Go Back   BMW X5 and X6 Forum (F15/F16) > BMW X5 (F15) and BMW X6 (F16) Forum > BMW X5M (F85) and X6M (F86) Forum
      01-03-2017, 03:46 PM   #23
atxgt3
156
Drives: 11 E92, 17 X5M, 15 Huracan
How much power is added with stage 2 + intake at the lower RPMs compared to stage 1? That's where I feel the X5M is really sluggish, even with Stage 1. In daily driving, that's where I feel like I need more power, because the transmissions likes to keep the RPMs low.
Also, if I already have the stage 2, will I need to change the Dinantronics box?
      01-03-2017, 03:54 PM   #24
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
The large power gains with stage 2 are above 5000 RPM but below that there is a consistent 10-15 HP and about 20 TRQ increase over stage 1. You can compare the 2 graphs directly on the website and the product pages if desired.
      01-04-2017, 10:33 AM   #25
scotty91ss
182
Drives: 19 M5, '15 X5M,'91Chev454ss
Is it possible for you to supply the shipping weight and dimensions of the box?
Thanks
      01-04-2017, 12:11 PM   #26
Dinan_Engineering
Drives: Any BMW
Thanks
30x20x12 - 11#
      01-04-2017, 05:49 PM   #27
tastelid
tastelid's Avatar
166
Drives: 2016 X5M
so a stock vehicle would need the intake + stage 2? no need to buy stage 1 and then stage 2, it's just a different version of software/mapping on the tuner device?
Cars: 2016 BMW X5M. 2017 BMW X1.
Bikes: 2007 BMW F650GS. 2014 BMW K1600GTL Exclusive. 2014 BMW HP4 Competition. 2016 BMW K1300S.
      01-04-2017, 05:55 PM   #28
Dinan_Engineering
Drives: Any BMW
Correct. If you had stage 1 you could update your existing box to stage 2 for the cost difference between stages.
      01-04-2017, 06:47 PM   #29
Sotally Tober
Drives: 2017 X5M
Intake and Stage 2 bought! Thanks Ben at RG Sport Shop!
r33_RGSport12971.00
      01-06-2017, 11:07 AM   #30
04cobra
633
Drives: 2015 M3 - 6MT
I wish you guys would measure your HP gains at the wheels rather than crank. Just seems to inflate the actual gains you are getting when measured at the crank. Obviously a 15% gain sounds better than a 5% gain though.
      01-06-2017, 11:27 AM   #31
Supadice
Supadice's Avatar
1028
Drives: 2020 M2CS
holy bananas Batman
      01-06-2017, 12:10 PM   #32
Fugly M3
Fugly M3's Avatar
5077
Drives: 2023 M3CX
Wow.
      01-06-2017, 02:52 PM   #33
MGF80
MGF80's Avatar
Drives: Skyscraper Grey G80
Here are some real world photos!
Appreciate 7
///Mobbin1478.00
TheQ4.00
Alan l.5453.00
N54MPower283.50
      01-06-2017, 03:43 PM   #34
Presario
Presario's Avatar
Drives: 2018 X3 M40i, 2016 435 GC
Dinan measures the HP and torque of the stock car on their engine dyno (crank) as baseline as well so their % gains are calculated correctly. The delta, whether you're measuring it at the crank or wheels, sound be the same and not inflated as long as you're comparing both wheel or crank numbers.
F36 435i * MINERAL GREY * ///M Performance | G01 X3 * PHYTONIC BLUE * ///M40i
      01-06-2017, 04:49 PM   #35
trev230
trev230's Avatar
351
Drives: 2022 M5C
Just ordered! Thanks Ben at RG Sport Shop
r33_RGSport12971.00
      01-06-2017, 06:18 PM   #36
Zebra99
Zebra99's Avatar
Drives: 2011 335is E93
Complete waste of money lol. Yes the hardware they make is nice, but nowhere worth what they charge.
And many tuners can hit 700hp just on a stage 1 flash tune without bolt-ons. I don't know why ppl throw away their money at Dinan
      01-06-2017, 06:31 PM   #37
raysspl
raysspl's Avatar
992
Drives: walking, bicycle, & bus
That's so boss!
re
      01-06-2017, 07:52 PM   #38
Eggplant
Drives: 2014 X5 50i 2018 M3
Now to wait on someone to test fit it on a 50i
2014 X5 50i
2018 M3 Indv.
      01-06-2017, 08:03 PM   #39
I believe it should fit with no problem.
PM for Everyday DEALS!!
      01-06-2017, 10:55 PM   #40
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Originally Posted by Dinan_Engineering View Post
Its not as easy as just adding the numbers together. Peak gains and max gains don't always occur at the same RPM. In this case Peak numbers occurs at ~6000 RPM. Max HP gain over stock is also at that location. However the max HP gain over stage 1 (whats quoted) occurs in the 4000-4250 RPM range.
Stage 2 does not require the intake or the exhaust technically but if you want to get the quoted power gains you would want the intake and tune. The exahust for all practical purposes is just a sound improvement. The power gained from it is all at the upper part of the RPM register. Would work for all exhausts as well, no matter the brand, and not need any specific adjustments. The exception would be if the exhaust removed the CAT's in which case it would result in a CEL which the system does not correct for (emissions legality) nor optimize for.
