03-17-2024, 07:47 AM | #133 |
Rep 11
Drives: bmw xf15
Heyy
Im a new owner of a f15 50i n63tu stock power nothing has been tuned I am wondering is it a good thing to install an oli catch can for this engines Or i am being paranoid and it isnt necessary Also there is a slight noise when i accelerate a little just as i touch the gas pedal the dealer told me it is the transfer case the good news is where i am located the transfer case can be repaired the cost is 500-700€ I am wondering does bmw change transfer case oil and adaptiation as a procedure or just replaces it |
03-17-2024, 05:35 PM | #134 | |
Rep 1,019
Whist checking the PCV, check the actual intake boots and connections, to make sure you are not sucking in outside/unfiltered air. See thread for info. https://f15.bimmerpost.com/forums/sh....php?t=2087286 RE Transfer Case, BMW just replaces them when they fail at full RRP. So either do a DIY, or get a mechanic to do a oil change on the TC w/ adaptation reset straight after. |
besi441.50 |
