10-07-2014, 12:00 AM | #221 |
Rep 208
Since many members keep asking on the forums and through PMs, I thought I would create this since we don't have a coding section. Feel free to add your coding information and cheat sheets here so we can at least have a coding thread/discussion in one place. If I forget anything or need to correct anything, just let me know .
References:
Coding prerequisites:
What if I have Mac? Running ESYS on Mac through Windows Virtualization because ESYS is a Windows platform only (thanks @wdimagineer, @Hang0ver, @MattBianco):
Remote support for coding:
EST Token and password: This is the .est file. Sometimes it comes with a .jar file depending - this is explained in the coding guide. Get the token from f x x t o k e n m a s t e r (at) gmail (dot) com (there's no spaces between anything, I just put that there because no emails are allowed in forums and replace @ and .). He will give you a choice between 1-3 year tokens. He knows a lot so just ask him what's best for you. (I'm not sure if I need to remove that email, but if so I will; just look up token master and you'll see many posts by him in bimmerfest and his email). Coding cheat sheet(credits to @r33): https://docs.google.com/spreadsheets...9s4/edit#gid=0 Initialization and Connection:
Coding Steps (Always do VO coding first and then FDL coding because VO coding overwrites FDL coded values. Scroll down for VO coding.): 1. Connect to car if you haven't done already. 2. Select "Expert Mode" on the left pane and click on "Coding" button. 3. In Vehicle Order Box (upper left), click on "Read" button., it would display FA of your car. 4. Right click on it and "Activate FA". You will see a green active text next to FA. Also FP will open on the right side. 5. Go to SVT Actual Box (right pane, midway down) and click on "Read ECU" button. 6. SVT box will display SVT of different modules of your car, some with green bullets. These green CAFD files are of our interest. 7. To make sure you don't mess up with other files, you can filter for CAFD files in the right bottom most SVT Filter dropdown selection box (this is optional and for your comfort). 8. Right click on required green CAFD and click on "Read Coding data". After codes are read, green icon will change into a folder icon. 9. Check the folder "C:\ESysData\CAF", this will contain all the read CAFD files. 10. Copy and Save all the files in a safe place. These are your original CAFD files. 11. Expand the folder of any read CAFD of a module that you would like to edit with the changes as shown on the cheat file. 12. Right click on the CAFD file and click "Edit FDL". Enter the pin if asked. 13. Open the module you wanted to edit, click on the Functionen folder, ausgelessen folder of the selected function will show the current settings. 14. Change them as per Cheat Sheet and Save. You can use the search box above to find the right function. Always search by selecting the required module (i.e., 3000 or 3001, etc). Search function works top down from selection point and if you search by selecting a function in the middle, all the functions above it in the same module will be ignored as the search is top down. 15. To be on the safer side, edit only one module at a time. 16. After making all changes in the module as per the cheat sheet for that function, save and go back by pressing top extreme left green arrow "back" button. 17. Select the edited CAFD file on SVT box and Click on "Code FDL" in coding box on right. 18. Coding process will start and should end with no errors. 19. Great, you coded one module. Disconnect E-Sys by clicking on top Connect button which is showing a red x. You are done. 20. Test the car for the changed feature. Some features require 15 -30 minutes to get activated where as some are instant and few need you to switch off the and lock the car and unlock and start. Quick tips:
VO Coding: VO Coding is permanent coding. We use this for things like adding or removing FA codes (eg: 6WB (digital display instrument cluster), 5AP, and 8S4 (LED lighting for anti-dazzle). Here is a PDF on how to VO code: http://www.4shared.com/office/pKbWJC..._MWPos__8.html. ALWAYS do VO CODING first before doing any FDL coding because it will change everything back to factory settings for whichever folder you have VO Coded. One correction in the PDF for F15 is in the last page. Instead of Read SVT, you need to Read ECU. If you read SVT, you will get an error. Clear All DTCs/Error codes through ESYS:
Always make sure you do this carefully. Don't ever CODE a whole folder because it might code default settings of the F25 target. This is only for VO coding. Only CODE FDL for each CAFD that you edit. If you have any questions down the road, feel free to PM me . I know it's quite a bit of reading, but don't let it intimidate you in the slightest. It's very straightforward. However, there's no such thing as a stupid question when it comes to this sorta stuff, so don't hesitate to ask. Good luck . CODING that may NOT be in @r33's cheat sheet: if you guys have/find more, just PM me or add to this thread and I will edit the OP page for these codes. 1. Anti-Dazzle LED Lighting (thank you @skalberti and @shawnsheridan - I also did some of my own reading to better explain the FLA module): Remove 5AP and 8S4 from the FA and CODE (right click the folder and select code) KAFAS2 or FLA3, BDC_BODY, LHM, and TMS. If you don't have the KAFAS2 folder under ECU in ESYS, that means you do not have the KAFAS camera but most likely you have the HBA stand-alone camera below your rear view mirror if you have LED Lighting Package. KAFAS2 folder is usually present in vehicles with Lane Assist Package. If this is the case, you must CODE FLA3 folder instead. For the full description, refer to post #107: http://f15.bimmerpost.com/forums/sho...