      02-09-2019, 08:40 PM   #1
humbertob
humbertob's Avatar
Drives: '16 BMW M235i
Thumbs down No Beeping/Chirp when locking/unlocking
Hello guys, our F15 is not beeping/chirping when locking/unlocking the vehicle and the audible alerts are ON in the iDrive, any idea what's wrong with our X5?
(OO)-(////)(\\\\)-(OO)
'16 F22 M235i
'19 G01 X3 | Wife's
'15 F30 335i M-Sport | Son's
'10 Porsche Boxster
      02-09-2019, 08:44 PM   #2
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
There's a red light on the rear view mirror - it's visible from outside facing the windshield. Does it flash many times when you lock unlock? If it does - there's something not closed in your car - hood, trunk, door etc. in that case there will be no chirping sound. Check that first please. it's a factory feature - if you didn't hear chirping - come back to car and check all doors, hood, trunk etc.
      02-09-2019, 08:55 PM   #3
humbertob
humbertob's Avatar
It's flashing so many times, the weird thing is that the vehicle is not telling me that a door the trunk or even the hood are open
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
      02-09-2019, 09:17 PM   #4
turboawd
1636
Drives: 2015 X5 35i
You're suppose to count the number of flashes and that tells you what is going on. I just don't know the flash counts.
      02-09-2019, 09:19 PM   #5
humbertob
humbertob's Avatar
Wow it's flashing like 20 times after locking the vehicle.
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
      02-09-2019, 09:36 PM   #6
turboawd
1636
Drives: 2015 X5 35i
Go around and open and close all your doors and trunk again. Maybe the hood too.
      02-09-2019, 09:43 PM   #7
humbertob
humbertob's Avatar
Just did it and no fix at all ! The red alarm light is blinking 20 times exactly after locking the vehicle
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
      02-09-2019, 10:47 PM   #8
DonJuan
DonJuan's Avatar
538
Drives: G82 M4, F15 X5, F30 328d, E30
Hi Humberto,
(I think I remember you from another forum) did you own an X3 before?
Regarding your issue, with the multiple flashing, the alarm system is trying to tell you that there's a problem with the system. A sensor malfunction, or even the siren could be bad. (Does the siren go off if you trigger the panic function?) The only real way to know is to read the codes in the alarm ECU, you can use the Bimmerlink app for that.
The other thing that could happen, if you bought it used, a previous owner could have coded the beep off, again, for this you'll need another app called Bimmercode and you can code it back. Both apps work with the same Bluetooth dongle.
Good luck!
2022///M4 Competition BSM / Fiona Red.
2023 X7 xDrive40i, BSM / Individual Ivory white/Atlas Gray over Piano Black
MSport Pro and Prof.
      02-09-2019, 10:53 PM   #9
humbertob
humbertob's Avatar
Originally Posted by DonJuan View Post
Hi Humberto,
Good luck!
Hello DonJuan, yes I owned 2 X3s before, I have checked the coding on this vehicle using BMWCarly and the audible locking/unlocking option is active, When I press the panic button the alarm goes off and the horn honks very loud, but I know for sure that the beep when locking/unlocking the vehicle is not related to the horn of the vehicle, so I think I have a damaged alarm sensor/speaker.
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
      02-09-2019, 11:07 PM   #10
DonJuan
DonJuan's Avatar
538
Ok, yeah proably Bimmerfest, I owned a an X3 for many years. (I'm X3Terrestrial there).
So yeah, you probably have a bad siren speaker or sensor. I wouln't rule out that someone has messed with the coding before, there are several different settings you can change for the alarm.
You can check here: http://bimmercodeapp.com/cars/f15/
      02-10-2019, 12:06 AM   #11
humbertob
humbertob's Avatar
Ohhhh I really remember you ! Glad to have you here buddy! I just compared the functions of bimmercode and BMWCarly and they are basically the same. I have determined that the speaker/level sensor is done. Just found one at ebay for $60, it's already on it's way home, I'll let you know how the story will end for sure.
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
      02-10-2019, 01:59 PM   #12
smyles
Drives: '21 X5
Did you check the fuse?
      02-10-2019, 02:00 PM   #13
humbertob
humbertob's Avatar
Not yet, any ideas of the fuse location?
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
      02-14-2019, 12:22 AM   #14
humbertob
humbertob's Avatar
Any idea how to access the siren location? Do you think that removing the rear passenger fender liner could I access the siren and replace it?
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
      02-14-2019, 12:51 AM   #15
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Rear bumper must be removed. I had the whole alarm module replaced about month back, after being rear ended and the tilt sensor got damaged.
      02-14-2019, 08:22 AM   #16
humbertob
humbertob's Avatar
I was thinking that the siren could be reached removing the rear fender liner ?????
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
      02-14-2019, 08:28 AM   #17
CatalinP
Good luck with that!
      02-14-2019, 08:31 AM   #18
humbertob
humbertob's Avatar
I think that my wife's F15 will remain silent for a long time then ! 😬
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
      02-14-2019, 08:50 AM   #19
Rainer M
Drives: E93 M3, 2018 X5 35D
You could try and code the chirp off with your Carly and then after a reboot (sleep) try to code it back in.
Unlikely that this would help but easy enough to do to give it a shot. Could be the module is just screwed up and changing the setting back and forth straightens things out.
Slim chance.
      03-12-2019, 11:57 PM   #20
humbertob
humbertob's Avatar
Update: Problem Solved
Just found out that Fuse 103 was broken, replaced and chirp is back !
'16 F22 M235i
'19 G01 X3 | Wife's
'10 Porsche Boxster
      03-13-2019, 08:58 AM   #21
DonJuan
DonJuan's Avatar
538
Oh wow. Good thing it was something simple!
      11-17-2019, 09:28 PM   #22
rosscgeller
rosscgeller's Avatar
Drives: 2022 G07 MSport
How did you find out Fuse 103 was shot? Just open it and take a look? I’m having the same issue and am running through the troubleshooting steps. Checked the coding, all is good there.
alarm, audible alert, beeping, chirping
