10-04-2018, 02:08 PM | #309 |
Rep 3
Hey Ben been following the thread and am picking up my 2018 X5 drive 35i M sport next month. Do you have any Racechip Black GTS with app control in stock or will soon and do you ship to APO? Currently deployed over in Stuttgart Germany.
r33_RGSport12971.00 |
10-04-2018, 02:10 PM | #310 | |
Rep 18,716
And I do ship to APO via USPS. PM me, I can't PM you.
10-14-2018, 03:22 PM | #311 |
Rep 181
Help with the wiring harness connectors
I removed the engine cover, the air filter box, and was able to access the two wiring harness connectors. Is there magic to taking them off? The one on the side doesn't seem to have any locking mechanisms (no moving parts) so do I just yank on it? I pulled very hard on it but it would not move. I tried wiggling it but it would not budge. About the same story with the one behind the air filter housing as well.
10-14-2018, 03:53 PM | #312 | |
Rep 2,194
10-14-2018, 05:00 PM | #313 |
Rep 181
I attached a picture. Can you point me where the tab is and how I move/unlock this tab?
10-14-2018, 06:05 PM | #314 |
Rep 58
Locking tabs
The locking tabs do unlatch, but they tend to stick, and the plug itself tends to stick. I suggest using 6" channellock pliers to gently wiggle the plug to make sure it will slide off.
I got impatient and broke the tab off the MAF sensor, so now it is held in place with two wire ties. Much easier to disconnect next time. :-) I will say, the Race Chip RS is noticeable, especially with a brake-torqued launch. And 100-120 seemed to take significantly less time. Mileage was down while flooring it, so it does seem to be using more juice. Not bad for the price and time invested, though I have to say the person(s) who okayed the instructions should be placed in a bag and beaten with sticks. |
b1st49.50 |
10-14-2018, 06:24 PM | #315 |
Rep 94
they have a direct customer service line that you can call. Im sure that they have a pic or two to show you where things go. With the TT models, A and B go to the TMAP sensors and they are not side specific.
10-15-2018, 01:16 AM | #316 |
Rep 181
So those two tiny plastic tabs on top are supposed to move? They had 0 give! Which one moves... the top one or the bottom one?
Agreed! |
10-17-2018, 01:06 PM | #317 |
Rep 152
Moved Post to correct thread topic post.
Delete this if you can please.
2ND X5 IN 6 MONTHS. LET THE MODS BEGIN AGAIN.
10-21-2018, 01:31 PM | #318 |
Rep 181
I'm giving up on installing this and going to return it. Still can't figure out how to remove it. Response back from Racechip was basically "remove the plug" Will just get the MPPK.
10-21-2018, 02:58 PM | #319 | |
Rep 18,716
Somehow BMW uses a plug that have soft plastic. Whenever you press the tab to unclip, the front end that's holding it in place doesn't lift up. So, instead, use small flat screwdriver or a pick to lift the front end of the plug where the clip is. I hope that help.
10-28-2018, 03:51 AM | #320 |
Rep 158
This is what i got with RC GTS Black w/app control.plus i have the MPerformance +25 HP installed also , that means that i got 400+?
2016 X6 M PACK/MPPK
RACECHIP BLACK GTS RACECHIP XLR |
03-12-2019, 12:12 AM | #321 | ||
Rep 413
03-12-2019, 09:13 AM | #322 |
Rep 18,716
Those looks fine.
duercos201.00 |
03-12-2019, 07:10 PM | #323 |
Rep 413
Thanks Ben! Put it in this morning, only drove 2 miles to work, let's see how it goes
03-29-2019, 05:10 AM | #325 |
Rep 84
CEL
35i gasoline M-Sport (stock setting B/1)
MPPK RaceChip Ultimate I've read many of the posts here about RC settings and would like to get a bit more performance out of the N55, but any setting higher than stock (C or D) throws a CEL in the first 30 miles. I primarily drive in comfort mode but will use sport at times. Would love some guidance from the RC pros out there. |
03-29-2019, 10:47 AM | #326 | |
Rep 2,194
This is another reason to upgrade to the GTS Black, they’re all preset to Eco, Sport, Race modes and change with the click of the app. Does the CEL go away on its own? Did you read the codes? If so, what are they? Miles? New spark plugs?
03-29-2019, 09:54 PM | #327 | |
Rep 84
51k miles 2015 Don't know about the plugs Will pull the CEL when I get home next week. In the past I've just reset it without checking the codes. Thanks for the response! |
03-22-2020, 11:53 AM | #328 |
Rep 536
RCU installed
Just added the RCU to my 2014 35i this morning. Set S2=B which is supposed to be the stock setting. A quick 10 minute run shows a bit more low-end power and lots of new "whooshing" noises. Likley due to the increased boost. I'll give a a few hundred miles before moving to level C.
Thanks to everyone on this thread with the details on the install and settings. |
