      03-09-2024, 04:50 PM   #1
tfunk88
192
Drives: F15 X5 50i
Sooooo found that the bank 2 “rubber boot” as BMW calls it…or the intake tube, as I call it…cracked where it mounts to the turbo on my 50i. Which is letting some air in post MAF and filters. I’ve ordered both bank 1 and bank 2 replacement tubes from FCP Euro. How bad is it to drive the car until they come in Wednesday? No engine light but when I pull codes I’m getting stored “bank 2 lean” codes.
I’ve been driving it this way for a bit, had seen the code occasionally but just discovered the crack. 🤦‍♂️
      03-09-2024, 06:14 PM   #2
zeroping
Drives: 2018 X5 M (F85)
It's allowing unfiltered and unmetered air. Likely fine to drive if needed but I wouldn't for long. I most certainly wouldn't push the beast with inaccurate readings.
      03-09-2024, 06:51 PM   #3
tfunk88
192
Drives: F15 X5 50i
Yep, definitely taking it easy when driving. Rigged it so it is pretty sealed, I’m guessing a couple more days can’t do any more damage than I have already lol
      03-10-2024, 07:51 AM   #4
jab23
224
Drives: 2017 X5M
Can you throw some tape on it in the interim?
tfunk88192.00
      03-10-2024, 09:07 AM   #5
tfunk88
192
Drives: F15 X5 50i
I’ve got it rigged up so it’s tight…the cracked area is right next to the turbo so I don’t want tape adhesive to melt and make a mess from the heat. Will drive it minimally from now until I get the replacement tubes in
jab23223.50
