03-02-2015, 01:41 PM | #46 |
Rep 420
03-02-2015, 01:53 PM | #47 |
Rep 3,990
Taking it tomorrow morning for my friend to tighten up all the bolts and make sure both struts are properly compressed and fitted correctly (his worker must not have compressed and tightened everything the way he should have). Then, appointment at 3pm tomorrow for wheel alignment and have them double check the strut/suspension. Last thing left to do is contact BMW (again- left two vmails - epic fail) to make a service appointment for this random engine start stop shutdown hiccup.
03-02-2015, 02:15 PM | #48 |
Rep 7,063
Good to see your plan breakdown. Seems solid. Hopefully the SA and laborer are cool and don't mess with you too much when you go in based on mods.
03-02-2015, 02:19 PM | #49 |
Rep 3,990
Thanks, Taran. Keeping organized is what keeps me sane, lol. My SA is cool (when I can get a hold of him ), so that shouldn't be a big deal. We'll see. I'll update on the full progress. Once everything is settled, I'll get better pictures together in the sunlight including interior.
03-02-2015, 02:37 PM | #50 | |
Rep 7,063
03-02-2015, 03:26 PM | #51 | |
Rep 450
Fingers crossed you get it all sorted out quickly. |
03-02-2015, 04:08 PM | #52 | ||
Rep 3,990
Also, I asked my SA about the 6WB update and he had no info on it, so I will have to remove it to be safe since they will need to program and use ISTA/P on my car to fix it.
03-02-2015, 04:23 PM | #53 |
Rep 450
It must be a real PITA to have to take the 6WB out when you want service, what's the service interval like on the petrol engined F15's?
I'm so tempted to get one for myself having seen your images of it and some others from SDRX's M50D that has just been delivered, but mine is leased so hard to justify so I'll just have to wait until my next one. I even enquired with BMW here in the UK about it but it isn't available from BMW as an official upgrade for mine, it is only available for MY2015 F15's that could have had it from the factory to start with Would you know if the same problem you have over there would happen here too? Say I upgraded to a 6WB which isn't available for my VIN, would I have to remove it before service even though 6WB is officially available here just not for my VIN. Do BMW lock down their ISTA software systems by VIN? |
03-02-2015, 04:30 PM | #54 | |
Rep 741
My advice would be to wait for the F15 LCI launch probably in 2017 and you'll have access to many new options - possibly a second generation 6WB too.
2018 G30 540i M Sport X Drive
2020 G05 X5 30d M Sport |
03-02-2015, 04:39 PM | #55 | |
Rep 450
I've got mine for 4 years which takes me to July 2018 so I'll see what the LCI brings if it happens in 2017. I'm also pretty interested in the eDrive F15 due later this year which would save me serious amounts of company car tax unless they change the tax system by then. I'll have to see if I can get a test drive when the local dealer gets one. |
03-02-2015, 04:42 PM | #56 | |
Rep 3,990
03-02-2015, 04:43 PM | #57 | |
Rep 741
Its only a matter of time before a cap gets introduced........
03-02-2015, 05:51 PM | #58 | |
Rep 450
03-03-2015, 09:20 AM | #59 |
Rep 19
Loose nuts and ball joints on the sway bars can sound like they're coming from the strut tower mounts.
The strut tower bearing force is always upward (from the spring) unless you go over a really bad bump. The central nut, holding the shock tube to the bearing does get force reversals on decent bumps and can clunk if loose. The sway bar mounts go through force reversals on even very small bumps, as the car tries to rock back and forth. So, sway bars mounts really need to be zero-slop. |
03-03-2015, 01:57 PM | #60 |
Rep 18,716
@opasha, for my username fixed,
MattBianco, you don't need to have my name shortcut saved anymore.
03-03-2015, 06:21 PM | #62 | |
Rep 3,990
03-03-2015, 06:27 PM | #63 |
Rep 286
5
03-03-2015, 07:40 PM | #65 |
Rep 3,990
Chassis Stability randomly popped up in EcoPro, but after I shut down the car and started it 30 minutes later, it disappeared. The suspension is 100% back to normal and feels/drives like a champ again . Only thing left now is the start stop issue, which will be taken care of on Thursday by BMW. I also tested the camera functionality, and it's pretty solid even at night. I'm gonna get him to fix the rear view camera because it is indeed upside down. I'll record some of my trip to the BMW dealership and show you guys some nice scenery on interstate 70 .
I'll kindly ask them for a full detail as well and take some pictures after I get it back. The color really shines at night...it's remarkable. PS: Having the car not coded (VO Coding resets everything back to factory state) at all is super annoying, lol. You don't realize how nice the coded features are until they are gone.
5
