07-20-2018, 04:03 PM | #596 |
Rep 4
Drives: 2014 BMW X5 50i
07-20-2018, 04:07 PM | #597 |
Rep 1,264
BMW will definetly not change the oil under warranty. And even changing it at your own cost might not sort out the issue you are facing.
I would go to the dealer and ask them to diagnose the problem first. |
07-27-2018, 06:22 PM | #598 |
Rep 1
Charging issue at Home
My new 2018 BMW was charging fine for last 6 months and suddenly it goes to error after some randon time ..say 2 min to any time in 2 hours ? Has any one else seen this issue ..The BMW shop is not able to replicate this ..but I tried many different outlets and this repeats ..
08-03-2018, 01:48 AM | #599 |
Rep 3
Please asking anyone who got the knowledge about the X5 diesel car stop / start funct
I have a 2016 X5 25d F15 model car. At the early of this year, when my wife drove to home it stopped at a traffic lights. it would not re-start again after release the break pedal. Towed to the dealer to check. I have been told the battery supply is not communicated well with the engine. took 5 days in the work shop, then back to work. but the start/stop function was still not working properly as before. most of the time it would not stop now, or 3 days stop and 4 days not stop. whatever in warm or cold of the car. it was the same. no any other appliance used in the same time, such as the heated seat, air conditioning. Battery is fully charged. It's under new the car warranty, but the dealer refused to check it and says it is normal. can any one help?
08-03-2018, 07:00 PM | #600 | |
Rep 177
08-05-2018, 08:06 PM | #601 | |
Rep 3
08-05-2018, 08:29 PM | #602 | |
Retired Curmudgeon
2985
Rep 4,047
Good luck and I hope this helped.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
08-06-2018, 10:21 PM | #603 |
Rep 839
Current problems with my 2018 F15 (14K miles) - I've owned a few F15s.
1. A/C is slow to turn on and not great when the cabin is hot. Common problem 2. Heads up display does not turn on once a month or so. 3. iDrive consistently does not remember last settings - what was on the display or that it was in preset mode. iDrive 6 is a POS 4. Recently something has become loose in the back on larger bumps, sounds like a suspension piece but hard to track down 5. The multi contour comfort seats are, well, not that comfortable. Much better than the ventilated seats but still hard on the butt for longer drives. Wife notices it also. I have a G05 on order but am questioning that and may switch to the Q7 which had one major known problem (brake squeal) that has been fixed. |
08-07-2018, 07:55 PM | #604 | |
Rep 3
Any idea? |
08-08-2018, 11:23 AM | #605 | ||
Rep 177
08-08-2018, 11:24 AM | #606 | ||
Rep 177
08-08-2018, 02:28 PM | #607 |
Rep 2
2015 BMW X5 Steering Issue
Hi Y´all,
I´ve been experiencing a very unresponsive and floaty steering above 40 mph. Doesn't act like any BMW I´ve driven. As a matter of fact, I don´t think I´ve driven a car with such a terrible steering. Above 40mph when I slightly turn the wheel in kind of keeps the steering angle, doesn't move back to neutral, it almost feels like it locks itself.. I don´t know if its normal...... I have an appointment on Monday for a checkup. Adblue: Had to change the nox sensors and adblue injectors Camera: 360°doesnt always show, so they had to do a software update. I´ve purchased the car with 60k miles and these are the problems after having driven it for 5k.... Very disappointing... I own 2 other BMWs and have had luck with them... |
08-10-2018, 11:32 AM | #609 | |
Rep 223
08-15-2018, 01:18 PM | #610 |
Rep 29
New issue started a week ago. When I plug a phone into the USB, it constantly cycles charging/not charging/charging/not charging very fast. Ends up just draining the battery... Will take it in under warranty soon.
08-16-2018, 02:22 AM | #611 |
Rep 188
Try a new cable first - it fixed it for me. The original cable has now failed completely (about 6 months on). Seems BMW is very sensitive to this kind of thing.
RotaryPowered15.00 |
08-29-2018, 06:48 PM | #612 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
Anyone got any problems with the front rotors on 35i?
Mine got warped in a little less than one year and less than 20K km. Got replaced them under the warranty. But the new ones got warped again after a year and 20K km. Dealer refused to replace them again, so I've raised the issue with BMW Canada. I'm not a racer of any kind, I drive pretty conservative. Never took my car to the track. My pads were good for another 17K km, so rotors live twice less than the pads. In Europe they put larger rotors on 35i, so I believe the rotors for North America cars are just too small. But BMW thinks they are just fine and proposed, as a "goodwill" to pay for the rotors and I was supposed to pay for the labor. For me it was not a solution, as I didn't wanted to have that conversation in one year again. So I just went for the MPBK. But I'm a little bit disappointed in BMW now...
Freude am Fahren.
09-07-2018, 10:26 PM | #613 |
Rep 7
Tire pressure fluctuating
Hi,
I bought a 2015 X5 Xdrive351i The tire pressure seems to be fluctuating between 39 & 35. It's low tire pressure when I first start driving it and then the pressure goes up to normal after 20 minutes of driving. Is this normal for tire pressure to fluctuate between 4 psi ? |
09-08-2018, 12:08 PM | #614 | |
Rep 177
09-08-2018, 01:26 PM | #615 | ||||
Rep 7
09-08-2018, 05:59 PM | #616 | |
Freude am Fahren.
835
Rep 1,287
Freude am Fahren.
