      11-11-2021, 05:11 AM   #1
devonjames
Drives: f15 x5
2014 X5 F15 N57 3.0d Excessive Oil Consumption
Hi.. im new to the Forums online,
I have this vehicle, and is excessively consumming oil..
Last time its 2ltrs in 350 miles!!!!!!!!
Vehicle is below 80,000 miles
No Leaks or Smoke either..
Very unusual
Anyone out there whos had a issue with this??
Inlet pipe to turbo (connection to breather crankcase) has abit of oil as you would expext??
Any help or info will be great
Thanks
      11-11-2021, 06:59 AM   #2
Isaurio
Drives: 2014 X5 xDrive50i
Very unusual
Thanks
Welcome! On my 50i i had similar issue. Took it to the dealer and turned out to lower oil pan seal was bad and was dripping oil. You wont see anything on the floor since there is a cover that have some type of oil catch. I would check there first. They replace the pan with new seal and new screws never had a issue again.
      11-23-2022, 12:20 AM   #3
armkub
Drives: BMW X5 F15 30d
Hi,
Did you solve the problem?
I also have same model and also burning oil
      11-23-2022, 01:49 PM   #4
suitedcboy
Cattlecar
42
Drives: 2016 X5 50i MSport
The place you start is crankcase vent unit., if this has not already been done. If it is partly plugged or has too much deposit buildup then it fails to condense oil from escaping vapors and oil consumption can be high. Search "N57 crankcase breather". There is a cover with diaphragm that fails but the unit can be cleaned and change the diaphragm or replaced to get a properly functioning unit with new diaphragm already fitted.
      03-05-2023, 08:42 AM   #5
dieseldrew
Drives: 2015 X5 35D (F15 / N57)
1qt consumed in 1400mi, 72K mi. on engine. Not excessive, seen worse especially on T4 engines (Audi, etc). 1L in 175 mi is excessive and if it is being combusted (as opposed to leaking), surely it could lead to other problems/fouling.
      02-17-2024, 09:55 AM   #6
LOTownX5
Drives: f15 x5
Ever figure this out?
I have similar issue.
