07-02-2021, 11:38 AM | #199 |
Rep 10,313
I started a separate thread discussing how to retrofit 4G capabiity / retain BMW Connected Drive services for F15 vehicle determined by BMW as "not eligible". It's not a simple process but a process does exist.
https://f15.bimmerpost.com/forums/sh....php?t=1832910 |
07-05-2021, 11:56 AM | #201 |
87
Rep 381
Guys, is it possible to buy 4G ATM, probably from BMW, but keep a regular NBT, not evo?
I see several options for ATM modules on eBay, ~$200-$300. What are pros and cons for those? |
07-05-2021, 06:25 PM | #202 | |
Luxury at the redline :)
9108
Rep 7,563
[/QUOTE] [COLOR="DarkRed"]Just for clarification, only 2016+ model year (03/2015+ for the 2 Series) vehicles are capable and eligible for this free 4G LTE upgrade. Absolutely no already 3G telematics system (vehicle built date 06/2015 and below) is capable nor is eligible for this hardware revision.[/COLOR] This offer not really an upgrade, per se, as both the older and newer telematics units run on the same 4G LTE connection. It's just that AT&T Wireless, the one and only data carrier BMW utilizes for its US telemetry operations, is killing off the original circa 2007 LTE standard that relay solely on circuit switching for voice calls, which is commonly known as "VoIP" or Voice Over Internet Protocol. After 02/2022, AT&T will then only support calls to be packet switched via a system called VoLTE; which is sending of voice data through cellular data such as 4G LTE. VoLTE will become AT&T's standardize system used for transferring voice calls by using the LTE connection. Since the earlier BMW 4G LTE telematics radios uses the now retiring VoIP technology for emergency calls, BMW is now offering a revised telematics system which would now support VoLTE or LTE-A calls, thus, emergency calls would remain functional, even after the obsolete "VoIP" technology for voice communication is officially sunset by AT&T. If one already has a 2016+ vehicle with a early 4G LTE (VoIP) radio and chooses not to take advantage of this VoLTE/LTE-A upgrade offer, most of the regular ConnectionDrive will still remain active as normal, with the exception of the emergency SOS calling, which would be the only feature no longer supported. https://www.androidauthority.com/vol...obile-1148654/ https://www.xda-developers.com/t-mob...-shut-down-3g/ |
QuarterMileJoe9.00 |
07-06-2021, 05:17 PM | #203 | ||
87
Rep 381
This offer not really an upgrade, per se, as both the older and newer telematics units run on the same 4G LTE connection. It's just that AT&T Wireless, the one and only data carrier BMW utilizes for its US telemetry operations, is killing off the original circa 2007 LTE standard that relay solely on circuit switching for voice calls, which is commonly known as "VoIP" or Voice Over Internet Protocol. After 02/2022, AT&T will then only support calls to be packet switched via a system called VoLTE; which is sending of voice data through cellular data such as 4G LTE. VoLTE will become AT&T's standardize system used for transferring voice calls by using the LTE connection. Since the earlier BMW 4G LTE telematics radios uses the now retiring VoIP technology for emergency calls, BMW is now offering a revised telematics system which would now support VoLTE or LTE-A calls, thus, emergency calls would remain functional, even after the obsolete "VoIP" technology for voice communication is officially sunset by AT&T. If one already has a 2016+ vehicle with a early 4G LTE (VoIP) radio and chooses not to take advantage of this VoLTE/LTE-A upgrade offer, most of the regular ConnectionDrive will still remain active as normal, with the exception of the emergency SOS calling, which would be the only feature no longer supported. https://www.androidauthority.com/vol...obile-1148654/ https://www.xda-developers.com/t-mob...-shut-down-3g/[/QUOTE] Does BMW really care about IMEI, there are a lot of those ATM modules on eBay for $200-300. What if I buy and install it in my car? |
07-06-2021, 06:15 PM | #204 |
Rep 10,313
Kolianovskyi, about ATM modules on eBay ... worth reading this post first.
https://f30.bimmerpost.com/forums/sh....php?t=1756438 |
07-06-2021, 06:55 PM | #205 | |
9108
Rep 7,563
Unfortunately, no, to simplify my answer; any vehicle running a current 3G connection cannot just be upgraded to 4G LTE without first changing the entire hard drive to at least iDrive 4 EVO and above. This upgrade BMW is offering is only applicable to vehicles which are already running an earlier version 4G LTE. So, think of this upgrade as like swapping the internet modem in your home for a more faster unit, however, it does not change your home computer's overall operation which it is actually capable of - or its lack thereof. TL: DR Current iDrive 3G owners are unfortunately SOL when it comes to this fixing this issue. |
07-07-2021, 08:10 AM | #206 |
184
Rep 308
Dropped my '15 off at the dealer this morning to do the allegedly possible upgrade. After having asked them twice before to confirm this was possible, and them saying yes, the service advisor taking my car in pointed out that it says its not possible in my warranty notes. But will have the shop foreman check it out, I'm not having high hopes now
Edit: That didnt take long. They called me and told me whoever i talked to was flat out wrong in telling me that this was doable. So, oh well. Last edited by Xolinlevh; 07-07-2021 at 09:04 AM.. |
07-07-2021, 11:21 AM | #207 |
87
Rep 381
Well, this became pretty clear.
$300 for Android mmi box and CarPlay on a display, traffic and navigation. HUD is useless then. No emergency calls. No service requirements. No stolen car being recovered. OR $750 ATM 4G + $1500 NBT evo and a display + paid traffic information. If I go with a second option I will buy a cracked lifetime code for CarPlay, hope that is not only for full screen but for a service itself as well. |
07-07-2021, 01:02 PM | #208 |
Rep 552
Hey guys!
