      01-09-2018, 01:36 PM   #573
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Oh well that's good to know. Weird why many others think otherwise. Cool. I've also never noticed a difference between the two ports. Exhaust comes out both.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      01-12-2018, 08:51 PM   #574
Rhinowso
Rhinowso's Avatar
Drives: 2014 X5 35i
I just finished up coding VLD in my garage via the bimmercodeapp with the help of the F15 X5 cheat sheet. From the cheat sheet, I changed a value in "LUT_FLC_FORWARDLIGHTING_Y" and in "C_AFS_ENA". After coding, I tested it out by turning my fog lights on/off as well as the brights. Just from what I saw, it appeared that the only headlight that was adjusting was the left. When coding I thought I saw a module named "LUT_FLC_FORWARDLIGHTING_X". Does this correspond to the right? Do I need to change this as well? Thank you!
      01-13-2018, 12:01 PM   #575
CeeTeeX5
That’s a good question and I have noticed my pass side light doesn’t pan out like the VLD description says it should... Might be worth checking on the main coding thread. I didn’t touch that one since I didn’t see it on the cheat sheet but it’s posible it needs to be codes too.
      01-19-2018, 11:24 AM   #576
candm
candm's Avatar
Drives: 2016 BMW X5 xDrive40e
Just went in for my first oil change for the X5 40e and while there they did a software update for a pre ignition fix.
Of course I expected to lose codings and sure enough I did.
Everything is fine except I used to have HUD Turn Signals but when I tried to re apply the coding I noticed it was gone from the HUD section. I also checked the BimmerCode website and under HUD it only lists these:
HUD entertainment list
Codable in KOMBI FPK_I12, KOMBI L6 BO
HUD telephone calls
Codable in KOMBI L6 BO
HUD telephone list
HUD voice input
So is the ability to have HUD Turn Signals gone with the latest app updates?
2016 F15 X5 xDrive40e Alpine/Terra
2013 E84 X1 xDrive28 Apline/Terra
      01-20-2018, 03:39 PM   #577
Bt12
Drives: 2018 X5,2018 m2, 2018 x1
Has anyone been able to figure out how to do EASY entry? With the seats? I can’t for the life of me figure it out...in expert mode
Using bimmercode
      01-20-2018, 04:50 PM   #578
CeeTeeX5
Tried to code 100% DRL with low beams today and it didn’t seem to want to take the change. Anyone have success with it?
      01-21-2018, 02:35 PM   #579
ABZ101
ABZ101's Avatar
161
Drives: X3M | X5 F15
anyone able to turn off the yellow amber in the headlights?
      01-28-2018, 11:45 PM   #580
perry8912
Drives: bmw x5
Got two questions guys,
Via bimmercode,
1,Anyone knows how to disable the auto steering wheel movements after shut off the engine? (Disable easy entry/exit function)?
2, How to lower the start speed for the blind spot detection? The default for that function is about 30mph, can I make it to 10 or 20?
Thanks guys....
      01-29-2018, 12:00 AM   #581
CeeTeeX5
1. You should be able to turn off easy exit in idrive
2. Go to ICM then expert mode, search for C_ZSW_Aktivierunggeschwindigkeit_Funktion_low, set to 20km. I heard any lower and it throws error codes.
      01-29-2018, 08:41 AM   #582
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
524
Never seen “easy exit” option on iDrive
      01-29-2018, 09:31 AM   #583
perry8912
Drives: bmw x5
1, Unfortunately, my x5 doesn’t have the no easy exit option in idrive...
2, Can it be done via bimmercode? I can’t find that option....
      01-29-2018, 11:31 AM   #584
CeeTeeX5
1. hmm...maybe I did code it in bimmercode.
2. Yes, that is how I did it. Look for the ICMQL Module, then go to expert mode and look for 3000 Daten section. Select it and then search or scroll to find C_ZSW_Aktivierunggeschwindigkeit_Funktion_low, select it and change the speed.
      02-03-2018, 09:26 PM   #585
shezi01
Drives: BMX X5 35i
HUD telephone calls
HUD telephone list
HUD voice input
I believe its gone. Mine went in for service around the holidays and head unit was replaced and now when i try i don't see that option in there as well (turn signals in HUD).
candm18.00
      02-05-2018, 02:29 PM   #586
Mexecutioner
Drives: 2015 X5 xDrive35i
Originally Posted by THATDONFC View Post
Has anyone figured out the blink 5 times setting in bimmercode?
I was able to get this to work a while back ago. Then when I got the MPPK installed they also did other updates which wiped out the coding. I have not been able to get this to work ever since. I suspect that the dealership update has something new that prevents this from working. Tried with both E-sys and BimmerCode and even though they both show it worked the the signals blink just 3 times.
      02-05-2018, 03:23 PM   #587
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
I just started using Bimmercode app today and coded some things, it's great!!
Does anyone know if its okay to leave the Wifi Adapter plugged all the time?
      02-05-2018, 03:26 PM   #588
Dogzyboy
Scotland
86
Drives: X5 M50d
There’s talk of adapters left in the port setting off the alarm.
      02-05-2018, 03:44 PM   #589
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Well, I don't have an alarm
Anyway, it scary that someone can hack into my car while stopping or moving.
      02-05-2018, 04:23 PM   #590
Pkitch
Drives: 2017 X5 4.0e iPerformance
Using bimmercode
I've done it a couple of times.
Go to Seat Module (SM) and then Expert mode.
Search for 'EINAUSSTIEGSHILFE' and you should see the below module. Change to Aktiv.
SM > EINAUSSTIEGSHILFE > Modus_FA_SLV
You might also need to adjust the default 'safety' settings, see this thread for discussion about it; http://www.bimmerfest.com/forums/sho...asy+entry+seat
A little cryptic but you would be able to figure it out, good luck.
      02-06-2018, 06:47 PM   #591
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
Is it safe to assume that foglights can be programmed to run along with the Auto feature?
Same question for adaptive high beams.
      02-07-2018, 06:46 PM   #592
Ljn21
Drives: 2017 X5 x35i
[QUOTE=wjdunn3;22628182]You can set the exhaust flap operation with a different app called Bimmerlink. Its from the same developer that does Bimmercode.
Bimmerlink allows you to set the Ex flap operation as : Auto (default operation), always open, always closed.
Bimmerlink also reads trouble codes, let's you clears codes, as well as some other non-coding functions. I think that app is IOS (Apple) only at this time.[/QUOTE
I bought a 2017 x35i m-sport and bought the vgate/bimmercode...which module/menu is the option in to keep the flaps open? Cant find it...
      02-07-2018, 08:59 PM   #593
CeeTeeX5
You need bimmerLINK not bimmerCODE.
      02-08-2018, 10:16 AM   #594
ABZ101
ABZ101's Avatar
161
what does keeping flaps open do? sorry for the noob question
2020 X3M
2018 X5-Msport
