12-05-2014, 09:11 AM | #1 |
Rep 3,126
F15/16 X5/X6 DINANTRONICS Performance Tuner Now Available!
The DINANTRONICS Performance Tuner is now available for the F15/16 X5/X6 (3.5 & 5.0)!
With a maximum performance gain of 77HP and 81 lb-ft of torque on the 35i (73 HP and 67 lb-ft on the 50i) you can combine the versatility and luxury of your current X5/X6 with increased usable power from Dinan for the ultimate package. Coupled with Dinan's signature factory matching new car 4yr/50k warranty it's a great addition for a new car. Please consult our website for pricing and any other specifications. You can also review the performance graphs below and let us know if you have any questions. X5/X6 35i X5/X6 50i |
12-05-2014, 09:46 AM | #2 |
265
Rep 345
Drives: 2019 X5 40i M
Any plans for a tune for the 35d?
2019 X5 X40iM
12-05-2014, 10:10 AM | #4 |
Rep 3,126
Historically Dinan has never given much thought to Diesel applications but this past generation we have had enough interest and inquiries on diesel models that it has at least been noticed by those in charge. While nothing absolutely definitive has been started I believe there is a distinct possibility that some diesel development may be forthcoming. The company stance up to this point however has always been that we are going to complete the regular gasoline lineup first and then re-access after that. We are closing in on completing all the gasoline lineup of vehicles by January/February 2015 it appears so a definitive answer should be forthcoming after that.
12-05-2014, 10:15 AM | #5 |
Rep 428
12-05-2014, 10:28 AM | #6 |
Rep 7,063
Holy sticker shock
Then again it is Dinan and warranty stays in tact
12-05-2014, 10:49 AM | #8 |
Rep 561
12-05-2014, 11:29 AM | #9 | |
Rep 3,126
Dinan Differences: One of the largest differences between a Dinan tune and most others is that we don't CREATE faults/codes so there is no reason to integrate the functionality to clear them. Just like software in previous generations we are after factory like drivability just with more 'oomph' and full integration with BMW parts and software is paramount in accomplishing that. Most other tunes rely on targeting specific signals related to boost pressure and alter those specific signals ONLY, thereby setting off codes/faults and letting the factory ECU adjust every other related parameter accordingly. We would argue that this 'reactive' adjustment hinders the drivability of a BMW that they are known for. While drivability is a subjective term a smooth delivery of increased power throughout the RPM range is nearly always the first comment someone who drives a Dinan vehicle mentions and in essence is what drivability is all about. Usable power with no hiccups, stutters, lurches or anything of that sort; just smooth power that seemingly keeps going. While the 'reactive' method works the fact remains that we see drivability suffering in addition to codes/faults constantly being set and then cleared so no CEL is given even though there is one. This is unacceptable to Dinan as it is basically skirting factory safeguards that has been put in place by BMW. Dinan on the other hand takes a 'proactive' approach and looks at / or interfaces with all related signals so no faults/codes are ever set so that the previously mentioned drivability can be given. This also ensures no CEL's will be given (visible or hidden) and the factory safeguards are still in place and usable. The other major difference is of course warranty. It is what Dinan is known for and we are still the ONLY aftermarket tuner that offers a BMW factory matching 4yr/50k new car warranty. We stand behind our engineering and our products and are comfortable enough to warrant our products and any harm, should it occur, to your vehicle related to the Dinan tune. This way there is peace of mind knowing that if something does happen, you are still covered by either BMW or Dinan. |
12-05-2014, 11:33 AM | #10 |
Rep 561
There apparently are two versions available. The one from BMS is super easy to install taking less than 5 minutes because it plugs into the MAFs on top but the ones from Racelogic apparently requires that you install them to another set of I assume MAF's down below. Opasha would be able to better explain since he has that one.
12-05-2014, 12:31 PM | #12 |
90
Rep 398
I was told that 35d was forthcoming in early 2015 when contacting Dinan directly.
Do you have any additional information other than the notes above regarding gas engines being near complete. |
12-05-2014, 01:52 PM | #13 | ||
Rep 3,126
12-05-2014, 05:25 PM | #15 |
Rep 3,126
We are currently looking for a local 50i that we can have access too for longer then a day or 2 at a time so that we can develop/test fit various pieces for the 50i. I do not believe an intake was an item on that list but then again the lists from engineering are in a constant state of flux so it may have been added recently. If history was any indication though I wouldn't count on an intake for the 50i from Dinan.
12-05-2014, 06:05 PM | #17 |
Rep 3,990
I'm content with my RaceChip TB Ultimate at $604. 507hp/564 lb/ft torque is enough for me.
12-05-2014, 06:38 PM | #18 |
Rep 188
any plans to sell it in Europe?
On order - 2017 F15 X5 40d M-sport Individual
Current - 2016 Porsche 991 911 Turbo S w/ Aero Kit Retired - 2015 F15 X5 50i, Mocha Nappa, M Sport Wheel, Night Vision w/ human recognition, Harman Kardon Retired - 2011 F10 550i xDrive |
12-05-2014, 06:52 PM | #19 |
Rep 3,126
12-05-2014, 07:10 PM | #20 |
Rep 481
Drives: F82 BMW M4
@Dinan_Engineering -- Thanks for the info! Just wondering if you have any solution for customer who lease their cars. Can we remove and sell this tune like BMS or Racechip before returning car back at the end of the lease?
2021 BMW X7 M50i + 2015 BMW M4
Retired: 2018 Audi Q7 | 2015 BMW X5 xDrive35i | 2012 BMW X5 xDrive50i | 2010 Audi S4 | 2007 335i Coupe Creator of Leasematic - Lease/Loan Calculator | iOS App Store | Android Google Play |
12-05-2014, 09:01 PM | #21 | |
Rep 710
12-05-2014, 10:44 PM | #22 | |
Rep 3,126
Yes/No on the reselling the tune. Unlike other vendors we have a different process and different factors we need to take into account on our tuning solution (such as warranty). Since one of Dinan's unique qualities is being tied into the dealership base and making it as easy as possible for them to stock and sell units we have split the DINANTRONICS system into 3 parts; the Dinan ECU, the wiring harness and the software itself. This way the dealer is able to program any car that may come in with a limited number of parts on the shelf. The Dinan ECU is a blank box by default and is universal amongst all applications. There are 4 different wiring harnesses (4 cylinder, 6 cylinder, M3/M4, and 8 cylinder), and then there is the unique software for each model of vehicle. So what that means is that the only piece that is guaranteed to be able to be re-used is the Dinan ECU. so depending on who you are selling or transferring to there are many different scenarios. They are in no particular order: 1.) You have an F15 X5 50i and you sell it to another F15 X5 50i user. For all practical purposes it will work fine (This assumes the harness doesn't need to be replaced or anything and is still in good re-sellable shape). The one caveat is the new vehicle will have NO warranty since the software installed on that box is tied to the original vehicle, NOT the new one. 2.) Same as above but the new owner wants a warranty. They would have to send the original ECU back to be scrubbed of the old software and then purchase what equates to a new license of software that would be tied to the new vehicle with warranty. 3.) Sell to some random guy who wants DINANTRONICS on his totally unrelated car. The ECU will transfer again but need to be scrubbed and new software installed. The harness depending on application may be transferred; just depends on the new application as their are 4 different harness styles. In this scenario the only cost savings potentially could just be on the ECU where the harness and the software would still have to be transferred. It's a bit convoluted hence the yes/no answer. |
