      01-15-2019, 11:44 PM   #67
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Guys is Lemforder 31126863785 a good option for wishbone replacement? I started having that creaking noise on low speed on flat road like in slow stop and go traffic. That Lemforder costs $110 and it says it's OE - not sure if it really is.
CPO warranty will not cover it right? I'll need alignment after correct? Thank you
      01-16-2019, 07:42 AM   #68
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
That's the upper control arm not the one that the usually makes the noise. Unless you've diagnosed this to be an issue now. And yes lemforder is a good brand.
And yes you'll need an alignment cuz this directly affects camber.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
DuSh2113.50
      01-16-2019, 10:47 AM   #69
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Thanks Maverick!
      01-16-2019, 12:24 PM   #70
sj22
Drives: 14 F15 50I
Subscribing, will be my next *mod* ... lol
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors
Past: 2013 750i xdrive, 2008 535xi
      01-16-2019, 02:23 PM   #71
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks Maverick!
This is the piece BmW offers in camber offsets of +- 30min. What my tech suggested I have installed as he couldn't get my camber perfect. Still got in limits but not ideal position he said
'06 C55 AMG (sold)
DuSh2113.50
      01-16-2019, 11:03 PM   #72
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
31126864821 is the lower left suspension piece. 822 is lower right. Called a wishbone but it's a straight stick of aluminum with two bushings and a ball joint...
I have heard that the upper wishbone can bend. I'm hoping mine is in good shape.
What do your thrust arm bushings look like?
What's funny is we share that upper wishbone w/E70 X5s.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
DuSh2113.50
      01-17-2019, 06:41 PM   #73
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
Originally Posted by daytonaviolet View Post
so was this your fix? i'm having similar popping thump noise coming from the front of the car. it occurs every time i back out of the garage while the rear tires are in the street and the front tires are coming off the driveway onto the street. not only is it a popping sound, but it feels like two plates of metal sliding off of each other.
i have an appointment at the Stealer thursday. hopefully they can resolve this i currently have ~ 10k miles.
Originally Posted by sbkim View Post
Just a quick update. While I am still skeptical, it seems like the noise may be gone after my 3rd trip back. Here's what they did: Chassis ears installed; retorqued thrust rod and lower control arm. They said it was about 3/4 turn loose. My guess is after they were installing the right control arm (warranty repair some time ago), they didn't properly torque some bolts. Hope the noise won't reoccur.
This is what the dealer told me today. Not sure if I buy it 🤔
Tech just reported back to me that there is a common problem with the M cars that there is a known noise that comes from the front brakes so they have a remedy where they place a shim between the hub, rotors and wheel to get rid of the noise. Tech says it may not get rid of it completely, but there should be a difference after that is done.
      01-18-2019, 01:58 PM   #74
smc007
Drives: BMW
Do you guys notice the nose when SLIGHTLY lifting off the brake pedal?
This, in addition to TURNING the wheels?
I'll need to find my directional mic to get some videos.
BimmerTy192.50
      01-18-2019, 02:18 PM   #75
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
So I thought about it when trying to pinpoint which suspension part was making noise I have. We might have in this thread 2 or 3 different noises/issues.
The one I have is when suspension makes creaking noise when car is not going over any bumps, but is on flat surface and we can reproduce noise by lightly applying gas pedal and taking it off right away, it's heard at low speeds with climate control turned off to hear creaking noise. By avoiding going over bumps - we rule out sway bars, struts and ball joint. We rule out tie rods by keeping steering wheel straight and not touching it. We only move forward on a flat surface when noise is made - that indicates it's control arms (so called wishbones) - as they are exactly what connects body frame and hub/strut assembly and if bushings are worn - it will create that creaking noise - when longitudinal force is applied against body frame (like in our case moving forward and car jerks forward/backward when we lift off the gas pedal, especially in Sport/Sport+ mode when gas pedal is very sensitive).
Then there is another issue/noise with backing up and turning the wheel - that is different issue I think that could be related to either steering wheel assembly (including inner knuckles or tie rods), to brakes or ABS module - not sure if it was 100% diagnosed by someone?
If you have noise going over bumps - that's either ball joint, strut mount or sway bar links/bushings.
In your case with turning the wheel and slightly lifting brakes off - could be either brakes or steering assembly (anything from mounts to knuckles and tie rods).
I know it's hard to diagnose suspension noise on x5 as we have lots of things that could be at fault here.
      01-18-2019, 09:31 PM   #76
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
I promise it's all the control arm lol. The turning noise is from the ball joint and the others is from the bushings. There are three points of failure on this damn thing. First Boise issue I had over summer with straight and level driving. One of the bushings was cracked. Now I'm getting it when I pull into a parking space with wheel turned and I come to a stop. Boom. This is the ball joint now.
But I could be wrong lol
'06 C55 AMG (sold)
DuSh2113.50
      01-18-2019, 10:30 PM   #77
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Thanks man! It's good to know it's control arm - probably a lot of stress on it. I'm going to replace it in couple weeks.
      01-20-2019, 01:59 PM   #78
Mojo85
Drives: S2000
Having this issue too. Thought it was a loose front driver side wheel as it got worse over a week or two. Is this control arm issue covered under CPO warranty?
      01-20-2019, 03:49 PM   #79
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Doubt it. Most suspension components aren't covered under warranties u less it's a faulty part. But doesn't hurt to try.
'06 C55 AMG (sold)
      01-20-2019, 05:09 PM   #80
fnunez164
Drives: BMW X5
It is covered under warranty. Just provide the SIB number to the dealer and they will take care of it. I had it done on mine under warranty 7 months ago.
      01-20-2019, 07:39 PM   #81
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Warranty and CPO aren't the same animal.
'06 C55 AMG (sold)
      01-23-2019, 07:15 PM   #82
Mojo85
Drives: S2000
Brought it car for service and both control arms were replaced without me paying anything.
      01-23-2019, 08:08 PM   #83
Mojo85
Drives: S2000
Spoke too soon. After I picked up the car I got a call to say car was incorrectly assumed to have warranty and work was done under that instead of the CPO. They said they will call me tomorrow to update me. Not sure if they are asking for the $50 deductible or want money for the work that I was never told the cost of.
      01-23-2019, 08:10 PM   #84
admranger
Retired Curmudgeon
admranger's Avatar
Upper or lower?
      01-23-2019, 09:47 PM   #85
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Upper or lower?
Lowers
'06 C55 AMG (sold)
      01-23-2019, 09:49 PM   #86
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
And yes there is a SIB which if in factory warranty will be covered. But extended and CPO are different animals. I've never heard anyone under CPO getting it done since most of these fail around 30k miles. My issue was so little miles in the Original lease that I lost warranty due to time not mileage.
'06 C55 AMG (sold)
      01-23-2019, 09:52 PM   #87
sj22
Drives: 14 F15 50I
That was my exact experience with my old F01 also - the left front control arm was replaced and the noise was gone. With F15 unfortunately this crept up after warranty expired.
      01-23-2019, 10:39 PM   #88
Mojo85
Drives: S2000
It was lower wishbone. Both left and right were replaced and the SIB mentioned in this thread was noted on the work sheet.
Not sure if I will get a call tomorrow to request payment as they seem to incorrectly assume I had warranty when in fact only CPO warranty. I didn’t authorize any work and assumed it was covered by CPO.
My warranty expired 12/31. The issue did being to occour before that but I don’t think I mentioned that.
I had 35k miles in the car. So
