      09-26-2021, 07:38 PM   #1
bimmertt
bimmertt's Avatar
93
Drives: 2007 e92 335i
Front diff leaking
Noticed the peculiar smell of diff fluid this morning after driving our 14 x35i. Looked underneath the car and sure enough there's a leak. The car has ~70k miles. I've read some horror stories of people needing their diffs replaced to the tune of 5-7k. Please tell me this is something small and common that can be fixed
      09-27-2021, 10:53 AM   #2
M302_imola
M302_imola's Avatar
843
Drives: '15 X5 35i Xdrive Mineral Whit
I've noticed a few drips in the garage toward the rear lately. Haven't pinpointed if it's the diff or TC yet. Plan on doing fluids for both soon. Hoping it's something as minor as a drain bolt not seating correctly issue.
      09-28-2021, 07:45 PM   #3
bimmertt
bimmertt's Avatar
93
I took off the reinforcement plate and the leak looked pretty bad. I couldn't pinpoint where exactly it was coming from. I haven't driven the car since. Plan on getting it towed to an independent shop
      09-30-2021, 10:40 AM   #4
M302_imola
M302_imola's Avatar
843
Bummer man...sorry about your luck!
      09-30-2021, 11:02 AM   #5
crystalworks
crystalworks's Avatar
522
Drives: Many BMW's
Ugh, bad luck. Degrease the area well, leave the plate off, and take it for a leisurely (that reinforcement plate is there for stiffness of the subframe) drive around your neighborhood for 10-20 minutes. Then check to see if you can locate the leak.
      09-30-2021, 04:32 PM   #6
bimmertt
bimmertt's Avatar
93
Had some time to look a little closer at the leak. Confirmed it's coming from my front diff. Looks like it's leaking right around the driveshaft seal. I drained the fluid and found metal shavings in the oil and on the drain plug, but not chunks of metal. I put in new fluid and will have someone else fix the leak. Anyone know how they would determine whether or not the diff needs to be replaced?
      09-30-2021, 06:48 PM   #7
parthpatel1
Drives: 2015 X5 M Sport
Any idea what would cause something like this?
      10-01-2021, 07:38 AM   #8
JMAN1111
Drives: F86 Black Fire X6M, F16 X6 50i
Mine was leaking also. I had one seal replaced and changed the fluid at my Indy.
      10-03-2021, 08:02 AM   #9
M302_imola
M302_imola's Avatar
843
Care to share approx cost you paid for this repair?
      10-03-2021, 09:34 AM   #10
JMAN1111
It wasn't cheap let me see if I can find the invoice.
I remember the shop had to remove the wheel, caliper rotor, shock support, tie rod and axle to obtain access to the left front seal.
      10-07-2021, 05:44 PM   #11
bimmertt
bimmertt's Avatar
93
It looks like the leak was coming from the pinion seal. Had a shop replace the seal and refill with fluid but I think the damage has already been done. I measured what was drained and about a half quart of oil came out. I think driving with that little oil in the diff messed it up. I still hear a humming sound during acceleration and declaration.There also seems to be a lot of play where the driveshaft connects to the front diff. Does this look normal? https://photos.app.goo.gl/z9JbafGVDe7xjckL9
      10-08-2021, 08:56 AM   #12
crystalworks
522
Drives: Many BMW's
That can't be normal. I was just under ours (2015 X5 35d) and inspected the U-joints on the front driveshaft. I don't remember any play like that on the diff side. Just some in/out play where the shaft enters the transfer case, which is normal I would suspect.
      10-08-2021, 06:43 PM   #13
Gkacmaz
Drives: BMW X5 50i
so I'm one of those unlucky ones who had to get it replaced.....7k....
      10-09-2021, 07:18 PM   #14
JMAN1111
I'm sorry to hear that. That's painful. I think it was like 700-800 to service the diff & replace the seal when I had it done.
      10-09-2021, 07:28 PM   #15
Gkacmaz
Drives: BMW X5 50i
It was too late for my car unfortunately, by the time I noticed the driveshaft had ton of play already. And like you said in your post mine went out around 70k miles
