08-08-2015, 07:43 PM | #1 |
Rep 130
Drives: 2015 M235i xDrive
X5 M Sport Wheel Spacers
Just wondering if anyone could recommend wheel spacers for my new X5 M Sport. Not exactly sure on the size but if someone could let me know the part# and exact size, that would be awesome. I'm assuming H&R are the ones to get.
Edit: Forgot to mention I'm on the 19" 467 M wheels. Thanks in advance....
Current: 2015 M235i F22 BSM (FBO)
Current: 2015 X5 M Sport CBM (hers) Previous: 2008 335i E90 Tiag (FBO) Last edited by jetvet; 08-09-2015 at 08:18 AM.. |
08-08-2015, 07:58 PM | #2 |
#dubspec
6337
Rep 5,201
I just put 12.5 mm spacers in the rear from ecs tuning. Front is almost flush.
08-08-2015, 10:33 PM | #3 |
Rep 5,483
Any one have pics with the spacers installed on 469M?
I have a set of 10 or 12mm spacers from my previous E64 M6. Would they fit ?
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
08-08-2015, 10:36 PM | #4 |
#dubspec
6337
Rep 5,201
same widths and offset as 469 wheels. 12.5mm rears
as for your old spacers, check if the center bore and thread pitch on the bolts is the same on ecs tuning
08-09-2015, 02:23 AM | #5 |
Rep 1,181
Wow, 12.5mm pushed the rears out that much? Looks like it is really flush or maybe even poking out a little. Do you have a pic directly from the back?
This will really help me decide whether to go with 12.5mm or perhaps ratchet down to 10mm. Thanks in advance...
08-09-2015, 07:04 AM | #6 | |
Rep 5,483
What wheels are those? Your car looks great, nice to see you are from Ontario as well Have you ever considered lowering your car? I don't want to lower and SUV but I plan to get 21s or 22s and I feel like the wheel gap will kill me
Current:
08-09-2015, 07:39 AM | #7 |
#dubspec
6337
Rep 5,201
i am running 22" wheels, and i was planning on lowering the x5 also, but after mounting the larger wheels with adaptive suspension the wheel gap wasnt bad at all, especially considering this is an SUV not a wagon. i might do the ac schnitzer 1" spring and links in the future but i am satisfied with the ride height now
08-09-2015, 08:11 AM | #8 | |
Rep 5,483
I saw a pic of a white X5 lowered a couple weeks back here on the forum, I think it was H&R Springs though and it made it look like a station wagon, it was also riding on the stock 20s which looked both small and the rear wheel was about an inch inside the wheel wells.
Current:
08-09-2015, 10:55 AM | #9 |
#dubspec
6337
Rep 5,201
Yes. 15' in Canada get adaptive and digital cluster standard on msport
08-09-2015, 01:01 PM | #10 | |
Rep 130
I looked on ECSTuning but all they have are Wheel Spacer/Hub Adapters that take the center bore from 74.1 mm to 72. 6mm. It's to my understanding the 476 M wheels are 74.1.
Current: 2015 X5 M Sport CBM (hers) Previous: 2008 335i E90 Tiag (FBO) |
08-09-2015, 02:11 PM | #11 |
Rep 1,181
Here is the 12.5mm spacer/bolt kit.
http://www.ecstuning.com/Search/Site...0406/ES240406/ |
08-09-2015, 02:50 PM | #12 |
Rep 222
personally I don't think the 469M (20") wheels need spacers, but using the 467M (19") wheels, I definitely need them in the rear ... I put H&R 3075741 pair in the rear, these are 15mm each side with long bolts included ... pic attached It probably needs even more, so I might go to the next size up which are 22.5mm each side H&R 45757404 ... they are DRA rather than DR style Here is the 15mm set for $148 Here is the 22.5mm set for $168 . |
Slickrick2211.00 |
08-09-2015, 03:33 PM | #13 | |
#dubspec
6337
Rep 5,201
08-09-2015, 07:39 PM | #15 | |
Rep 130
Slickrick2211.00 |
08-11-2016, 03:23 PM | #18 | |
Rep 77
08-11-2016, 05:54 PM | #19 |
Rep 1,547
https://www.ecstuning.com/BMW-F15-X5...heels/Spacers/
ECS carries their own brand, as well as Turner. I got my H&R spacers & lugs from Ben @ RGSport.
08-16-2016, 02:48 PM | #20 | |
Rep 51
08-16-2016, 05:10 PM | #21 |
Self-Deprecating Narcissist
7266
Rep 6,561
Get the H&R DR spacer that is hub centric and made for your vehicle. Do not use cheap ECS bolts. They strip easily their threading erodes and they rust. The conical and ball seat portions wear poorly and do not hold wheels against the hub after a few thousand miles. You will be replacing them.
11-23-2016, 04:01 PM | #22 |
Rep 59
Drives: BMW X5 - F15 M Sport
I installed the 22.5mm (per side) from H&R (Part #: BM45757404) on my F15 M Sport with 19'' 467m wheels.
Here are some before after pictures:
2015 BMW X5 35d | Space Grey | M Sport | LED Lighting Package | Cold Weather Package | Premium Package
469M Wheels | Black M-Style kidneys | Front window tints |
Slickrick2211.00 |
