03-06-2015, 06:05 AM | #89 |
Rep 286
opasha - well done on figuring it out correctly, but may I just ask, why take the risk to dismantle the brake pedal yourself? Wouldn't it be easier to just get the BMW guys to sort everything out once and for all?
03-06-2015, 06:43 AM | #90 |
Rep 3,990
I won't be dismantling the brake pedal. It's the brake light sensor. It just needs to be pushed forward so it make contact withe the brake pedals sensor. It's a simple fix. I don't really want to drive all the way to BMW for that. Sure, if my dealer was 10-15 min away, no problem, but my closest BMW service center is about 1-1.2 hours away. I would have to remove both my 6WB and RaceChip before that as well (something I decided not to do since I cancelled my appointment due to the snowstorm the next day). I also think the chassis stability error could be related to the cold or something to do specifically with EcoPro - this I'm going to test again - it could be related to my battery as well. My battery was discharging when I turned the car on in AC POWER mode (one button push). If it's not something that gets resolved easily, then I will make an appointment for Monday, but I want to exhaust all my options first before doing that. That way I can also properly explain to the service department what they need to check.
03-06-2015, 01:38 PM | #92 |
Rep 3,990
03-06-2015, 02:49 PM | #93 |
Rep 3,990
Took my car to my friend at Midas, and the brake light sensor was twisted out of place from it's original perfect position, so they just had to readjust it. Took about 30 min, but everything is working well again . I have not seen the stability issue pop up either.
03-06-2015, 03:12 PM | #94 | |
Rep 55
03-06-2015, 10:44 PM | #97 | |
Rep 18,716
Is that the one that I show you the diagram? I believe it is.
03-06-2015, 11:16 PM | #99 | |
Rep 3,990
I figured it out by working backwards. It was when he removed the driver lower panel (this houses the sensors/wiring for the brake and acceleration pedal, etc) to feed the micro usb power cable for the E-level touchpad that adjusts the height of the air suspension. He must have knocked out of its original position (turned or twisted) without realizing. When aligned correctly, this sensor is touched by the sensor/some switch on the brake pedal metal arm that hits this sensor telling the computer: "Ok, you can turn off the brake lights because I'm not being pushed by Omar's foot anymore to make the F15 stop."
03-06-2015, 11:56 PM | #100 |
261
Rep 733
Glad to see that you've figured it out.
03-07-2015, 08:27 AM | #101 |
Rep 18,716
@opasha, no worry. Glad you got it fixed.
Now we all know where to look when the same issue occurs on our cars.
03-07-2015, 10:56 AM | #102 | |
Rep 609
Joe |
03-07-2015, 02:15 PM | #103 | ||
Rep 3,990
Feel free to ask questions anytime. I'm always happy to help .
03-07-2015, 02:36 PM | #105 |
Rep 3,990
Haha, you mean my stock suspension?...I appreciate it more now than before. It drives well with the 22s. I think that the larger wheels really improve the handling/road feel overall. I was only trying to get closer to a DHP feel and was told that the steering would be tighter as well (my main goal), but this was not the case with the accuair.
03-07-2015, 02:44 PM | #107 |
Rep 3,990
Yes, read my previous thread. I talked about the issues. http://f15.bimmerpost.com/forums/sho...032521&page=24
r33_RGSport, Taran.J, I don't have self-leveling rear. I have completely stock suspension. I asked Eddie what he was referring to in my rear. It's all stock but the rear has its own factory dampeners so we didn't need to put in new ones nor had to mess with factory parts in that regard. So, even if any of you modify yours...you will run into issues unless you bypass the height sensors or whatever may cause chassis stability malfunction (this thing is very sensitive it seems). I guess our F15 computer is really that smart.
03-07-2015, 03:20 PM | #108 |
Rep 18,716
@opasha, the loaner I got is indeed the first F15 AWD that I ever drove. The steering feel much looser than the sDrive. Surprised me.
Also the running board keep on hitting my calf, in and out the car. The other thing, I always got stability synchronizing when I start driving within 10 seconds of starting up the car. Fortunately, it is a loaner, so I don't have to live with it.
03-07-2015, 03:42 PM | #109 | |
Rep 3,990
Yes, I agree, the running boards def get annoying for hitting the calves. Thankfully, my habit of stepping out and over and being 6' tall helps me avoid hitting my calves often, but it is definitely a big design flaw.
03-07-2015, 06:29 PM | #110 | ||
Rep 18,716
I have felt the loaner xDrive a little more loose on the steering wheel.