The aim with the turbo engines with all successive stages is to "flip the tip" of the upper HP curve so that instead of falling off at peak it continues to pull all the way to redline. This usually means having varying amounts at boost at the various loads in order to achieve that.
Do you have any data to show how faster the car can go (1/4 mile or 0-60) compare to the stock car? Can't wait to see the result. I believe it must be about half a second faster
Current : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 - 6MT
Gone : 2016 F82 Austin Yellow M4 - 6MT
Gone : 2013 F13 Sakhir Orange M6 -7DCT
Gone: 2013 F13 Alpine White 650i -ZF8
      01-07-2017, 02:24 AM   #41
Ghostriderf80
United Kingdom
840
Drives: Just a Porsche
Attachment 1549059
Dinan F85 X5M / F86 X6M Carbon Fiber Cold Air Intake
Part Number: D760-0047
Applications: 2015+ F85 X5M SAV, 2015+ F85 X5M SAV
Release Date: Today, December 29th, 2016. Please see note below for details.
Description: 'Striking' is the first word that comes to mind when you pop the hood of a F8x X5M/X6M with a Dinan carbon fiber cold air intake system. The under hood appearance is completely changed and set off by intricate carbon detailing that make the engine compartment just as flattering as the sleek exterior lines the vehicle possesses. While the aesthetics are the most recognizable change to the system what is more impressive is the functionality that lies beneath the carbon fiber lid.
The care that went into the filter design is what makes the system function as well as it does. The stock filters are restrictive with only a minuscule 89in² in total filter area. The stock filters also only allow air to be drawn in from the front and rear instead of around the entire surface area. Dinan's custom filters on the other hand eliminate this wasted area and allow air to be drawn in from all around and increase the total filter area to 292.4in². That's an unheard of 228% increase in filter area over the stock setup. In order to accommodate these massive filters the stock lid needed to be enlarged as much as the hood clearance would allow. This gave us the opportunity to implement it's signature carbon fiber look and appeal while also increasing the overall volume of the air box by ~15%. The increased volume of the air box allows the larger filters to ingest more air at any given moment and elicit a slightly more audible and sporty tone over its stock counterpart. This optimized design yields increased HP/TRQ throughout the power band and shows consistent gains over stage 1 when combined with the stage 2 DINANTRONICS Performance Tuner.
Benefits of the Dinan Carbon Fiber High Flow Air Intake for the BMW F85 X5M and F86 X6M:
  • More Power: Max gains of 23 HP @ 5500 RPM and 25 lb-ft of torque @ 4000 RPM when combined with the Stage 2 DINANTRONICS Performance Tuner and exhaust over stage 1 tuning.
  • Sportier Sound
  • Improved throttle response
  • ~15% Larger volume air box via a Carbon Fiber lid that allows for the spacing needed for the larger filters.
  • 228% increase in filter area (stock: 44.5in² each, Dinan: 146.2in² each)
  • Dinan filters draw air in from all around versus the stock filters which only draw from the front and back of the filter.
  • Bolt-on installation
Please Note: Due to limited production capacity the F85/F86 X5M/X6M carbon fiber cold air intake is highly susceptible to back orders.
After months of production issues instead of delaying launch any further waiting for stock to build up we are releasing the product knowing full well we be in an instant back-order situation. Our estimated back order timeline is 4-6 weeks shortly after launch.
Attachment 1549058
Dinan F85 X5M / F86 X6M DINANTRONICS Stage 2
Part Number: D440-0047-ST2
Product Page - Details /Additional Photos / Pricing: http://www.dinancars.com/product/d44...ries&mid=1241/
Description:The baddest SAV on the market is about to set the bar even higher!
With the release of the cold air intake for the F85/F86 X5M/X6M platform the engine can realize more power by virtue of greater air flow. Particularly effective in the upper RPM range where horsepower and torque typically fall off, stage 2 with the Dinan carbon fiber cold air intake holds the power much more effectively for longer lasting enjoyment. With a bump in power of up to 23 HP and 25 lb-ft of torque over stage 1, the combination sets this versatile vehicle further ahead of its competitors.
Attachment 1549060
I like that DINAN is offered by BMW dealers and is covered under dealer warranty in Canada.
1 - The software is great.
2 - Their exhaust on the M4 at least rattle with broken welds.
3 - Their wheels lack imagination and purpose.
4 - I would be very skeptical about their suspension - you have Ohlin which is as good as it gets.
So for 2k in software and 700 hp with dealer warranty. You can't go wrong. The rest well its up to you if you want to uglify your ride.
      01-07-2017, 12:30 PM   #42
MGF80
MGF80's Avatar
I really don't know why people like you feel the need to come in just to bash on Dinan. Clearly if you are in these forums you are aware of what other tuners can do with different platforms. It's easy to extract a ton of power from these cars without placing a warranty behind it. People choose different tunes for different reasons and I don't know people just can't grasp that simple concept. Thanks for your input though!
Appreciate 6
      01-07-2017, 02:38 PM   #43
Alan l.
Alan l.'s Avatar
5453
It's worth whatever someone is willing to pay for it. Considering nobody else makes an intake for this car I think the price is fair. Look at what some other tuners are charging for intakes for other M cars and this is considered cheap.
I didn't get it for power. I got it for sound and any extra power gained is just a plus.
Alan
r33_RGSport12971.00
      01-07-2017, 03:07 PM   #44
Alan
+1.
Mods is not always about power. It is about vehicle personalization.
Appreciate 4