&postcount=107. We have discussed the features from post 107-112 (pages 5-6) of this thread. Thank you to @shawnsheridan and @Hang0ver for bringing this to my attention . Bi-Xenon has the capability for HBA (if you have it) and Visual Light Distribution. You can read about this as well in posts 107-112. Videos of Anti-Dazzle LED Lighting (thank you @Catflap): a) https://www.dropbox.com/s/efyfe742hf...D%27s.mp4?dl=0 b) https://www.dropbox.com/s/ct88fwnowu...s%202.mp4?dl=0 2. Stop Flickering of Custom LED Turn Signal Bulbs: This flickering occurs for the Bi-Xenon headlight turn signals when you first start up your vehicle and may resume every 2-3 minutes depending. The vehicle is checking for burnt bulbs. To turn this test off, you simply change these 6 values (3 for each light) in BDC_Body (tip: search "fra" and you will find all of these easily in Esys within BDC_Body folder):
3. Driver/Passenger Seat Belt Coding (thank you @shawnsheridan): This disables the classic annoying BMW chime when you don't put your seat belt on for both driver and passenger and also removes the little red guy and warning message in the instrument cluster. There are 7 total located in ACSM>3000. 2-4 of the last ones might be in3001 or 3002 in folder that deals with SeatBelt; just check by searching "SBR" and "SPW" because it's been a while since I coded these:
4. Auto Start Stop OFF by Default in Comfort Mode: Comfort mode should remember your last setting when you turn off your car, but I hate this feature (especially after reading a while back how it may create more wear and tear on the engine in city driving with lots of lights/stop signs). I also don't use it in Eco-Pro but this code won't turn it off in Eco-Pro mode because it's supposed to maximize fuel efficiency by turning off the engine. It is located in BDC_Body>3026: TC_MSA_DEFAULT_OFF: nicht_aktiv to aktiv 5. Cell Phone Ringtone Plays Through Car Bluetooth Upon Receiving Call: pretty self-explanatory. This is located in HU_NBT>3001. INBAND_RINGING: nicht_aktiv to aktiv / Werte=01 6. Enhanced Bluetooth (thank you @skalberti for 6-12): For EBT enhanced Bluetooth, first unpair and delete all bluetooth connections. Then simply add 6NS to your VO and then VO code HU_NBT, you do not need to remove anything from the VO first. Now go to Options-scroll down-Configure bluetooth, and tick Telephone 2 and Office. Now pair devices. If you are pairing 2 phones, the first one should be selected as Telephone 1 during pairing and the second one needs to be selected as Telephone 2 for both phones to work at same time. 7. Rain Light Sensor Reduced Sensitivity: BDC_BODY > 3130 Pf RainLightSensor, 0C > RLS_DEF_FLC_SCHWELLWERT_SATZ > change standard to unempfindlich 8. Dimming Side View Mirrors:
9. TLC Coding for Road Edge Detection: KAFAS > 3020 TLC Coding 0B >ROAD_EDGE_WARNING_ENABLED > change DISABLED to DETECTION_FOR_GRASS_EDGE_AND_CURB_STONE 10. Changing the # of Turn Signal Blinks: This is for the light tap when you hit the indicator. The default # is 3 blinks (werte = 02). # of blinks = werte value + 1. So, if you want 5 blinks, werte = 04. LceMaster > 3068 > BLINKZYKLEN_ANZAHL_TIPP > Werte = (your desired amount, default is 02 (3 blinks)) 11. Emergency Stop Signal/Flashing Brakes: This is when your rear brake lights flashing during a sudden emergency braking (this needs to be tested, not sure if we have the bulbs to make this work). To test, slam on your brakes driving about 50mph, preferably with someone behind you that knows what you're about to do. If you don't get a check bulb error on your dash this should work. LceMaster > 3068 > ESS_AKTIVIERBARER_AUSGANG > bremslicht blinkend 12. FLA Active When Headlights Manually On: This turns on your FLA not only in the auto light setting, but also when you manually turn the headlights on. LceMaster > 3068 > FLA_AKTIVIERUNG > change "LDS in A" to "LDS in A or 2" Last edited by Hang0ver; 10-07-2014 at 06:02 AM.. |
10-07-2014, 12:02 AM | #222 |
Rep 1,746
Ah man, at least they should have enabled that. Oh well it means I am going to have to keep pressing sport every single time. That button will wear fast.
Make a video!
10-07-2014, 12:39 AM | #223 | |
Rep 3,990
@Hang0ver, thank you very much for taking the time to organize that and adding the coding steps I had explained to you in person - it definitely makes things easier for people to understand. There are some important points that need fixing like the FA Activation (this should be done right after you READ FA at the beginning). You listed it much later in your steps for some reason - if you don't activate it, your changes may not apply/save correctly. Edit that and please leave spaces between the coding list so people don't get confused when reading them. Also leave the references near the top because those are the most important for starting coding and seeking coding help. I'm happy to update my coding OP with your adjusted organization, but I can't copy the whole thing because the numbers become like this[*] so that's why I didn't want to do that without making sure everything was corrected by you. I would have edited it myself and applied and rearranged everything as I needed, but if anything got screwed up in the paste, I would lose my original OP information. I read through your additions a few times in comparison to mine and everything seems good aside from those few points I mentioned. Thanks, buddy .
