      08-08-2015, 07:43 PM   #1
jetvet
jetvet's Avatar
34
Drives: 2015 M235i xDrive
X5 M Sport Wheel Spacers
Just wondering if anyone could recommend wheel spacers for my new X5 M Sport. Not exactly sure on the size but if someone could let me know the part# and exact size, that would be awesome. I'm assuming H&R are the ones to get.
Edit: Forgot to mention I'm on the 19" 467 M wheels.
Thanks in advance....
Current: 2015 M235i F22 BSM (FBO)
Current: 2015 X5 M Sport CBM (hers)
Previous: 2008 335i E90 Tiag (FBO)
      08-08-2015, 07:58 PM   #2
dubsesd
#dubspec
dubsesd's Avatar
6337
Drives: G05 X5/ 2016 F80 M3 INDVL
I just put 12.5 mm spacers in the rear from ecs tuning. Front is almost flush.
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow
instagram: @ dubsesd
      08-08-2015, 10:33 PM   #3
SlammedR8
SlammedR8's Avatar
Drives: 2019 X5 40i/2020 R8 V10 Spyder
Any one have pics with the spacers installed on 469M?
I have a set of 10 or 12mm spacers from my previous E64 M6. Would they fit ?
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
      08-08-2015, 10:36 PM   #4
dubsesd
#dubspec
dubsesd's Avatar
6337
same widths and offset as 469 wheels. 12.5mm rears
as for your old spacers, check if the center bore and thread pitch on the bolts is the same on ecs tuning
      08-09-2015, 02:23 AM   #5
Doanster
Doanster's Avatar
627
Wow, 12.5mm pushed the rears out that much? Looks like it is really flush or maybe even poking out a little. Do you have a pic directly from the back?
This will really help me decide whether to go with 12.5mm or perhaps ratchet down to 10mm. Thanks in advance...
      08-09-2015, 07:04 AM   #6
SlammedR8
SlammedR8's Avatar
That looks great! Perhaps even a tad too aggressive for me. Just to confirm, you are not running any spacers in the front, but only in the rear?
What wheels are those? Your car looks great, nice to see you are from Ontario as well
Have you ever considered lowering your car? I don't want to lower and SUV but I plan to get 21s or 22s and I feel like the wheel gap will kill me
Current:
      08-09-2015, 07:39 AM   #7
dubsesd
#dubspec
dubsesd's Avatar
6337
i am running 22" wheels, and i was planning on lowering the x5 also, but after mounting the larger wheels with adaptive suspension the wheel gap wasnt bad at all, especially considering this is an SUV not a wagon. i might do the ac schnitzer 1" spring and links in the future but i am satisfied with the ride height now
      08-09-2015, 08:11 AM   #8
SlammedR8
SlammedR8's Avatar
I think I will have adaptive suspension as well, isn't it standard here in Canada on the 15s?
I saw a pic of a white X5 lowered a couple weeks back here on the forum, I think it was H&R Springs though and it made it look like a station wagon, it was also riding on the stock 20s which looked both small and the rear wheel was about an inch inside the wheel wells.
Current:
      08-09-2015, 10:55 AM   #9
dubsesd
#dubspec
dubsesd's Avatar
6337
Yes. 15' in Canada get adaptive and digital cluster standard on msport
      08-09-2015, 01:01 PM   #10
jetvet
jetvet's Avatar
34
Yeah but it looks like you have 20" rims and I'm assuming the offset is different. I have the 19" 467 M wheels.
I looked on ECSTuning but all they have are Wheel Spacer/Hub Adapters that take the center bore from 74.1 mm to 72. 6mm. It's to my understanding the 476 M wheels are 74.1.
      08-09-2015, 02:11 PM   #11
Doanster
Doanster's Avatar
627
Here is the 12.5mm spacer/bolt kit.
http://www.ecstuning.com/Search/Site...0406/ES240406/
      08-09-2015, 02:50 PM   #12
wearenh
Drives: 2015 x5 x35i DHP
personally I don't think the 469M (20") wheels need spacers, but using the 467M (19")
wheels, I definitely need them in the rear ... I put H&R 3075741 pair in the rear, these
are 15mm each side with long bolts included ... pic attached
It probably needs even more, so I might go to the next size up which are 22.5mm
each side H&R 45757404 ... they are DRA rather than DR style
Here is the 15mm set for $148
Here is the 22.5mm set for $168
      08-09-2015, 03:33 PM   #13
dubsesd
#dubspec
dubsesd's Avatar
6337
Make sure it's for a f15. Bmw uses different pitch thread on their cars
      08-09-2015, 06:23 PM   #14
BTT 335i
BTT 335i's Avatar
Drives: X5 F15 M Sport- F30 M Sport
469 Wheels with ECS 15" mm Wheel spacers looks perfect.
      08-09-2015, 07:39 PM   #15
jetvet
jetvet's Avatar
34
Actually, I think those 15 mm look great. Appreciate the detailed info, I'm going to order some right now.
      08-09-2015, 08:03 PM   #16
wearenh
glad I could help
      08-18-2015, 09:30 PM   #17
PRican//M614
Drives: 2014 BMW M6, 2015 BMW X5...
Hi
I have no idea how to post pics but I'm running 20 mm in rear and nothing front I like the stance
      08-11-2016, 03:23 PM   #18
thaddh
Drives: BMW X5
This one doesn't list the F15 X5 as compatible. When I enter my car details and then select wheels then spacers this option doesn't come up.
      08-11-2016, 05:54 PM   #19
stewy604
stewy604's Avatar
290
https://www.ecstuning.com/BMW-F15-X5...heels/Spacers/
ECS carries their own brand, as well as Turner. I got my H&R spacers & lugs from Ben @ RGSport.
2007 Suzuki GSX-R 750
      08-16-2016, 02:48 PM   #20
quad_drive2
Drives: 2014 BMW X5 35i M-Sport
Here is the link: http://www.rgsportshop.com/index.php...product_id=803
      08-16-2016, 05:10 PM   #21
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
Get the H&R DR spacer that is hub centric and made for your vehicle. Do not use cheap ECS bolts. They strip easily their threading erodes and they rust. The conical and ball seat portions wear poorly and do not hold wheels against the hub after a few thousand miles. You will be replacing them.
      11-23-2016, 04:01 PM   #22
Axel81
Axel81's Avatar
59
Drives: BMW X5 - F15 M Sport
2015 BMW X5 35d  [10.00]
I installed the 22.5mm (per side) from H&R (Part #: BM45757404) on my F15 M Sport with 19'' 467m wheels.
Here are some before after pictures:
2015 BMW X5 35d | Space Grey | M Sport | LED Lighting Package | Cold Weather Package | Premium Package
469M Wheels | Black M-Style kidneys | Front window tints
