      05-24-2023, 04:02 PM   #1189
oem.plus_440gc
oem.plus_440gc's Avatar
353
Drives: 2019 440i XDrive GC
Just dropped of my wife's 2015 X5 35i to (i believe) get the oil filter housing/oil cooler thermostat replaced. It was just flowing coolant out of it. They're going to do their own diag on it tomorrow so i'll update with their diagnosis and cost to fix/replace.
Edit: It just passed 101,000 miles on it and from what i've ready this is somewhat common on the N55.
Edit 2: Just got the car back yesterday. It was indeed the OFHG and that was replaced. $200 diag, $750ish repair. When they completed the repair, they took it for a test drive and a drivetrain error and CEL popped up. Since the car was in their hands when this happened, they diagnosed and fixed the issue (which i believe was a cam position sensor) for free. Glad that happened while they had the car so i didnt' have to cough up another few hundred $$...
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
      06-05-2023, 08:37 PM   #1190
Harv
Drives: 2023 X5 M50i, 69 2002, 77 530i
Overheating
2018 F15 X5 35d 86,000 miles original owner.
Excellent maintenance and all recalls up to date including the egr cooler and hp fuel pump.
A few weeks ago I departed Cleveland for Asheville towing my 69 2002 on an aluminum trailer. Myself and this X5 are not new to towing, I also tow a 23’ Airstream. The night before I left the temp dropped to 38f and about 70 miles into the trip I got a low coolant level indication. Keeping an eye on the temp gauge I pressed on (bad idea I know) thinking the fluctuation of outdoor temp may have had something to do with it. About 120 miles later (and right by an exit) I got a high engine temp indication. I pulled off, let it cool, topped off the coolant level, burped the system the best I could and continued to Asheville without issue. When I got to “The Vintage” I dropped the X5 off at Asheville BMW for a look over. They reset the coolant level and vac bleed the system. No faults, no leaks, no codes of any kind. After the weekend I loaded up Sunday am and started for Cleveland. I made it up and over the mountains and down into TN. Stopped for fuel and back on the road again. 10 miles later it overheated again. Stopped immediately had it towed to a dealer about 30 miles away. They looked at it Monday and said it needs a thermostat and mechanical water pump. Sounds reasonable and correct. On my way Tuesday (had to wait for parts) and it happened again 120 miles away. Cooled, topped off, burped and I made it back to the dealer. They were embarrassed. Vac bleed the system again and all is normal. This time I made it 200(somewhat) miles away and it did it again. Got towed to Charleston WV where I stayed overnight. A buddy of mine drove down with his Sprinter Van. 2002 off the trailer and X5 on. I followed in the 2002 4 hours home.
I’m not coming up with any similar issues with all my searching. At best it’s something like the egr cooler (but no codes). After that it goes down hill fast head gasket, head, block? I seams to me air (boost?) is getting in the cooling system. Air bubble manifests in the pump and it overheats. Rad hoses are cool to Luke warm (they should burn you) the heater hoses go cold too.
Anything?
Buler?
I might X post this.
John
      06-06-2023, 10:39 PM   #1191
FALKLAN
Sing your death song!
FALKLAN's Avatar
Drives: 2015 X5 xD35d | 2003 MB ML500
Diagnostic Report Assistance
2015 x5 35d
pdf of Diagnostics Report is attached
I'm more of a MB guy is why I'm here asking for help with my accountant's bimmer. IDK what started all this but I recorded the report and cleared.
None of those DTCs returned during my test drive of a little more than 30 minutes; however, she says it's still running as if it's missing. After driving this SUV, you would swear that it's missing pretty bad. I have not seen the first DTC for an engine misfire. It cuts out just for a moment, just like it's a misfire.
I'm going to attempt to meet her tomorrow and scan it again before she takes it to the indie Thursday.
I'm really not sure what tripped all those DTCs.
Any and all help is greatly appreciated! Thanks!
