      02-20-2015, 10:35 PM   #199
pdawg
Drives: 2015 X5 XDrive 35i
um where are your HRE rims?
EDIT: nevermind I read above.... LAME!
      02-20-2015, 11:43 PM   #200
Lol, I took them off for the roadtrip to Vegas last week.
I don't want to deal with the headache if the valet guys damage the wheels.
PM for Everyday DEALS!!
      02-21-2015, 12:37 AM   #201
Taran.J
Taran.J's Avatar
Drives: BMW, LEX, MBZ, RAM, TESLA
Originally Posted by r33
Just got a chance to park side by side to another F15 X5 in stock condition.
This is the picture comparison between stock height and my lowered X5 with RG Sport spring kit.
Spring kit price? And JB intake any promo code? Is there any excess noise from the engine bay? I know it happened on my e90 makes it sound a little richer.
      02-21-2015, 12:39 AM   #202
Need some further pics
Uh, didn't took it. I don't want to get arrested for leaving minor unattended in the car. J/k
I don't want to show the other X5's plate, cuz I don't know the owner, lol.
      02-21-2015, 12:08 PM   #203
The intake will gives you a nice turbo sound. But not that loud where you can hear from the inside. I usually roll down my window and enjoy the sound during the drive home from work.
Spring kit price, do you have all around spring or rear air suspension?
I'll give you a forum price for sure.
      02-21-2015, 12:25 PM   #204
Taran.J
Taran.J's Avatar
Pm me for the intake please
      02-21-2015, 01:06 PM   #205
@Taran.J, PM'ed.
      02-21-2015, 02:18 PM   #206
cenix
cenix's Avatar
Drives: E90 M3 ZCP
r33, how were your camber specs before and after the springs? Care to share? Thanks!
      02-21-2015, 02:53 PM   #207
I'll look for the alignment paper later.
But it shouldn't change much since the car is using double wishbone/multi link suspension system.
      02-23-2015, 02:41 PM   #208
Here is my alignment spec after the drop.
As mentioned, the camber can't be adjusted due to the suspension design.
Front:
Left camber - -0.9° Right camber - -1.2°
Left toe - 0.05° Right toe - 0.05°
Rear:
Left camber - -1.5° Right camber - -1.5°
Left toe - 0.10° Right toe - 0.10°
      02-23-2015, 10:25 PM   #209
Taran.J
Taran.J's Avatar
Springs all around. Stock M sport suspension
      02-23-2015, 11:04 PM   #210
@Taran.J, PM'ed on the deal.
      02-24-2015, 03:17 PM   #211
cenix
cenix's Avatar
Drives: E90 M3 ZCP
Front:
Rear:
The suspension design, be it MacPherson strut, multi-link, double-wishbone, etc., shouldn't matter about adjustability. Adjustability would be up to the manufacturer's design.
From looking at the rear, there seems to be some camber adjustability by way of the eccentric bolts in the lower rear control arm pieces. Someone correct me if I'm wrong. For the fronts, it appears the only way to adjust camber is to get new upper a-arms which BMW has a part number for, and appears to give some set adjustability by around +/- 0.5 degree.
      02-24-2015, 04:38 PM   #212
cenix , MacPherson suspension usually have an oval slot on the bottom mount and/or top mount for you to adjust the camber.
While double wishbone or multi-link, by default, you are not supposed to be able to change the camber. Those parts that BMW sells are in order to compensate if you have chassis damage where you can't re-align the camber to the spec. But, of course there are some aftermarket products that makes you able to adjust the camber by changing the upper A-arm.
As for the rear, those eccentric bolts are for toe adjustment, but if you look at the way it positioned, it will also affect the camber while adjusting the toe.
      02-24-2015, 05:04 PM   #213
cenix
cenix's Avatar
Drives: E90 M3 ZCP
thanks for clarifying r33, very informative!
      02-27-2015, 02:50 PM   #214
I just did a quick 0-60 today using P3Cars gauge, and I got 5.56 secs.
I was on sport mode and manual shifting, and was about 3/4 throttle. Maybe soon I can spare some time at the local drag strip to do a few run and average it from there.
      03-24-2015, 04:55 PM   #215
Just got dyno. Here is the baseline compare to the JB4 Stage 2 (Map 2), BMS Intake, ER Chargepipe, and RG Sport Prototype muffler.
Next Mod: Catless Downpipe and FMIC.
Video will be uploaded soon.
      03-24-2015, 09:30 PM   #216
Video uploaded. Link on the OP.
Enjoy.
      03-25-2015, 10:15 AM   #217
SpdAddictRY
Drives: 2015 x5 50i
Impressive!
      04-01-2015, 12:18 PM   #218
2nd Dyno has been done yesterday.
Mods:
- BMS JB4
- BMS Air Intake
- ER Chargepipe
- ER Catless downpipe
- RG Sport Muffler
Video on OP.
      04-01-2015, 01:21 PM   #219
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
hey R33, I am not familiar on how to read the dyno charts but from what I can tell with all your performance mods your HP is max 349.05 and Torque at 391.08? Do you know what the Hp/Tq would be at with just the BMW JB4 tune?
      04-01-2015, 02:39 PM   #220
On the first dyno session, 1st run, I did baseline at 279.49whp and 296.27wtq.
The conditions are:
- 91 octane
- JB4 turned off
- Air filter (which very minimal hp gain)
- Charge pipe (very minimal hp gain, but eliminate turbo lag)
- Muffler (minimal hp gain, averaged 10-15hp in my experience)
On the 2nd run, I did 313.27whp and 362.65wtq.
The condition are the same as above but with JB4 at map 2.
So with that, it concludes, with JB4 only, it gives out 33.78whp and 66.38wtq gain.
If you have 93 octane, you will see more gain.
Also, I just recently did 2% mix of E85 while on map 2.
I may try 30% E85 mix soon, but it is more complicated on the setup. But, I've read that it is very rewarding.
