09-17-2014, 07:37 AM | #1 |
Rep 525
sport mode vs gear selector sport
so i know we have the sport/comfort/eco switch, as well as being able to shift the gear selector to sport mode or a manual shift mode.
i love the sport suspension, but dont always need the sport tranny. i need to see if there is definition of the sport mode switch vs sport gear selector right now my sport mode is set for suspension and tranny characteristics. if i set that to just suspension can i use the gear selector to enable full sport shift and suspension mode??? is there a difference in using the sport switch with the gear selector in normal vs sport settings? |
09-17-2014, 07:48 AM | #2 | |
Rep 2,664
Drives: Goggomobil
F86 X6///
09-17-2014, 08:10 AM | #3 | |
Rep 525
sport switch Tranny/Suspension and sport gear shifter is like sport +++ sport switch Suspension and sport shifter is like sport++ im asking if having a full sport mode tranny/suspension and the shifter in sport is the same as sport mode suspension and shifter in sport? with no tranny sport selection |
09-17-2014, 08:10 AM | #4 |
Rep 8,808
Not sure about the F15 but in my F10 the full Sport Mode with the toggle switch is still different from the shifter being popped over to the left in S mode. Sport with Drive mode the trans shifts crisp. Sport with S mode (toggle to the left) the trans shifts almost dct quick and the rpms shift points are slightly higher. It def. shifts quicker because I can hear the exhaust note being different while it shifts.
Alan
09-17-2014, 08:12 AM | #5 |
Rep 525
wellllllll thinking about it now, i guess sport+ is all sporty,
then if i set sport mode to be only suspension, i get the sporty drive but relaxed tranny. then i can go to sport+ for full sport mode..... so i will have a -comfort -sport suspension -sport+ hell of a beast sport 50i |
09-17-2014, 01:51 PM | #6 |
Rep 512
Oddly my E70 50i felt the quickest in standard mode. When i pulled the shifter into "S" mode it shifted almost too much. The big torque of that V8 is felt more in normal mode i think. Try both and i think you should notice this as well. Especially half throttle from a stop feels a lot more torquey in normal mode.
09-17-2014, 02:21 PM | #7 | |
Rep 525
sport mode is intensely responsive compared to comfort |
09-17-2014, 05:14 PM | #8 |
Rep 512
Mine was a 2013. And i am an aggressive driver. I always felt the normal mode worked best on that car. Sport mode had lots of hesitation between shifts and that engine the power falls of after 6k while the sport mode is taking it to redline where its very flat. So the normal mode pulls a taller gear and shifts earlier making it feel like its pulling harder. Probably 0-60 may be a touch quicker in sport setting but the butt dyno says normal mode feels stronger. Try it!
09-17-2014, 11:01 PM | #9 | |
Rep 1,744
09-18-2014, 12:34 PM | #10 | |
Rep 512
09-18-2014, 04:02 PM | #11 |
Rep 473
Drives: 2016 Mini Cooper S 5 Door
The Gear Sport Mode shifts gears a bit later to simulate Manual Transmission but the Sport Mode actually changed Suspension and Traction Settings
2015 X5 xDrive35i M Sport, Black Sapphire on Terra Dakota Leather, Lane Change Warning, Lighting Package, 6WB, ConnectedDrive Services... (Sold) 2016 Mini Cooper S 5 Door Fully Equipped. (Sold)
2016 Audi A6 35 TFSI 2017 X6 xDrive50i Pure Extravagance, Space Grey on Coral Red, Fully Equipped. |
09-19-2014, 12:54 AM | #12 |
Rep 512
My E70 50i only had the gear shift selector sport mode. Not like my F15 35d which has actual sport and sport+ modes.
09-19-2014, 12:57 AM | #13 | |
Rep 473
