      10-16-2021, 02:33 PM   #45
Cbozz
Cbozz's Avatar
Drives: M3
Originally Posted by pachieh View Post
How's the brake dust off these?
It's great! I really didn't notice much dust but the pads are low dust compound.
I actually am going to change the front because those pads drive me insane!
there are two different squeal sounds... one just high pitched and the other exactly like race pads would make and it's just terrible!! and the dust in the front is so bad.
      10-17-2021, 03:55 PM   #46
pachieh
Drives: '17 X5M
Wonder how they compare to the Powerstops…
Eisenmann Pro, Dinan Intake, BM3 Stage 1, XHP Stage 3
21" Vossen VFS-1 on Michelin PSS
      10-20-2021, 09:50 PM   #47
SaNGRia
SaNGRia's Avatar
986
Drives: LCI E93 M3 + F85 X5M
I finally installed the calipers today. The best visual upgrade impo. This should have come like this from the factory!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
Appreciate 4
      10-21-2021, 12:10 AM   #48
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Are there any other pad options or is the custom design from Porterfield the only option.
      10-21-2021, 10:02 AM   #49
Cbozz
Cbozz's Avatar
Drives: M3
You can use any pad for the GT4 caliper but you will have a 5mm rust ring with other ones..
No one makes the pad that would cover the whole diameter of this rotor…
This pad is made to cover those whole thing but you can use a different one.
      10-21-2021, 10:09 AM   #50
Cbozz
Cbozz's Avatar
Drives: M3
Here is what it looks like with the biggest pad that they make for that caliper… so you do have options!
Chilled363.50
      10-21-2021, 01:51 PM   #51
FirstBMWLA
FirstBMWLA's Avatar
187
Drives: 2007 335i Coupe
As I stand to the side of my car right now I realize this mod is going to be a must lol.
These rear brakes are pitiful
Cbozz688.50
SaNGRia986.00
      10-21-2021, 06:14 PM   #52
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
What about the wear sensor? Is it like a universal thing or just don't plug it in.
      10-22-2021, 07:53 AM   #53
Cbozz
Cbozz's Avatar
Drives: M3
Plugs right in- just like in the picture
      10-22-2021, 06:04 PM   #54
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Is there a pad shape/ style for these? Just found https://www.zeckhausen.com/catalog/i...gfmliefufsrjq0 and from the pictures it looks like either the Gt1/f40/f50 or the Monoblock 4 (D810). Plus the pad dimension look similar to yours.
Sorry for all the dumb questions, all of this is kinda new to me and trying to learn.
Been on the other side of the world, have to think where to source things a bit closer.
      10-23-2021, 10:34 AM   #55
Cbozz
Cbozz's Avatar
Drives: M3
Your link took me to a vague of selection but here is one you can use.. it will leave like a 5mm rust ring tho.. maybe more not sure
https://www.hawkperformance.com/pads/hb453f-585
Chilled363.50
      10-23-2021, 11:43 AM   #56
Blue By You
Blue By You's Avatar
631
Drives: 2017 LBB X5M F85
I really like this mod for cosmetics. And I assume braking performance is just as good if not better? Is that something my indy can properly program so that the braking dynamics and performance remain? (I am an assertive driver and I plan to be on the track next year)
Also wondering when to do it because I have a warranty and maintenance program that I want to keep intact for the rear brakes. I'll talk to my SA about how they would handle it.
If you guys have any insight on the programming for performance etc. that would be helpful.
TIA
      10-23-2021, 09:47 PM   #57
Cbozz
Cbozz's Avatar
Drives: M3
TIA
No need to program anything, the brake piston size is a 101% match to the oem piston so it’s the same surface for the master cylinder and brake bias.. pedal feels oem.
      10-23-2021, 09:50 PM   #58
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Sorry about the site, I had no idea what the part #/ spec a Brembo GT4 calliper is, and that was the first site i found that had pictures.
Cheers for the example.
