      03-29-2022, 06:15 PM   #45
Ionutz009
Drives: F85
Originally Posted by Chilled View Post
Ionutz009 , Hey what was the P/N for the bearings you ordered. Just looking at RealOEM and slightly confused. or the Set?
Those are the ones i bought:
https://www.driftshop.fr/coussinets-bielles-acl-trimetal-bmw-s63b44.html
Chilled363.50
      03-29-2022, 11:11 PM   #46
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Originally Posted by Ionutz009 View Post
Cheers.
Curious what the mains look like.
      03-29-2022, 11:57 PM   #47
M_Bimmer
M_Bimmer's Avatar
583
Drives: G12 B7, G07 XB7, F02 B7, 991.1
Originally Posted by sly1types View Post
There have been some local S63s that have blown up. I just hit 50k and will be doing oil samples. Just sent one off last week. If it comes back questionable I will get them done.
Can you post your oil analysis results?
I just received mine back and few things don't seem right for only 9,563 miles on the odometer, and oil changed every 12 months:
Copper (average = 3) = 3 (my value)
Tin (average = 1) = 2 (my value)
Boron (average = 71) = 90 (my value)
Fuel % (average = <2.0%) = 2.8% (my value & 5% is critical)
My main concern is that the fuel dilution seems awfully high for such a low mileage engine....
{Note: I put 1,000 to 2,000 miles in between oil changes, so my vehicle has had 5 oil annual oil changes}
      03-30-2022, 01:27 AM   #48
Sophisticated Redneck
Drives: 2012 BMW X5 50i
When you drive it, are the trips long enough to allow the oil temps to reach normal operating temps? This aids greatly in boiling off the fuel that naturally works its way into the engine oil.
Next to check is your Crank case Ventilation lines to make sure they are connected properly and not cracked/damaged.
You can also have your injectors tested with ISTA loaded on a laptop and enet cable if you are a DIY'er or take to dealer and request injector leak test in ISTA/E-sys as it could be a possible failing/sticky injector.
      03-30-2022, 02:51 AM   #49
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
interesting you didn't go with the HX. I haven't done much reading, does anyone know the pros/cons on going +0.001"/0.025mm on the S63? Is there any data proof?
      03-30-2022, 11:12 PM   #50
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Or the better question would have been, does anyone know what's a good spec for the S63?
Looking around and a few of the shops that have built the S63 to 1000whp+ all just hide and say proprietary. No brand, nothing.
The only thing I could find was a down under place, PPM. and their 5.0L kits. These run the ACL bearings.
https://www.pureperformancemotorspor...ng-engine.html
      03-10-2024, 02:50 PM   #51
Ionutz009
Drives: F85
sorry for not updating the thread for so long...
i already made 10k km on the rod bearings replacement and no issue at all.
meanwhile i made some huge upgrades. Pure turbos stage 2 turbos, jb4 with methanol injection, remap. And everything gone to a result of 920hp.
The car is driving wonderful and it's a true beast.
And for sure i recommend to change the oil every 5-6k. Better if you have an aggressive tune.
If you have any question, i'm here to answer them and help as much as i know
      03-14-2024, 05:26 PM   #52
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Wow, nice.
Well done sounds like a beast.