File Type: pdf 5.23.2023 Diagnotic Inspection Report.pdf (183.8 KB, 82 views)
Last edited by FALKLAN; 06-07-2023 at 08:00 PM.. Reason: please don't shoot me... i posted an unsanitized report w/company info and idk know your polices but my apologies
      06-08-2023, 01:30 AM   #1192
FALKLAN
FALKLAN's Avatar
Post RE:Diagnostic Report Assistance
I believe this has something to do with the exhaust fluid stuff. I really have no idea concerning that stuff. Something about chemically induced exchange of something? yeah I really don't want to go there.
I also attempted to recreate the EGR code without success. At first I thought the EGR fault was the cause but it's functioning properly.
Well, you all know the drill I believe. It's called a service manual right? Wrong! My MB "service manual" is provided as a VM (virtual machine). Off I go to get another "service manual" where the UI is an atrocity on my PC due to it's resolution. No I "don't need" a magnifying glass to read the UI of the "service manual" VM. I need a FN microscope! Yes I edit the system font to increase it's size to maximum; which, in turn, works for everything else in the OS (Win 7 Ult.) but the "service manual." I'm even uncertain if it can help troubleshoot this dilemma.
      07-20-2023, 08:41 PM   #1193
BigStan76
Drives: BMW f15
Power Control Module location
I am trying to find the location of the power control module for 2014 F15 sdrive
Last edited by BigStan76; 07-20-2023 at 08:44 PM.. Reason: new member maybe posting in wrong place
      07-21-2023, 02:05 PM   #1194
RED_Y_
Drives: 2014 X5 3.5d
https://f15.bimmerpost.com/forums/sh....php?t=1938950
      07-22-2023, 03:14 AM   #1195
Hotflare
Hotflare's Avatar
189
Drives: 2018 YMB M3 Comp
2018 BMW M3  [9.50]
Originally Posted by Bmm34 View Post
Hello, I'm a new member to the forum. I'm on my 2nd BMW. First was a 2009 335I and now I have a 2018 x5 35d.
About two months ago I started to have some rough idle issues mostly on a cold start but sometimes even when it was warm. The RPMs would fluctuate when I first start it up. It's progressively gotten worse and in the last month it has actually stalled a few times and the rough idle is more severe when it happens. I've noticed it happens more often when I back out of my driveway vs driving out, but it doesn't do it on every cold start.
I've had the steering module replaced under warranty and was told by the BMW dealership that that could potentially rectify the issue. They didn't see any other faults when doing a diagnostics.
Unfortunately the rough idle has persisted and so I was hopeful it might be the EGR causing the issue. I had a new one on order to be replaced under warranty. The EGR was replaced today and after I got it home and it sat for a bit, I took it out and it the rough idle happened again. The dealership can not replicate the issue.
Any advice would be appreciated. If I'm leaving out pertinent information, please let me know.
62,000km
Thanks
Mine is doing this too. Ever find the problem?
      07-28-2023, 10:48 AM   #1196
FREE100KSECRET
Drives: BMW e70 4.8
BMW F15 40e Drive Malfunction Codes
Greetings,
I am curious on issues related to codes for Drive Malfunctions. I had several codes which all related to low voltage. I have 2016 and when I checked battery which died, it did charge back up, but given it is near 7 years old, I changed it out with a new one. Problem is I get same codes and engine starts and then stops instantly. EDrive battery is near depleted, but all I want is engine to run at this point and it won't start.
I know I need to register battery, so does anyone have the INSTA download to avoid having it towed to stealership service just to get battery registered for a couple hundred dollars given the $190 labor rate now. Crazy. The codes are all related to low voltage, P1ACF, P1ADI, P123B, P18FD, P1ACF, Example of code description below.
The diagnosis monitors the reception of a control signal from the EGS.
The fault is detected if the EME receives a control signal from the EGS requesting the deactivation of the electrical machine (zero torque).
Anyone had to deal with this issue before? I am new to the 40e technology.
