10-27-2018, 08:38 AM | #89 |
Rep 1,343
Ask your dealer to replace them. I would think if it's CPO they should have been able to spot this.
01-13-2019, 09:17 AM | #90 |
Rep 52
resurrecting this old post...
I've been doing a ton of searching, but can't find anything related to the actual removal of this particular door seal. I just purchased new ones to replace my torn seals on my MY2014 35i, but cannot figure out the best way to remove the seals from the door jamb. I tried a hair dryer to heat the adhesive, but didn't seem to work well enough. Any suggestions? |
01-13-2019, 10:07 AM | #91 |
Rep 627
Drives: X5 F15 M package
Did you watch this video
01-13-2019, 02:38 PM | #93 |
1150
Rep 2,426
Start from the top with a plastic pry tool. Lift it up and just pulling. To get rid of the adhesive, use the same pry tool to scrape it off. Should take no more than a few minutes to remove it. Installation I also started from the top. I peel away a little of the double-sided tape and I pressed it down bit by bit whilst removing the backing tape. Took me I think five minutes total.
2015 BMW X5 xDrive50i
BMW CCA 509766 Last edited by alphaod; 01-13-2019 at 02:45 PM.. Reason: Added picture |
Russmov1328.00 |
03-03-2022, 09:02 AM | #95 | |
Drive Different
52
Rep 225
'17 F87 M2 DCT / '16 F15 X5 X35i / '09 E82 135i 6MT*
'10 E70 X5 35d* / '05 E60 M5 SMG* / '01 E53 X5 4.4i* / '76 2002* | '70 2002* *Gone |
03-07-2022, 09:34 AM | #96 | |
Rep 7,489
If you look at alphaod's amended pic below...the top of the lower gasket gets tucked under the bottom of the upper gasket. Is this the "hook" you're referring to?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-07-2022 at 09:41 AM.. |
03-07-2022, 12:01 PM | #97 | |
Drive Different
52
Rep 225
03-08-2022, 03:48 AM | #98 |
Rep 17
There is also a method to use dental floss to 'saw' through the adhesive similar to removing an emblem.
I used this method when replacing these seals rather than prying, once I got a big enough edge up from the bottom, I was then able to pull the seal off, as its actually made from plastic where it attaches to the door. |
03-11-2022, 10:02 AM | #99 | |
Rep 7
03-01-2024, 12:17 PM | #100 | |
Rep 81
That link shows "Note:This product is no longer available.". Has this been superseded and if so what part number should I be looking for and where? |
Tags |
defect, door, gaskets, seals |
