04-03-2024, 11:40 PM | #1 |
Rep 16
Something feels off balance
Hey y’all,
When driving slow or fast I feel as if a wheel is not balanced, but I’ve taken it two times now for a balance and they said it’s fine. What else could cause this? I feel it more in my seat than the steering wheel. I’m thinking is has something to do with the rear suspension? Is there something I should be looking for? Thanks! |
04-05-2024, 06:51 PM | #4 |
Cattlecar
44
Rep 141
Can you define the shake more? Tire imbalance is lower frequency (slower) and typically is a higher amplitude shake that is 60MPH and up. If it is front driveshaft then it is higher frequency and lower amplitude and starts at lower speed, maybe 40 mph. Suspension bushings has always been more like tire shake on any BMW I've ever experienced it.
04-05-2024, 11:03 PM | #5 | |
Rep 16
04-19-2024, 08:10 PM | #6 |
Rep 299
I've been noticing something similar. I would describe it more as a wobble. First thing that comes to mind is what a bent axle would feel like, but I know I haven't hit anything that could cause damage.
I feel it most between 10 to 45 mph. The whole car wobbles side to side and it definitely feels like it emanates from the rear. Time to go research thrust arms. I only have 68K miles on it but who knows how it was driven for the first 50K before I got it. |
04-19-2024, 09:26 PM | #7 |
85
Rep 370
there is an app which measures vibration and can help diagnostic those issues. I have never used so far but heard good reviews. It is $100 ... but maybe can save you a lot of money.
04-20-2024, 03:04 PM | #9 |
208
Rep 305
Before spending any money, I would at least do a visual inspection, followed by the good old pry bar test. I would check wheel weights, suspension arms, axle boots, guibo, literally anything that moves under the car.
Does the problem go away when you're off the throttle, then return when you're back on it? Or is it constant? |
04-21-2024, 12:02 PM | #10 | |
Rep 16
_ObiJon207.50 |
04-21-2024, 03:58 PM | #11 |
208
Rep 305
Let us know how it goes. Didn't mention it in my last post but take a look at the center support bearing for the rear driveshaft too.
