04-28-2019, 09:16 PM | #45 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
You can suggest a map update if you want:https://mapcreator.here.com/mapcreator/
Here is partially owned by BMW, and BMW uses Here's data for the maps.
Freude am Fahren.
05-06-2019, 10:06 AM | #46 |
Rep 74
does anyone have a torrent link for this? i tried the magnet link and it was stuck ... (i.e. not downloading)
The mega link caps out at 46% and tells me it doesnt have enough space to downlaod it wihtout using their crappy software ... TIA |
05-18-2019, 11:22 AM | #47 | |
Rep 43
05-18-2019, 11:27 AM | #48 | |
Rep 43
06-11-2019, 08:16 AM | #50 |
Rep 174
06-13-2019, 02:08 PM | #51 |
Rep 252
Drives: '06 M3, '20 X3MC, '03 540i MSp
downloading now, thanks!
2020 Dark Graphite X3M Competition
2021 Audi e-tron 2006 Mystic Blue M3 2003 540i MSport 1991 Red 318i (M50B25 engine swap) |
06-14-2019, 09:27 AM | #52 |
Rep 7,488
If you're not that computer savvy and find that the "free" downloads are above your skill level...you can purchase updated maps from your local BMW dealer ($$$$$)...or you can use the services of vendors like the one at the following link which is usually a more reasonable cost solution: https://bimmernaviupdate.com/.
BimmerNavUpdate.com offers multiple ways of updating maps...you can download the maps (after paying a fee)...or again, if your CPU skills are not that great...you can purchase a USB thumbdrive with the data already to upload to your BMW. Good luck with whatever decision you make.
06-14-2019, 12:25 PM | #53 |
Love the X5, but R1 is life!
20
Rep 69
Just did the update myself. Upgraded from my 2015 maps to the new one and got a "lifetime" FSC code from ebay. For a first timer, the upgrade went extra smooth although there are some things to watch out for.
I'm not sure if a FAT32 usb drive is absolutely required but I had to find software that would format my USB3 128GB usb thumb drive to Fat32 (For windows look for guiformat by Ridgecrop.) I believe windows struggles formatting anything >32GB with Fat32. Once completed I figured it'd be a few minutes at best. I extracted the ~24GB map to USB, took it out to the car and I turned on the ignition but didn't start the car. Plugged in the USB drive and after a few seconds the update was detected. I said yes to start. Before it started, I was prompted to enter the FSC code (I remembered there are no 1s or 0s, zeros to avoid confusion.) The code took. The file copy/update process took almost 45minutes. I left the key in the car and walked back into the house and periodically checked on it. It completed while I was in the house and idrive had shut itself down, or the radio did at least. I wish the drive in the car were usb3.0 compatible. Transferrign 24GB data took a while. The map updated successfully but I noticed there were still some changes missing - I've got a whole new interchange near where I live (new stepfordwivestypeofsurburbia) which didn't show up even though it's been completed for at least a year. The process wasn't difficult but you definitely need to have some time to tackle it. Last edited by hlrzr; 06-14-2019 at 12:31 PM.. |
06-14-2019, 01:39 PM | #54 |
Rep 885
Process itself is very easy, as hlrzr mentioned it just takes a bit of time. Lots of resources out there regarding FSC codes (both one time and lifetime) as well as Map Updates. For those that can't get their hands on torrent files and/or don't want to pay the ridiculous amount from BMW, check out:
https://www.ebay.com/itm/BMW-Navigat...72.m2749.l2649 https://www.ebay.com/itm/BMW-Navigat...72.m2749.l2649 Response time is roughly 20 min to get code/map link. |
Silververtu231.00 |
06-14-2019, 08:24 PM | #55 | |
Rep 7,488
The last thing I need is the battery going dead or it's voltage going low enough that the car starts shutting down systems that might corrupt the data that's being uploaded. You can see that I'm a big ol chicken when it comes to leaving a BMW on with only the battery powering everthing for anything over a few minutes. I''ve played with that fire before and got burn.
hlrzr19.50 |
06-15-2019, 12:03 AM | #56 |
20
Rep 69
Plain dumb n00b luck that it didn't die, I guess. I had the headlights off and radio off after I left. Only thing left running was the idrive and the display turned itself off although the update kept going - i actually had to press the volume button for it to turn back on and I saw I was at 72%.
I appreciate your thoughts though - definitely wouldn't want the battery going dead happen to anyone. |
06-15-2019, 03:11 PM | #57 |
Rep 128
Drives: 2015 BMW x5
Did anyone else have to use different USB drives to get this to work? I am using a 128 GB flash drive. I was prompted to update, but now the idrive is asking to insert USB #1.
06-15-2019, 03:43 PM | #58 |
Rep 174
That means that the car doesn't see the data. It could be some corruption somewhere. I had the same problem when using an older usb stick with a micro sd card. I bought a native 64mb usb3 stick and have had no problems.
06-15-2019, 03:47 PM | #59 | |
Rep 128
Drives: 2015 BMW x5
06-20-2019, 09:30 PM | #61 |
Rep 244
06-21-2019, 01:53 PM | #62 |
Rep 108
Clarification please!
If I buy a map update and a lifetime FSC bundle from a vendor, is the lifetime FSC only usable with the vendor I bought from or can I buy a map update from a different vendor next year without needing to get another FSC? |
06-21-2019, 03:21 PM | #63 | |
Rep 271
No need to buy map update, just follow the links on the forum to download. Many of us have done it. |
CanadianLurker41.00 |
06-23-2019, 10:55 PM | #64 |
20
Rep 69
06-24-2019, 09:34 AM | #65 | |
Rep 1,168
EDIT: the code worked for 2020-1 map. Go figure... Last edited by smyles; 08-13-2019 at 09:18 AM.. |
06-24-2019, 12:17 PM | #66 |
Rep 27
