      11-12-2020, 05:34 PM   #1
aroldo.aguilar
Drives: 2015 X5 35i
2015 X5 Front fuse box removal
Hello, wondering if any of you had replaced the front fuse box, mine looks like have water damage since the right blinker was not working on the cluster but it was working normally outside, when I pulled the cluster fuses from the front box, was a water leaking from there, cleaned and let it dry over night, worked fine for a day and again went off from the cluster.
Any help will be gladly appreciated.
Thanks!
      11-12-2020, 06:35 PM   #2
turboawd
1636
Drives: 2015 X5 35i
Why not open the box and clean the wire terminals?
      11-12-2020, 07:38 PM   #3
aroldo.aguilar
Drives: 2015 X5 35i
Yeah, that's what I'm gonna try to do first before to replace the whole box, but wondering if its a hassle to remove it or if someone had done it before, think that to access that area need to remove the door sill cover then the foot rest cover, but not sure if after that the box is reachable.
Thanks for the suggestion
      11-12-2020, 07:57 PM   #4
turboawd
1636
Drives: 2015 X5 35i
If it's like most other fuse box, the box is just plastic, and the terminals inside are the actual wire ends with terminal plugs.
