looks like driver's side sensor just controls the valve for this side and the passenger's sensor controls both the valve and the pump. I'm not sure if it's designed like that and if my system operates correctly but I'm pretty sure both sensor are functional. Also both sensors are identical, same part number.
I wish somebody with air suspension could repeat my test to verify that driver's side sensor doesn't engage the pump...
Originally Posted by Mr.47 View Post
If I recall the rear air suspension is a dumb/non-adaptive suspension, all it does is just keep it straight ie level and maintain a specific pressure in the air suspension bellow, even if you have DHP, (which DHP uses a rear sway bar that has electric counter-torsion motor to mitigate body roll).
All 4 wheels has level sensor for (even the front axles), reasons why it only works on passenger side is probally uses one sensor to detect level. The air suspension its just for level purpose and nothing else (not for comfort or performance gains)
I may need to try this as I've lost all air just in my driver side as well when I had the car jacked at the front for two days.
Just to confirm I'm assuming you simply unbolted the bottom bolt of the sensor arm and pulled the arm all the way down to make the car think it was too high and held it there till it totally deflated and then simply reattached the bolt and they both reinflated?
Was the car running? Did you have the wheel on or off? I'm a bigger guy so I don't have a ton of room under there as it is. I won't be able to fit if the back end is fully deflated lol.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      09-16-2018, 11:46 PM   #25
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Ok ill shut up now. Got it all leveled in the rear. Was not easy or fun but same issue OP had. Although I did get the driver side to activate the pump. Basically Just had to keep moving both sensor Arms into several different positions. I was never able to get them to deflate but was able to get the pump to fill the driver side. Now the rears are at 31.5" and the fronts are 30.25 and 30.75.
'06 C55 AMG (sold)
      09-20-2018, 05:02 PM   #26
Reckamech
Master of Disaster
Reckamech's Avatar
Drives: 2014 X5 Sport
Cost
What would a typical job like this cost to replace both air bags for the x5?
      09-20-2018, 07:46 PM   #27
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Dealer will want a couple grand probably. DIY under $500
'06 C55 AMG (sold)
      09-24-2018, 08:11 PM   #28
Reckamech
Master of Disaster
Reckamech's Avatar
Anyone ever consider replacing the air bags with springs?
      09-24-2018, 10:09 PM   #29
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Never seen anyone have anything that's compatible.
'06 C55 AMG (sold)
      12-12-2018, 10:27 PM   #30
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
So still having inconsistent issues with my driver side height. I'll come out and it's deflated one day. Then won't do it for a couple days. Then I park for work and come out and I'm riding dirty in the driver side again. Start up it fills and I drive away. Get home park over night wake up and all good still.
This leads me to believe it's not the bag since it's very inconsistent from day to day. It's almost like the car just lets the air out once parked when it feels like it.
Very frustrating. Starting to think it's a bad sensor but I was able to manipulate the arm manually after work as it wouldn't re inflate on its own. I was able to pop off the arm and manipulate it to activate the pump and then my right side was all kinds of lifted now and I was still leaning just not slammed on one side. So then I had to go to right side and deflate some air.
Idk anymore. Any thoughts would be helpful and welcome.
'06 C55 AMG (sold)
      12-17-2018, 12:31 PM   #31
backtrack2015
Drives: 45e (soon)
The driver's side of my wife's X5 (64k miles) was sinking whenever the car was parked on a significant slope (side-to-side) for the last couple of months. On flat ground the air spring stayed inflated. I assume the deflection caused by the side-to-side slope simply forced the leaking section of the spring to be "opened."
-- As an aside, in hindsight the first occurrence was provoked by lifting the front-passenger side to remove the wheel and extract a rock from the brake. --
I finally replaced the driver's-side air spring with the one from Arnott this past weekend. It was a very simple job and I'm an absolute novice. So far so good.
      12-14-2019, 12:13 PM   #32
///msaleem
Drives: X5.0
Can someone link the part numbers for the right rear and left? or link to a website they bought theirs from?
      12-14-2019, 12:24 PM   #33
RED_Y_
Drives: 2014 X5 3.5d
Based on info here
https://f15.bimmerpost.com/forums/sh....php?t=1511949
and here
https://f15.bimmerpost.com/forums/sh....php?t=1641660
P/N is Arnott A-2642 and people got them from amazon, rockauto and other retailers.
      12-15-2019, 12:28 PM   #34
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
I thought this was interesting read about the suspension and how it operates.
http://www.micro-tronik.com/learning...ng-suspension/
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
      12-16-2019, 11:27 AM   #35
x6spacegrey
Drives: BMW X6
2016 BMW X6  [0.00]
Dealer just replaced my Driver's side air strut under warranty, and it took under 1 hour (M adaptive suspension).
Interesting to see so many people having similar issues - and it's kind of making me nervous as my warranty is going to run out soon.
      12-16-2019, 12:16 PM   #36
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
I would have got them to replace both while they were at it. You usually replace these in pairs.
      12-16-2019, 04:08 PM   #37
x6spacegrey
Drives: BMW X6
2016 BMW X6  [0.00]
I tried - but unfortunately they will only replace the broken one.
      12-16-2019, 09:36 PM   #38
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
I imagine it's only a matter of time before it needs to be done. How long do you have left on warranty?
      12-17-2019, 09:55 AM   #39
x6spacegrey
Drives: BMW X6
2016 BMW X6  [0.00]
Well, I still have 3 months, but I bought my car "Pre-owned" so its supposed to have an additional year of Powertrain coverage on Engine, Transmission and Suspension after the 3 months.
Hopefully this counts under Suspension!
      12-18-2019, 12:17 AM   #40
speedracerM4
speedracerM4's Avatar
57
Drives: 2015 M4
Has anyone replaced the desiccant balls in the compressor?
https://youtu.be/dUDDH3mtjr8
      12-18-2019, 12:35 PM   #41
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
I posted a video about this before. Not sure anyone( besides the guy in the video) has done it or the success of it.
      01-15-2020, 02:24 PM   #42
rok2774
Drives: X5
Bumping thread - I'm having same issue. Anyone know if CPO warranty will cover suspension airbag replacement?
      01-20-2020, 10:55 AM   #43
x6spacegrey
Drives: BMW X6
2016 BMW X6  [0.00]
yeah, I believe it does.
You were right - my right rear airbag just gave out. Not even a month after they replaced the reft rear one.
Immediately made an appointment to get it replaced. Hopefully these new airbags hold for a few years.
      01-20-2020, 12:25 PM   #44
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Sorry to hear that it went out. I knew it would though.
Also, it's ridiculous that they don't replace both at the same time since they are supposed to be replaced in pairs.