Cbozz688.50
      10-24-2021, 09:40 PM   #59
SaNGRia
SaNGRia's Avatar
986
Pedal feels OEM , And IMPO breaking got better, it might also related to fresh fluid but I definitely feel the differences 🙌🏼
      10-25-2021, 12:50 PM   #60
Cbozz
Cbozz's Avatar
Drives: M3
Could be the fluid combined with a larger pad..
      10-25-2021, 03:16 PM   #61
FirstBMWLA
FirstBMWLA's Avatar
187
Any instructions with this or I guess I could figure it out looking at any other brake DIY?
I've done brake pad work but never a caliper swap.
      10-25-2021, 03:30 PM   #62
4everkidd
Drives: F80 AY M3
Scope out YouTube; swapping a caliper is a very easy DIY.
I would highly suggest a motive power bleeder to make the job even easier.
Cbozz688.50
      10-25-2021, 08:45 PM   #63
Cbozz
Cbozz's Avatar
Drives: M3
that's the pressure bleeder I used...
also before you unhook the calipers from the brake lines depress the brake pedal and leave half way depressed in - that blocks the fluid from leaking out and you will get no leaks and no chance on air entering your lines and with that being said a lot easier job when it comes to bleeding them later after installation of new calipers...
also when comes to bedding the new brake pads - this is what porterfield sends out.. they pretty much say that pads are pre bedded and you suppose to drive easy without bedding in procedures, no hard breaking unless you have to for around 100 miles...
      11-04-2021, 04:26 PM   #64
JRock80
JRock80's Avatar
456
Drives: 2016 BMW X5M F85
[img]https://i.ibb.co/ZmxfKC6/20211020-113330.jpg[/img] [img]https://i.ibb.co/f4tvcvY/20211020-113648.jpg[/img] [img]https://i.ibb.co/wZnwphp/20211020-123518.jpg[/img] [img]https://i.ibb.co/Bc0gYMB/20211020-130033.jpg[/img] [img]https://i.ibb.co/p3Q9Td8/20211020-131249.jpg[/img] [img]https://i.ibb.co/Kj79SDy/20211020-221848.jpg[/img]
How is the setup thus far? Any honest feedback you'll like to share with everyone?
2016 BMW X5M F85 | 2019 - Present
2015 BMW X5 F15 5.0i m-sport | 2016-2019
2001 BMW X5 3.0i Sport | 2005 - 2008
      11-04-2021, 04:41 PM   #65
SaNGRia
SaNGRia's Avatar
986
Excellent, Great, Amazing!
, F85 ACC Retrofit
Cbozz688.50
      11-11-2021, 02:29 AM   #66
Seattlesquash
Car Enthusiast
Seattlesquash's Avatar
Drives: E92 328i 2007 SC
Chris, fantastic work. Just picked up an F15 3.5D w M package and brakes are garbage (at least looks) From what I understand these bolt up ok for me too right? Then I just need to source discs, SS lines, and the front kit, and where would you recommend picking up that one? Last one, do I need to change MS l, me coming from non M model (F15). Very interested, and likely talk/PM you soon and do want the cross drilled discs too and great if I could source them for front in a way to know they are color matched, and blue works well with me. CTSV gold painted and mustard yellow in other cars so this needs to be different and prefer it over red.
Appreciate any info on this. Cheers.
E92 328i|6MT|ESS SC VT-1 (G.2)|3 stage|22 RPD SC/Meth tune|AA Headers|Snow Performance Meth Injection|Rotiform KPS|R139|PS4S 275.245.19|M3 front|M3 side skirts|MTEC rear|Akrapovic C tips|Koni Sport (Yellow)|Eibach PS|Hotchkis SB|C high-kick spoiler|C mirror Covers|C trim|LCI tails|M3 Control arms|M3 MS|Black E trim|Black kidney's|Full LED Conv|BMW F30 370/345 BBK|ECS SS|ECS Strut Tower Brace|034 Engine-Trans-Rear Mounts
