      09-29-2015, 04:44 AM   #89
BMW - BEKTAS
BMW - BEKTAS's Avatar
16
Drives: X5M
Originally Posted by paicapo View Post
Begin whit the E2 setting further settings don’t give much after that, it think that’s: s1=E s2=2. If you want info on settings search the forum, a lot of posts on this about a year ago. E2 is the preferred setting among most. God Luck
Guys thank you for your posts. I have read all the stuff here considering RaceChips. Lot of explanation how it works etc. I just have one question for all. The thing which I didn't understand is who from you uses S1 and S2 in this order. For example when you write E2. I understand its S1=E and S2=2. But I think it should be other way. S1=2 (approx 26% more power) and S2=E. Am I right?
This is important info. Thank you all.
      09-29-2015, 03:16 PM   #90
Trojanlaw
Trojanlaw's Avatar
Drives: 2019 X5 40i M
2019 BMW X5  [0.00]
No. Its the other way. For example I am running at 03
2019 X5 X40iM
      09-30-2015, 02:00 PM   #91
BMW - BEKTAS
16
Drives: X5M
If you are running at 03 that means you are running aprox. at 22% more power. I am writing like I understod the racechip tech. And that is confusing to me. Because Paicapo when he was trying the max of the chip he was moving S1=2,3,4(position) and S2=E(stayed in this). That makes sense considering the response I got from racechip.
This is how they described how it works:
Ria V. (RaceChip)
Sep 4, 09:51
Hi again,
only S1 regulates the performance and every position is an increase of about 1,5 %.
So default position 'E' is an increase of about 20 %, '0' about 22 %, '2' about 25 % and so on.
Dial "S2" regulates the RPM range in which the RaceChip is active and also when it is being deactivated again. On our default setting it is active between 1500- 3500 RPM. Every additional dial change with S2 increases the active range by about 150 RPM. We recommend not exceeding position '3' or '4'.
      10-02-2015, 05:22 AM   #92
gigabit77
Drives: 2015 X5 35d
Trojanlaw, so you are running S2=0 and S1=3 or S1=0 and S2=3? This would be so much less confusing if they used letters on one dial and numbers on the other or something.
      10-02-2015, 11:36 PM   #93
BMW - BEKTAS
16
Drives: X5M
I agree for using explanation. My default settings for 3.0d came S1=E S2=0.
      10-04-2015, 07:28 PM   #94
gigabit77
Drives: 2015 X5 35d
Interesting...my 35d (USA) came set at S2=E, S1=0. That's on the Ultimate. Purchased August 2015.
      01-21-2016, 02:04 PM   #95
FSociety
IG @bmwF9xG80
FSociety's Avatar
3810
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
paicapo how is it going amigo ?
60-130mph 6.5s X4M #HCP
IG: @bmwF9XG80
Search this Thread:
Advanced Search