Thanks,
      07-31-2023, 10:54 AM   #1197
KNRESQ
KNRESQ
Drives: Bmw x6m
Hey I’m in NY but I took mine to a wheel repair shop, my rims are two toned and they did a great job making them like new
      08-06-2023, 06:48 PM   #1198
M_Bimmer
M_Bimmer's Avatar
583
Drives: G12 B7, G07 XB7, F02 B7, 991.1
'16 X5 Cylinder Head Cover Oil Leak & Many Faults
My neighbor's '16 X5 3.5i has been leaking oil for some time now, and is no longer under warranty. With 55K miles, and an estimate of $2,500 for a gasket replacement on the valve cover by the shop, I went ahead and dug in for him, after he bought a $60 BMW gasket.
Well, we ended up needed some other seals, but I decided, since the firewall parts and the air inlet parts were already off, I'd check the M6 cover bolts.
Front end of the N55 engine M6's (8.5 Nm torque) were really tight, and as I got to the rear, some required a quarter turn, but the bolt under the O2 sensor harnesses, required over 6 full turns before it even was finger tight.
Doubt that this screw was even installed from the factory....
His wife is not really happy that she's been inhaling emissions leaking from the head cover for so long.....
The PCV is bod, so waiting for the new BMW valve cover to come in and new BMW AGM battery.....but not looking forward to doing this valve cover job in whole. A few places were a pain the ass.
      08-14-2023, 07:42 AM   #1199
50iXman
50iXman's Avatar
34
Drives: 2014 X5
new forum member I posted my concern in the main forum. Is this a better place?
Looking forward to all of the advice!
      08-21-2023, 06:12 PM   #1200
Mando
Mando's Avatar
Drives: BMW X5 F15, BMW 228i, Porsche.
Hello guys, I am stomped . Can’t find what is caused a CEL. I get this code
160504 Crankcase ventilation heating, activation: Line disconnection
I changed the vent on top of the intake, new batteries, oil change, and can’t get rid of it. Clear codes and rescan
Anyone? Thank you
      08-31-2023, 05:01 PM   #1201
bsuciu2023
Drives: BMW x5
what is this sign ?
I just replaced my battery 1200$ and this sign shows my battery level if is indeed my battery level. is this correct?
      09-11-2023, 11:21 PM   #1202
Tomcat_F15_STL
Tomcat_F15_STL's Avatar
150
Drives: BMW F15
Full disclosure, I don't own one, but I see the X5 40e plug-in hybrid has a few modes you can choose from - each affecting how the lithium battery is used & charged.
Plugging it in, "BMW estimates that a full charge using the X5 xDrive45e’s 3.7 kW charger takes just over five hours. This is based on using a capable 240-volt, Level 2 home charging station, such as the JuiceBox 32."
Further, "The eDrive button allows the driver to choose between three eDrive modes: the standard AUTO eDRIVE mode, the purely electric MAX eDRIVE mode and the SAVE BATTERY mode, which maintains the charging status at a constant level."
Maybe you should ask your local service advisor to check your settings to better understand if you have a real problem or have a driving style not conducive to the operating mode you have selected.
      09-18-2023, 01:49 AM   #1203
EnzoCali
Drives: X5 F15, 535 F10
Originally Posted by cc3 View Post
Rattle from tailgate driving me mad despite visit to dealer
Nav and radio turned off while driving then re booted itself after a couple of miles.
rattle comes from the gate latch. very easy to fix. stuff with grease or replace.
      10-10-2023, 06:33 AM   #1204
mindhealer
Head Doc X-5
Drives: BMW X5
Fuel Range Indicator next to Fuel Gauge (2017 X5)
Good morning all. I was messing around with my setting the other day and how, I don't know but I became a magician and made the fuel range indicator (the little gas tank disappear LOL) I've been through numerous posts and read through even more directions but I can't find out how to turn it back it back on. Hopefully it's something simple, which I imagine it is and someone out there in Bimmerpost world knows how to help me turn it back. I know it sounds silly but it gave me a sense of comfort having it on and I'm a creature of change lol
Here's a picture of the fuel indicater below so you all know what I'm referring to. Thanks so very much for alll your help and hope everyone has a great day. Oh....it's a 2017 BMW X5 xdrive35 (F15 style)
Name:  fuel range BMW.JPG
      10-10-2023, 05:36 PM   #1205
beats
beats's Avatar
225
Drives: 2015 911 GTS
Attachment 3296262
If you are referring to the white dot the arrows are pointing to, I thought that was the amount of gas the car estimated would be left when you reached your destination using NAV? The range in terms of total distance can be toggled on by using the BC button on the end of the stalk.
