      03-20-2016, 01:25 AM   #2201
MTornberg
Drives: BMW G11 LCI 740 d M-Sport xD
Originally Posted by shawnsheridan
Originally Posted by MTornberg View Post
Shawn, no thoughts on my problem?
VO Code PMA2 (right -click on ECU itself, not CAFD, and select Code, not Code FDL) to reset it.
I've tried that already. I'm thinking the F025 codes arent 100% correct for my F15?
      03-20-2016, 03:22 AM   #2202
Hideada
Hideada's Avatar
Japan
23
Drives: BMW X5(G05) 2019
2019 BMW X5  [0.00]
I was successful Traffic jam assist in the retrofit by the calibration.
It is very favorite feature.
Thanks for all.
      03-20-2016, 07:27 PM   #2203
VegasPOD
VegasPOD's Avatar
Drives: 2014 X35 M-Sport
Shawn, THANKS! Feels like a new Bimmer with all the coding options.
      03-20-2016, 07:37 PM   #2204
shawnsheridan
shawnsheridan's Avatar
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      03-23-2016, 12:38 PM   #2205
Maxs1234
Member
Maxs1234's Avatar
Drives: 2014 X5 M-Sport
Trying to code f15
Hi everyone,
Is it possible to get the latest esys download file, PSdZData and token generator for esys?
Also, I had the car coded before, any coding that I will do to it now, will it get wiped ? Trying to get the turn signals not to check for burnt bulbs because I have custom led turn signals.
Thank you so much.
      03-23-2016, 02:37 PM   #2206
Doanster
Doanster's Avatar
627
@shawnsheridan will PM you with software info.
To answer your question, no previous coding will get erased unless you VO-code the car, which you're not doing. You're only FDL-coding for the LED bulb error check.
      03-23-2016, 02:38 PM   #2207
Maxs1234
Member
Maxs1234's Avatar
Thank you so much for the quick reply. Do you know when he will PM me ?
      03-23-2016, 04:13 PM   #2208
shawnsheridan
Originally Posted by Maxs1234 View Post
Hi everyone,
Thank you so much.
PM sent.
Now.
      03-23-2016, 04:25 PM   #2209
Maxs1234
Member
Maxs1234's Avatar
Thank you ! Will let you know how it works out!
      03-23-2016, 08:04 PM   #2210
Nkbm82
Nkbm82's Avatar
74
Drives: 2018 BMW 750i
Hi Shawn,
At your convenience can you please send me the files needed for coding?
Thank You!
      03-23-2016, 08:05 PM   #2211
Nkbm82
Nkbm82's Avatar
74
Also if anyone knows of someone whether its a shop or an individual that can do coding in Orange County please let me know. I just got my x5 back from the dealer and all my coding has been erased. I have the cable I bought from Ben but honestly I'm scared to try it on my own for fear of messing something up!
      03-23-2016, 08:24 PM   #2212
shawnsheridan
Originally Posted by scnick82 View Post
Hi Shawn,
Thank You!
PM sent.
      03-23-2016, 09:12 PM   #2213
Neuera09
Drives: 2016 X5 Xline with MPPK
I know the feeling bro, but honestly if you follow the step by step instructions and don't get ahead of yourself, you'll be alright. Look at the cheat sheet and code the simple deactivation of the iDrive warning message. After decoding one, disconnect and check your work. Give yourself an hour and slowly do it with NO distractions. Then try it again and again until you're comfortable.
If money is not an issue, drive up to Northern California and I'll hook you up! I only charge 1 bottle of IPA beer per module. Lol.
      03-23-2016, 09:42 PM   #2214
Nkbm82
Nkbm82's Avatar
74
Lol thanks for the encouragement man. Going to give it a shot! When I lived in San Diego I had a coding guy. He's no longer in business or I'd make a weekend of it and drive down
      03-23-2016, 09:48 PM   #2215
Neuera09
you'll be fine bro, you'll see. I'm about to restore my FA to factory since Im having my MPPK installed first thing Saturday morning. Got a great deal from an Orange County dealer.
      03-23-2016, 11:40 PM   #2216
Nkbm82
Nkbm82's Avatar
74
So I tried it and all I could get to work was closing the tailgate via the fob and door button.
The usb video plays but I get the warning once the car is in motion. I couldn't find most of the modules on the cheat sheet, like even the names are missing. I don't have the following modules:
HU_NBT 3000 I don't have API_USB_VIDEO and it also wouldn't let me change the werte for the Speedlock min/max to FF.
KAFAS2
PMA3
ICAM
I can't access BDC_BODY at all.
Is this because maybe they just installed new software today and things have changed?
Below are some of the errors I received. Any help is greatly appreciated!
Thanks in advance!
Transaktions-Report: Aktion: Codierdaten lesen
CAFD_000017BE_042_100_009 Fehler:
CPS read from ECU "ECUId:BDC_BODY_0x40" failed! [C070]
openECUConnection for link BDC_BODY_40_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name BDC_BODY_40_ETHERNET doesn't map to an item [1694]
CAFD_000013D8_003_003_001 Fehler:
CPS read from ECU "ECUId:ICM_0x1C" failed! [C070]
negative response error:
code: TIMEOUT P2/T2 occurred
description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: ICM_1C_ETHERNET
severity: ERROR
[2130765072]
CAFD_00000069_010_002_012 Fehler:
CPS read from ECU "ECUId:KOMBI_0x60" failed! [C070]
description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: KOMBI_60_ETHERNET
severity: ERROR
[2130765072]
      03-23-2016, 11:44 PM   #2217
Nkbm82
Nkbm82's Avatar
74
Here are all the folders I have:
      03-23-2016, 11:49 PM   #2218
Neuera09
What version of Esys do u have?
KAFAS2
PMA3
ICAM
Thanks in advance!
severity: ERROR
[2130765072]
severity: ERROR
[2130765072]
      03-23-2016, 11:56 PM   #2219
Nkbm82
Nkbm82's Avatar
74
      03-23-2016, 11:58 PM   #2220
Neuera09
Was your car running while u were coding? If not, were probably disconnected.
      03-24-2016, 12:03 AM   #2221
Nkbm82
Nkbm82's Avatar
74
Ill try again in a bit with it running, thanks!
Would the car not being on also explain the missing folders?
      03-24-2016, 12:09 AM   #2222
Neuera09
I'm not sure. Are your surround view cameras working?
