      07-03-2019, 11:59 AM   #1
BMW_K1D
Drives: 2014 BMW X5 (F15)
My A/C blows cold air on driver side and hot on Passenger
Hey guys, my 2014 x5 x35i is blowing cold air on driver side and hot on passenger side. I check the refrigerant and is charged. Anyone knows what my be the problem and how much it may cost? Thanks in advance!
      07-03-2019, 12:20 PM   #2
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Have you checked the dial near the center vents? If it's red it will be hot, blue will be cold
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
      07-03-2019, 12:22 PM   #3
BMW_K1D
Yes i did. Both dial are set to cold
      07-03-2019, 12:24 PM   #4
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
Looks like the passenger zone sensor needs to be looked at.
But do try this. Hit MAX AC button and see if it works.
      07-03-2019, 12:31 PM   #5
BMW_K1D
I did that as well, but that didnt work. Where i can find that sensor do you know?
      07-03-2019, 12:38 PM   #6
menelaos
menelaos's Avatar
1226
Will need to do some digging in the diagrams. Do you have 4 or 2 zone?
      07-03-2019, 12:49 PM   #7
BMW_K1D
I think is 2 zone
      07-03-2019, 12:53 PM   #8
BMW_K1D
      07-03-2019, 12:56 PM   #9
menelaos
menelaos's Avatar
1226
Do you have rear dials? if so, it's 4 zone.
Regardless, does the center passenger vent blow cold..or is it just the door-by passenger vent that does not?
      07-03-2019, 01:08 PM   #10
BMW_K1D
So its 2 zones. No rear dials. Center passenger vent blows hot as well
      07-03-2019, 01:14 PM   #11
menelaos
menelaos's Avatar
1226
From a brief google search, it could be a loss of Freon pressure.
As such, AC may be shutting down one zone to compensate.
First, if you can, check for any codes being thrown. This may provide a lead.
Eventually, you will have to take it to shop to check Freon pressure, evapcore leaks etc.
      07-03-2019, 01:17 PM   #12
BMW_K1D
Ok. It happened at a bad time when is hot here in nyc. Thanks for the help!
      07-03-2019, 01:19 PM   #13
menelaos
menelaos's Avatar
1226
I had a scare last week, but it went back to work after I hit the MAX AC button.
Must have kept the "warm" setting in each passenger profile as my wife had the same issue.
Car w/o fully working AC is kinda useless in these conditions.
Keep us posted!
      07-03-2019, 01:27 PM   #14
BMW_K1D
Keep us posted!
Will do
      07-03-2019, 02:16 PM   #15
va335i
Drives: G07 X7 M50i
I have the same problem in 50I right now, except driver side is hot and passenger is cold. I was told it is an actuator, does not throw codes. I have not fixed yet since I am turning over my vehicle Tuesday and moving to an X5M. Good luck with the fix.
2007 335i sport sedan fully loaded, fmc, downpipes, PTF custom tune. Sold
2012 X5 50i fully loaded. ESS TUNE
2017 X5 M Donington Grey
      07-03-2019, 08:03 PM   #16
jfandl
Drives: 2014 BMW X5 5.0 (F15) - BM3
I used to have this happen to my 330 a couple times a year. It was a freon leak and it would blow cold on passenger side, moderate on the center vent and hot on the driver's side. Even with dual zone, its still one compressor so I'd check freon.
      07-03-2019, 09:57 PM   #17
mgbabe
Drives: 2018 330i xDrive Gran Turismo
It happened on our 2017 40e on RHS as well, but only when the engine was running and got put to normal running temperature. In pure electric mode, it worked normally since the engine never heats up.
Dealer diagnosed as the RHS system valve was shorted to open letting hot air in from engine. Part was replaced under warranty and in the year since it has not re-occurred.
2018 330i xDrive Gran Turismo - Mineral White, Coral Red Interior
2016 Mazda Mazda3 GT - Deep Crystal Blue Mica, Off-white Interior
2007 Four Winns Horizon 190
      07-09-2019, 06:43 AM   #18
BMW_K1D
Problem fixed. The issue was the heater control valve.
Picasso37.00
      07-02-2020, 07:18 AM   #19
byaru1
Drives: X5 E70 3.0si
Hi, I have the exact problem.
What was the issue with the control valve? Was it loose? Did it require replacement?
Thx.
      07-05-2020, 07:37 AM   #20
uwodoc72
Drives: 2016 X5 35D
Did you do the repair yourself or did you take it to a tech?
      06-07-2021, 10:32 AM   #21
markslc1
Drives: 2011 1M, 14 X5 x35i
I’m having similar issues. How did you determine it was the heater control valve? Did you DIY?