I was thinking about this. If I have time, I might do it after I VO Code my BDC_Body, etc. for my M-Sport steering wheel. This way I can show some of the BDC_Body coding. Should I do a screen video or should I make a live video with my G16 as I comment and explain the coding. Is there a program that let's you do a full screen capture video while allowing you to record your voice? That would be more helpful.
10-07-2014, 12:52 AM | #224 |
Rep 1,746
Back in the day, Cam Studio was the easiest to use and lightest software for screen capture & commenting but I just checked around it looks like it comes with adware bundled, you can still safely install it but you have to make sure you are not tricked into clicking & installing the adware that's bundled. Otherwise I am sure there are many better options out there.
I checked Alternative.To and this came in as the best alternative: http://alternativeto.net/software/camtasia-studio/
10-07-2014, 12:55 AM | #225 |
Rep 1,746
It looks amazing, makes the whole process look a lot easier. Opasha's information and your formatting =
10-07-2014, 12:55 AM | #226 | |
Rep 3,990
EDIT: I just checked and my Snagit! program has everything I need. Awesome. I'll definitely make a video of everything and add it to the OP when I get a chance.
10-07-2014, 06:08 AM | #227 | |
Rep 208
Regarding Read FA, you don't mandatorily need to Activate it before. You can activate it later too. If you don't activate it and try to code, it will just ask you to activate. Even the step by step guide listed is it in the later time to activate. I moved it to the top where we do it after Read. Either way it works fine. So we should be good Thanks for your suggestions, I made the edits in that post. For your convenience, I am attaching the post content in the reply. Edit your OP and once you paste content in attached sheet to the reply box, click Preview Post and make sure everything is aligned correctly. Once you are satisfied, you can save changes. I am also thinking, may be we should add the coding in OP also to @r33 sheet so make it a one stop shop for everything. Thoughts? We might need use seperate sheets for FDL and VO coding to make it easier. Thanks for considering my changes |
10-07-2014, 06:15 AM | #228 | |
Rep 208
10-07-2014, 06:27 AM | #229 | |
Rep 3,990
Regarding the extra coding - I had already told Ben that I would input the coding list in the OP into his cheat sheet when I get around to it . Yeah, we will definitely have to separate the VO Coding from the FDL coding or else it will confuse people and they might mess something up by mistake. I'm going to edit and include this into the OP right now. Again, thank you for your help and time. You have a good memory as well . Almost every step I remember explaining to you in person, you wrote down in the coding steps. Thanks for the video post. I found two perfect tools to record my screen with commentary. Do you think I should still bother with a video for our F15 then?
10-07-2014, 06:31 AM | #230 |
Rep 3,990
Yeah, so I just watched it. I don't mean to be negative, but this video isn't very good. I'll make one that is more straightforward and easier to understand so that no one gets confused. Plus, it will be only for our F15. Thanks for trying to find one though .
10-07-2014, 06:33 AM | #231 | |
Rep 208
I don't think we need to hurry on the video. But making one for F15 makes people feel better because the video I posted has E-sys is different language. Also a PDF with screenshot would be better than video like we already have for VO coding. I personally feel convenient using PDF instead of video because, they can flip pages instead of going through video and finding where it is. When I did the VLD VO coding, I lost some FDL that I did in KAFAS2. I can put together that PDF with screenshots if you want |
10-07-2014, 06:34 AM | #232 |
Rep 208
Agreed.. the video is not perfect and makes it difficult because of diff language...
10-07-2014, 06:39 AM | #233 | |
Rep 3,990
10-07-2014, 06:53 AM | #234 | |
Rep 208
10-07-2014, 08:06 AM | #235 |
Rep 3,990
Thanks, buddy. I updated the OP .
10-07-2014, 08:34 AM | #236 | |
Rep 193
Indeed it this video there are some things which I think not applicable for f15(for example read ECU(not VCM) and use Istufe(not VCM parameters) during log in. Thank you very much guys!!! It is really helpful what you are posting!!! I already started process of coding and it easy to understand how it has to be done!!! |
10-07-2014, 09:05 AM | #237 | |
Rep 578
can't wait to watch your video opasha!!! |
10-07-2014, 09:58 AM | #239 |
Rep 156
well guys i have never code but i find this video and i think it have the steps you wrote, and its from tokenmaster maybe helps.
www.youtube.com/watch?v=pPhZ7kep1aY |
10-07-2014, 12:22 PM | #240 | |
Rep 40,789
The PSdZData version used must be >= to the last version of ISTA/P used to program the car. If you use the latest PSdZData, then you don't have to worry about it. Otherwise, you will need to read I-Step Current from VCM, cross-reference it to the ISTA/P version, and determine if your PSdZData version is >= to it. To determine I-Step Current: http://f30.bimmerpost.com/forums/sho...postcount=1403
10-07-2014, 01:18 PM | #241 | |
Rep 208
10-07-2014, 02:28 PM | #242 | |
Rep 3,990
