      04-28-2019, 02:38 PM   #23
Meehow
Meehow's Avatar
19
Drives: '14 F15 X5 Msport
Transfer case 100%. Change the fluid and run a calibration in ISTA
      04-29-2019, 10:41 AM   #24
markslc1
Drives: 2011 1M, 14 X5 x35i
I guess I'll start with plugs. Really hope it is not a transfer case. Any other tests to confirm?
      04-29-2019, 10:43 AM   #25
markslc1
Is there a diy somewhere for this?
      04-29-2019, 10:44 AM   #26
turboawd
1636
Drives: 2015 X5 35i
Sounds like misfire. You said you had old misfire codes too.
Just change your plugs first and go from there.
      04-29-2019, 10:45 AM   #27
markslc1
No codes. So thinking it's something else
      04-29-2019, 11:21 AM   #28
turboawd
1636
Drives: 2015 X5 35i
But you said it had those codes in the past?
Just change your plugs first. It's easy and cheap.
There's 2 plugs on transfer case. One to drain and another to fill. Takes less than a quart of fluid if I remember correctly. And it's expensive if you buy the fluid from a dealer. Supposedly it's a GL4 lubricant.
      04-29-2019, 01:17 PM   #29
Meehow
Meehow's Avatar
19
yes, get underneath the car and disconnect the transfer case plug - fairly simple. I think you can do the same pulling fuses.
I would scan the car - if you don't have any misfire codes it's the transfer case for sure.
I had mine done at the dealer for $250 - fluid service with adaption reset at 60k miles. Has been fine ever since.
      04-29-2019, 01:49 PM   #30
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
Gotta check codes being fired first.
Could be ignition coils too. If one is bad, it causes headaches.
Changed mine preemptively to avoid any blinking CEL in future.
      04-29-2019, 09:39 PM   #31
markslc1
What does removing the transfer connector case do exactly?
      04-30-2019, 01:55 AM   #32
turboawd
1636
Drives: 2015 X5 35i
hey, dont let the other guy scare you about the transfer case yet. i would think a bad transfer case would shudder at low speed turns. just get the plugs changed first. its a simple job. rule that out first.
      04-30-2019, 05:45 AM   #33
LocksmithNick
LocksmithNick's Avatar
Drives: BMW X5 M Sport - G05
The transfer case issues are mostly with 50i. Yours is probably just plugs.
      04-30-2019, 09:06 AM   #34
Meehow
Meehow's Avatar
19
It deactivates it. PM is you would like to chat further about it, might be easier to jump on a call. (will throw a code) but if you go drive it and the tugging is gone, you know the culprit is the transfer case.
I've chased the same symptoms for about 2 months - changed plugs/coils- did nothing. (dumb, because I didn't have codes, but all the experts on here believe that should be step 1 in diagnosing anything)
Once I did the fluid change and adaptation, it's smooth as butter.
      04-30-2019, 09:29 AM   #35
LocksmithNick
Plugs can definitely give your car a sluggish feel when they need replaced, which is a similar feel (I think) to the transfer case issues. Regardless, both things probably need serviced on a 60k mile German vehicle.
      04-30-2019, 11:18 AM   #36
Florida-X3
Drives: '24 X3 x30i / '12 Infiniti M37
Was transfer case for me and only did it under harder (not excessive) acceleration.
      04-30-2019, 11:19 AM   #37
Florida-X3
Happened with my 35i
      04-30-2019, 11:21 AM   #38
Florida-X3
This is what the dealer did for me, first replaced plugs and coils, still there. Disconnected the transfer case and issue went away. Things replaced under CPO. Symptoms were under semi-heavy acceleration the car would kind of buck or skip. It was bad enough the wife noticed it and she doesn't notice much when driving.
      04-30-2019, 03:22 PM   #39
markslc1
So I'd like to start with the transfer case oil change. The change seems easy enough. But the resetting of adaptations would require some coding I believe. What is the most cost effective way to do that ? Carly?
      04-30-2019, 03:39 PM   #40
David3
Drives: E21 (x2), E46, F15, G05 LCI
Not an F15, but the transfer case in my F10 needs to be changed as it exhibits the same described symptoms. Yes, unplug the electrical connector at the transfer case. You will get tons of warning lights, but ignore those and go for a drive. If the symptoms go away, it is the transfer case and an oil change will not fix the issue.
It is important to not mix and match tires front to back or simply replace tires on one axle at a time as the small change in diameter (front to back) plays havoc with these transfer cases.
Usually, you will get a whine as well as the jerking feeling. usually gets worse as the fluid temp rises.
      04-30-2019, 05:10 PM   #41
turboawd
1636
Drives: 2015 X5 35i
Why not the plugs? They are a wear item and who knows if the previous owner had a tune or a heavy foot and put some wear on the plugs..
      05-01-2019, 10:21 PM   #42
markslc1
Crawled under the car to locate the TC plug and found this
View post on imgur.com
But I can't get my hand in there to pinch the connection. Any advice on getting it unhoooked?
      05-01-2019, 11:17 PM   #43
turboawd
1636
Drives: 2015 X5 35i
You'll have to remove the splash shield
      05-02-2019, 10:28 AM   #44
David3
I should probably clarify my previous post: For me, the jerking symptom (F10) happens while coasting, same with the whine. When my F10, 550i exhibited jerking on acceleration, it turned out to be a bad coil.
