      07-08-2017, 01:41 PM   #133
Originally Posted by 1coolF15D2017 View Post
I've tried it on expert mode and change the value to a custom (maximum is 03 cannot go 04) of "PIA_DEFAULT_TIPPBLINKEN"-> "Tippblinken_fuenfmal (0x02). And I still get 3 blinks. Developer said that the value of 02 is correct and with newer iSteps it works for some and not for others. So I fall also on the others since it does not work for me. Oh well.
That sucks, that was one of the main reasons I wanted to code it. 3 is just not enough in a traffic circle.
      07-08-2017, 02:11 PM   #134
sigx5
Drives: X6
The only option that isn't working for me is the blinker from 3 to 5. Is anyone else having this issue? Recommendations?
you are not alone, I tried two times with no success, by the way, I have 2017 F16 35i
      07-08-2017, 06:36 PM   #135
wjdunn3
Drives: 2014 X5 xDrive35i
I was able to code the blinker count using Bimmer code app. In Bimmer code go to bdc_body, then expert mode. Find section nbr 3068, value name BLINKZYKLEN_ANZAHL_TIPP and change the werte value from 2 to 4 or 5 (for 5 or 6 Blinks). Code bdc_body.... Get ton of errors.... Use Bimmer link to clear the errors and info errors (have to do each 2/3 times to clear them all). Thats what worked for me!
      07-08-2017, 06:48 PM   #136
1coolF15D2017
Drives: 2020 X5 G05
Originally Posted by wjdunn3 View Post
I was able to code the blinker count using Bimmer code app. In Bimmer code go to be_body, then expert mode. Find section nbr 3068, value name BLINKZYKLEN_ANZAHL_TIPP and change the werte value from 2 to 4 or 5 (for 5 or 6 Blinks). Code bdc_body.... Get ton of errors.... Use Bimmer link to clear the errors and info errors (have to do each 2/3 times to clear them all). Thats what worked for me!
I will try that, thanks for your suggestion. What is the version of your app? My app was updated 2 weeks ago, 2.0.10
      07-08-2017, 08:09 PM   #137
Kr0m3assass1n
kr0m3assass1n
Kr0m3assass1n's Avatar
Drives: 22 X7 M50i
Originally Posted by Dirty Cash View Post
Originally Posted by Almaretto View Post
Only should have to update time after Coding instrument cluster functions.
Copy! Now I'll know when changing anything in the IC to expect that orange triangle and _ _:_ _ setting on the cluster.
Ok I attempted my first code tonight, just to make sure everything works properly. I only enabled turn signal on HUD which works like a charm. I used BimmerLink to clear temporary errors. Do I need to clear permanent errors as well?
      07-08-2017, 08:48 PM   #138
Dirty Cash
USAF Retired
Dirty Cash's Avatar
Drives: F15.50i
Originally Posted by zinengineer View Post
Best $75 spent ever
Agreed!
BTW, are you a WKU "BIG RED" fan?
      07-08-2017, 08:48 PM   #139
Dirty Cash
USAF Retired
Dirty Cash's Avatar
Drives: F15.50i
I cleared everything I could each time I coded.
      07-08-2017, 09:15 PM   #140
zinengineer
zinengineer's Avatar
207
Drives: 2016 Space Gray X5 M Sport
Best $75 spent ever
Agreed!
Lived all across the USA (engineer, not military) and find myself a Kansas basketball fan in the heart of Wildcat country
2016 X5 35i Xdrive M Sport; Space Gray Metallic/Mocha Dakota
2014 535i Xdrive luxury line; Black Sapphire Metallic/Black Dakota
      07-08-2017, 09:15 PM   #141
Kr0m3assass1n
kr0m3assass1n
Drives: 22 X7 M50i
I was able to code it using BimmerCode. My app showed values 1 through 6 in the sub menu. I selected 5 and coded and it was successful. Cleared errors, restarted and it worked like a charm. Not sure if you're seeing the 1 through 6 values on your screen?
      07-09-2017, 03:10 AM   #142
I only have 1, 3 and 5 available.
      07-09-2017, 06:12 AM   #143
Kr0m3assass1n
kr0m3assass1n
Drives: 22 X7 M50i
Just a wild thought but can you try 1 and see if that even works? You could try to set it to 5 and try again afterwards?
      07-09-2017, 09:34 AM   #144
Dirty Cash
USAF Retired
Dirty Cash's Avatar
Drives: F15.50i
Ok! I'm from KY (Louisville), and I am a diehard UofL fan!
      07-09-2017, 11:04 AM   #145
Yes, that was my next plan, then attempting the expert mode.
      07-09-2017, 03:50 PM   #146
jsebjimenez
jsebjimenez's Avatar
16
Drives: 2014 BMW X5
Originally Posted by lowlevelhell View Post
1. Buy a vgate OBD II wifi adapter on Amazon ($24ish)
2. Download Bimmercode and pay $26.99 to unlock coding
3. Code your X5 to your liking
The only thing I wanted to do that I could was increase the fan speed, but I have a request in to the developer for help.
Do you need to keep the ODB adapter connected or can one remove once unlocked all codes?
      07-09-2017, 04:28 PM   #147
d_v_o_1
Gotta be connected each time you wish to access the code.
      07-09-2017, 04:30 PM   #148
jsebjimenez
16
Drives: 2014 BMW X5
But once the changed/entered ?
      07-09-2017, 04:34 PM   #149
d_v_o_1
Once it has been entered you can disconnect the module until you need/want to use it again. So if the dealer flashes the ecu upon a visit, just go through the process of coding again. Also works on multiple vehicles at the same time. Hope that helps
      07-09-2017, 05:35 PM   #150
Kr0m3assass1n
kr0m3assass1n
Drives: 22 X7 M50i
I also notice Bimmercode saves backups of the codes along with the date and timestamp. It may be easier to restore from backup after a dealership visit instead of recoding everything?
      07-09-2017, 05:50 PM   #151
eggyacid
eggyacid's Avatar
Drives: BMW X5 F15
Anyone know the coding in bimmercode for the following
- activate front camera when driving
- activate rear camera when driving
I know I can change the shut off distance and speed which I like. However, is there a way to quickly activate the camera while driving?
Jeff
Current Ride
- 2016 Toyota RAV4 Hybrid
- 2014 X5 xDrive35 M
- 2013 ML-350 (Gone)
- 2012 Audi Q7 TDI (Gone)
      07-10-2017, 12:28 AM   #152
sigx5
Drives: X6
me 2; I only saw 1, 3 and 5 option as well. let me know your plan is working or not ... I have no time to play the coding around this week, busy for office stuff thank you for sharing
      07-10-2017, 12:31 AM   #153
sigx5
Drives: X6
I only saw 1, 3 and 5 options
      07-10-2017, 03:15 AM   #154
Update: changing from 1, code then back to 5, code - didn't work.
Expert mode, didn't see the aforementioned option. I searched the entire directory.