Thanks for all the back and forth feedback on the thread. This thread was more to figure out the issue and get a resolution from BMW… and we all know where we sit at now. I do believe this thread to be dead. Any equipment stuff, parts, retrofit should just go ahead and please post at "cfm56d7b"s thread named… "3G Shutdown: Parts, Procedures, and Shops willing to try the retrofit" That way people are not looking at two separate threads for possible solutions and ways forward on this. Great group of guys here providing answers and feedback! This is what the community is all about 🤙🏽 |
richf8079.00 |
07-09-2021, 05:19 AM | #209 | |
9108
Rep 7,563
3G & 4G are two totally different technologies. 4G network depend on a completely different hardware from that of 3G, it's not only the software or telematics modem, which is the only two things BMW is offering to change with this free upgrade. However, who am I to doubt easily verifiable facts. So, congratulations, I guess 🤷🏻 . |
07-09-2021, 08:03 AM | #210 | |
184
Rep 308
07-09-2021, 08:25 AM | #211 | ||
9108
Rep 7,563
No shade bro, you got me all wrong. I wish you nothing but the best.. I read what you wrote and I'm not accusing you of saying or claiming anything.. But here are the facts; Your vehicle is a 2015 model year, which is running a iDrive 4 3G hard drive. BMW is offering a upgrade only to the telematics communications unit and a software update. If they not also replacing your 3G only iDrive to that of a 4G capable unit, then the upgrade to 4G is factually not possible. Anyone claiming otherwise is sadly mistaken and this can be verify by anyone with a spare 2 mins and an internet connection.. However, if your dealer is somehow able to turn water into wine, then who I am I doubt them. More power to you and Enjoy your "4G" |
07-11-2021, 09:06 PM | #212 | |
Rep 14
Drives: BMW X5M Dinan, BMW 335i xDrive
Your post is exactly what most would describe as the male version of a Karen... lol And no one here has claimed otherwise.... ... Claimed otherwise to your "technical" observation. BTW: So, if its only a "hard drive" at issue, why can the OS just not simply be reinstalled or upgraded....? I am intrigued. Last edited by unplugged216; 07-11-2021 at 09:11 PM.. |
07-11-2021, 10:39 PM | #213 | ||
9108
Rep 7,563
The irony of you calling me a "Karen" because you're offended I was being logical with your buddy, must be lost on you What he was his claiming was impossible and a waste of time. Sorry if I came off snarky but after 10 pages of the same repetitive experience with current 3G vehicles, plus official documents to support this, it was attempt to convey the obvious and save him the trouble. However, if he wanted to roll the dice at a losing game, it was his time to waste, I didn't lose any sleep over it either way. By now, I'm sure the dealer has informed him that it can't be done, so he should update the thread. Weird that he hasn't, right 🤨 |
07-12-2021, 03:18 PM | #214 | |
Rep 14
"Edit: That didnt take long. They called me and told me whoever i talked to was flat out wrong in telling me that this was doable. So, oh well." Original Post.... |
07-12-2021, 03:47 PM | #215 | ||
9108
Rep 7,563
The point is that factually a 3G can't be upgraded to 4G without first installing a compatible hardware. I don't know why you guys keep going around in circles about what I originally stated. That was the only issue with the OP's claim. I have no beef with the dude, I'm just working with facts, not emotions, so keep it simple and move on. |
07-12-2021, 04:00 PM | #216 | |
Rep 14
I appreciate your effort to mask the fact you didn't read and continued to be argumentative. You still haven't answered my original question to your "facts" regarding a "hard drive".... FYI... Its just me, no one else cares and I just need some entertainment watching a troll flail. Last edited by unplugged216; 07-12-2021 at 04:11 PM.. Reason: Added a link for ref |
07-31-2021, 03:51 PM | #217 | |
Rep 14
Anyway, I did the same as you. Knowing there is way more to this "upgrade" or "retrofit" than the documentation is eluding to I went ahead and followed suit. I contact my BMW dealer and asked if they could verify my VIN. They in fact did. I was told that SIB 84 02 21 was in fact in effect for my 2016 X5 M (F85). So, I scheduled my appointment. Thankfully I had a service due and some other stuff so it wasnt a waste. I get a call telling my vehicle is ready. I get down there and am informed that the "recall" no longer appl;ied to my vehicle and there is now a SIB attached to my VIN, SIB 84 01 2021. This SIB describes how my vehicle does not meet "the technology requirements." From ym research and retrofitting many a BMW with gizmos and gadgets, I know there are three main things that need to updated. My head unit needs to be upgraded to the EVO unit as well as the wiring harness to the boot and them the communications module. So, I went ahead and got all riled up. I got the "Regional BMW NA Engineering" team involved and filed several complaints. They are currently reviewing the "situation." What is so messed up is that my $170,000 vehicle, its got all the Dinan crap also every package that was available, is now a rolling technological brick. Fast as hell but still dumb lol. My BMW turns 6 in 2 months, that is from its official production date of 10/08/2015. This means that it was in the last production run without 4G. Really? lol |
07-31-2021, 06:31 PM | #218 | |
Rep 10,313
In addition to informing all affected owners that the decision has been made by carriers (and not BMW), BMW isn't particularly motivated to create an approved 4G kit because the cost of three parts - NBT Evo + ATM + wiring loom - plus labor would be north of $3K at the very least. At this point, only customers that purchased the vehicles are affected. Lease customers are already driving some other vehicles. |
08-01-2021, 03:52 PM | #220 | |
Rep 14
