09-13-2015, 08:18 AM | #133 | |
Rep 25
09-13-2015, 10:19 AM | #134 | |
Rep 5,066
09-22-2015, 03:18 PM | #136 | |
Rep 7
VW Diesel Fiasco...
09-22-2015, 03:47 PM | #137 |
Rep 30
I had a smog check on my 2008 chevy silverado about a year ago. It was the first smog check since new. It was all done via the OBD II port. The tech told me that tail pipe testing is no longer required on vehicles model year 2000 and later. The smog check took about ten minutes. This was in California. So, as long as the chip is not throwing CEL, it should be fine.
09-22-2015, 11:29 PM | #138 | |
Rep 18,715
Too many variable to be able to have your car to show the advertised up to 5 MPG increase (you need to change the dial to an economy setting). Unless if you can constantly run your car for about 1/4 tank on the same condition, it would be a very hard question to answer. Edit: correction on the advertised MPG increase.
09-24-2015, 10:28 PM | #139 |
266
Rep 345
Drives: 2019 X5 40i M
I am still running at 03 without issue and could not be more pleased with the performance.
2019 X5 X40iM
09-25-2015, 10:33 AM | #140 |
Rep 25
Nice to hear, it sounds like the 15's are able to handle modding a little better than the 14s. On a side note how did you go about blacking out the trim around the window?
10-26-2015, 01:38 PM | #141 |
Rep 137
Hi All,
I just tried racechip ultimate on my 35D, the throttle response improvement can be felt right away. The increase in performance is not dramatic, but definitely can be felt. I would say it improves the drivability in comfort mode the most. Before it felt sluggish in comfort mode. However I do find the engine sounding not as smooth as stock. The diesel clatter is much more pronounced. I'm at default E0 setting. Has anyone found a setting that gives performance gain but still close to factory smoothness? That may be too much to ask, but just thought I'd check. I have not tried other settings yet. |
10-26-2015, 02:36 PM | #142 |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
+1
....Life is too short to drive boring cars
12-02-2015, 02:04 PM | #144 |
Rep 52
Guys, I'm currently considering buying RC Ultimate for my 40d. Keeping in mind that the engine construction is nearly identical to 30d/35d I'm wondering if it would be safe to boots the hp and torque by approx. 15% as that would be close to 50d spec (which has better engine components). I don't want to invest in a Dinan program because I would still like to disconnect the chip before visiting the dealer of undergoing state technical control so the piggy back solution seems just what I'm looking for. Has anyone had any experience with tuning 40d and recommend the safe settings so that my engine wouldn't explode?
01-21-2016, 02:03 PM | #145 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
Hey Opplock1 how is it going
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
01-26-2016, 08:16 PM | #147 | |
Rep 18,715
And most of the users ended up forgetting the fuel savings since it gives you much more enjoyment of driving. If you are looking into gas savings, you don't need a RaceChip, there are plenty of tricks to gain mpg. Such as; higher tire pressure, reduce the car weight, run on eco mode all the time, etc.
02-11-2016, 04:56 PM | #148 |
Rep 137
I do notice a 1 -2 MPG improvement with the racechip ultimate, at least in E0 factory setting. Also different brand of fuel feels different. Chevron #2 feels a bit more powerful compared to Shell, although a bit louder.