      10-11-2023, 10:47 PM   #1206
JRgully
Drives: '18 X5 35d F15, '07 335I E93
2018 X5 35d  [10.00]
2007 335I  [10.00]
Fog Light
Any one have a fix for replacing the stock fog light with LED and not getting fog light errors? Or maybe another option I haven't thought of before??
      10-12-2023, 02:06 PM   #1207
MartindaleX5
MartindaleX5's Avatar
112
Drives: F
Assuming you’re replacing the OEM bulb with an LED bulb, you’ll need to code so you don’t throw an error. You can easily do this via Bimmercode. If you do a search on the forum you’ll find plenty of info. Best of luck.
      11-01-2023, 11:26 AM   #1208
Jbi
Drives: BMW X5 and 520i
There is whistling noise when the car about to stop
I'm having an 2014 X5 with N55 engine, recently I realized that when the car is about to stop, there is whistling noise from the front, and if I turn off the auto start/stop, the noise is gone, does anyone had same issue? and how it was solved. thanks.
      11-14-2023, 05:08 PM   #1209
DaveM1949
Drives: BMW X3, BMW X5
F15 Steering Wheel stopped telescoping
My 2016 X5's steering wheel stopped telescoping in and out. Doesn't retract when car is shut off and column switch just clicks when pushed or pulled up. The tilt works fine. I've heard that some people have found metal bits from the gears inside the column. Also have read that the motor can seize up and a couple of guys got it working by just banging hard on the wheel several times. The dealer wants to replace the steering column for $4,000! The position is fine for me where it froze. I'd just like to find a better way to get it working again for less than 4K! Anyone have any comments?
      01-25-2024, 03:09 PM   #1210
ocbrad1
ocbrad1's Avatar
Drives: 2016 BMW X5 35i, 2020 Tesla 3
Lightbulb Weird Headlight Issue
2016 X5 x-drive 35i with the standard HID lights. Just before I rolled it over 100k miles, I noticed a lot of oncoming drivers flashing their high-beams at me. I had turned off the high-beams, verified by the fog lights coming back on. Unfortunately, whatever the mechanism is that adjusts the single HID bulb between low and high-beams (just give us the separate high-beam bulbs in the otherwise vacant inboard locations) is sticking on the driver's side. The passenger side "rotates down" (or whatever the actual function is, a filter?) but the driver's side stays in the high-beam position. But because it thinks that it's gone back to low-beams, the fog lights do come back on. Unfortunately, the driver's side lights (closest to oncoming traffic, natch) stay in the high-beam position. I can get out of the car with the headlights on, hit the top of the light housing with my fist, and it will rotate into the low-beam position. I don't know what the mechanism is that makes the shift between low and high, but presumably it is some sort of actual mechanical function that is sticking. I went to my dealer in the hopes that they would be able to find the right hinge or whatever to lubricate and I'd be on my way, only down a few hundred bucks. Nope. They said that it's broken, can't be fixed, and a new housing will only set me back $3200 or something ridiculous like that.
There has to be something mechanical that actuates the shift between low and high beams, because I can look at the light beam projected on my garage door when I hit the light housing, and I watch the beam literally angle down into the low-beam position. I don't know if there's some visor or something that normally sits over the top quarter of the projection that rotates up when high-beams are activated, or if the actual socket/housing that the bulbs are situated in itself rotates up or down based on whether high-beams are turned on or off. It seems weird enough that it's probably a common problem. Any thoughts out there?
