      02-22-2018, 09:51 PM   #177
Originally Posted by nocbrute2345 View Post
Can someone link me to a video or pics guide to installing RaceChip GTS for the f15 5.0?
0Pasha's post's pictures have been removed/expired by the hosting site, i just ordered a racechip online.
With the pink wire and the stock # he provided
(thanks ! 0pasha)
edit:
i saw your PDF for the x5m and x6m, is there one for f15 5.0? (@r33_rhsport)
It is the same location.
PM for Everyday DEALS!!
      02-26-2018, 07:56 PM   #178
nocbrute2345
Drives: 2017 X6M 2014 M6GC Comp
thanks for the replies
one more question
in your PDF it says to remove the air box..
for the last step, where its plugged into the dummy end and you turn on the engine, at that point in time the air filters have to be reconnected right?
also, the cars battery should be disconnected at the start, and that's underneath the rear trunk? is there any wrench usage there?
I don't have the proper tools since I am away from home so I am going to purchase/rent them.
      02-26-2018, 10:15 PM   #179
one more question
Of course you have to plug everything back on before you start the engine.
Unless you want to see a christmas light on the dash.
The battery is in the trunk under the cover. I believe all held either by torx screw or 8mm screw.
You have to check it, I don't remember since it has been a while and I don't have my X5 anymore.
      03-22-2018, 02:01 PM   #180
nocbrute2345
i plugged the harness with dummy cable, didnt get any malfunction.
connected the chip, black ultimate GTS and the default settings were 5.. i left it on, so far i feel a minimal throttle difference and i can hear the gear shift louder and smoother than the typical 0-60 sprint to jerking down to xmph.
secondly the power seems more linear.. as in when you let go of the pedal it doesnt just drop off sporadically.
i expected more, but this is literally the first 5miles so i cant give a verdict yet.
      03-22-2018, 02:47 PM   #181
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Ok. Go to a higher setting.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      03-24-2018, 12:34 AM   #182
nocbrute2345
thanks for the reply
i have a question i am a little confused
when i use dummy plug on stock i dont get any issues.
Once i connect the chip i get a check engine light, i have tried setting 4/5 and 1. Now when it default starts with ignition it selects 3. Why do i keep getting CEL when i clear codes and start the car?
Should i try deactivating the battery and then plugging the chip and starting after clearing CEL?
      03-24-2018, 01:12 AM   #183
nocbrute2345
i think the mechanic may have connected it to the MAP sensor instead of TMAP
edit :
i am a retard for not realizing this sooner. anyone wanna draw on the picture where the TMap sensor is? i know its behind the reservoir but i am illiterate and pictures help.
      03-24-2018, 06:37 AM   #184
Rotzy
Rotzy's Avatar
Drives: 2016 F15, 2015 F83
You are not the first to make that mistake. Install instructions, with pictures, are here:
http://f15.bimmerpost.com/forums/sho....php?t=1241984
They are for a S63TU, but the intercoolers and sensors are in the same place. You can thank r33_RGSport for creating that for us.
Also, this photo posted above clearly shows where the correct sensors are. I know it's not the exact same engine layout as yours, but again, the sensors are in the same location. The airbox absolutely has to be removed to access them.
Edit:
Oops, I see you already have the instructions. I don't understand how you could use the wrong sensors if you followed the instructions.
2016 F15 X5 50i M-Sport
2015 F83 M4
      03-24-2018, 02:55 PM   #185
nocbrute2345
the tmap sensor is under the silver bar?
i am having a hard time locating it.
      03-24-2018, 04:08 PM   #186
Rotzy
Rotzy's Avatar
Yes, remove the bar and you should be able to get a hand down to each sensor. There is one on each intercooler, which are the aluminum rectangular boxes located behind the bar.
2015 F83 M4
      03-24-2018, 06:36 PM   #187
nocbrute2345
i installed it with the yellow circle harness to the tmap
and the red circled to the air hose intake
see pics
i got drive malfunction error at startup while connected to the dummy plug.
      03-25-2018, 10:14 AM   #188
Rotzy
Rotzy's Avatar
nocbrute2345 How did you make out with the install?
2015 F83 M4
      03-25-2018, 11:13 AM   #189
nocbrute2345 , I can't see your images.
Here is the image of N63tu engine and I circled the sensors that you need to connec the harness to.
As I mentioned again yesterday, if you still unable to do it, hire a proper knowledgeable mechanic or you are going to damage the RaceChip unit and /or your car.
