10-04-2014, 04:22 AM | #177 | |
Rep 3,990
10-04-2014, 04:38 AM | #178 |
Rep 40,774
FLA_AKTIVIERUNG sets High Beam Assist (HBA) on by default with lights in Auto or Manual On Position.
10-04-2014, 04:48 AM | #179 |
Rep 3,990
Ah, that makes sense. Thanks for the clarification, my friend .
10-04-2014, 09:53 AM | #180 |
Rep 18,715
@opasha, I've just set you to be able to edit on the cheatsheet. Maybe you can type up the addition that's not in the cheatsheet.
@skalberti, PM me your email address, and I'll add you to be able to edit the google docs. I've been leaving it open where everybody can edit, and I saw it got messed up twice. So, I only allow few knowledgeable member to be able to edit. @wdimagineer, PM me also if you want to be able to edit it.
10-04-2014, 10:03 AM | #181 |
Rep 206
10-04-2014, 10:27 AM | #182 | |
Rep 3,990
10-04-2014, 11:38 AM | #183 |
Rep 40,774
Are you sure? Normally in the U.S., Open Windows from Fob or Comfort Access works, but Close function needs to be coded.
10-04-2014, 11:49 AM | #184 |
Rep 1,133
This code isn't the same as FLA_AUTO_AKTIV. By default on the F15, you can only activate the HBA when the headlight switch is in the auto position. When you manually turn the headlights on and depress the HBA button on the BC nothing happens. FLA_AKTIVIERUNG allows you to turn on the HBA in the auto position or turning your headlight switch all the way to the right or position 2.
10-04-2014, 11:51 AM | #185 |
Rep 40,774
Ok. Thanks for clarifying.
10-04-2014, 04:15 PM | #186 | |
Rep 3,990
10-04-2014, 04:19 PM | #187 |
Rep 1,746
Why would they remove the function that was there in earlier model?
10-04-2014, 04:57 PM | #188 |
Rep 3,990
BMW does a lot of stupid things like this, lol. Audis and Mercs have power fold mirror option with the keyfob selectable in their vehicle menu (it's a default setting). For us, we have to CODE this, and it's the same deal with the power windows and comfort access.
10-04-2014, 08:48 PM | #189 |
Rep 11
HUD position
I am sure I have seen somewhere there is a coding option for this, but dont see it in the F15 cheatsheet or the OP.
My problem is that the HUD display is too far to the left and if I move my head a little to the left it starts to disappear... I would like to try and position it further to the right. |
10-04-2014, 09:08 PM | #190 | |
Rep 3,990
10-05-2014, 06:06 PM | #191 |
Rep 206
10-05-2014, 10:15 PM | #192 |
Rep 1,746
Hi,
Do I need the full or lite of the software? PSdZDATA v.53.5_PSdZData_Lite or PSdZDATA v.53.5_PSdZData_Full Seller says "for general coding you only need the Lite files … for flashing modules, you need the Full version" I guess we are not flashing modules, right? Because that thing is like 30GB vs lite only 5GB.
10-05-2014, 10:20 PM | #193 | |
Rep 40,774
Who is the seller? You should not be paying for coding files, only the Token solution and ENET Cable.
10-05-2014, 10:22 PM | #194 | |
Rep 1,746
Thanks for confirming Lite is all we will need.
10-05-2014, 10:25 PM | #195 |
Rep 3,990
Yep, as Shawn said, you only need the Lite version.
10-06-2014, 08:24 AM | #196 |
Rep 529
Sorry if this was discussed previously but is there anyway to code to have electronic speedometer in the center display (e.g., XX mph that is clearly visible - ie bigger font) OR do I need the digital cluster?
Thanks |
10-06-2014, 08:30 AM | #197 | |
Rep 3,990
Show Speed on instrument cluster via switching BC button: Dekombi > 3000 > BC_DIGITAL_V > change from nicht_aktiv to aktiv You do not need to have the 6WB cluster for this. However, there is no way to have it appear in larger font anywhere else. For a big number display, the 6WB shows it only in Sport Mode. No other cluster can do this. Here's a general video of where the BC_DIGITAL_V coding appears: The BC Digital Velocity is also shown here in my 6WB cluster (enabled by default).
10-06-2014, 10:47 AM | #198 |
Rep 193
Opasha
Want to buy token and tried to send message to guy which you mentioned in your initial message but somehow something wrong with e-mail. Could you please tell me what is wrong??? |
