      12-12-2017, 07:55 AM   #529
CC///M
Drives: BMW X5 M50d
Is it possible to code Apple Car Play?
Thank you.
      12-12-2017, 04:11 PM   #530
SCA
SCA's Avatar
Drives: Multiple BMWs
Thank you.
Not via BimmerCode.
      12-12-2017, 04:56 PM   #531
Dogzyboy
Scotland
86
Drives: X5 M50d
Thank you.
I believe you can buy it from the ConnectedDrive site if you have right correct version of idrive.
      12-13-2017, 05:31 AM   #532
CC///M
Drives: BMW X5 M50d
Originally Posted by SCA View Post
Not via BimmerCode.
But via?
Thanks
      12-19-2017, 01:32 PM   #533
ptm1nh
ptm1nh's Avatar
Vietnam
202
Drives: Blue Cars
I decided to give this a try and am able to change the ConnectedDrive splash screen to M display plus delete the Legal disclaimer but still experience some issues:
1. Not able to active "HUD turn signal (2/2)" under "Headunit". After switching this to "Active", my HUD settings doesn't show any new options regarding turn signals at all.
2. Not able to active "Fold mirrors when locking vehicle with Comfort Access" and "Unfold mirrors when unlocking vehicle with Comfort Access" under "Body Domain Controller". I switched to "Active", Start coding process, everything is successful, but nothing happens. When I reconnect the apps, the value is set back to "Inactive".
3. Also under "Body Domain Controller", I tried switching "Indicator cycles" from 3 to 5 times but my blinkers are still only doing 3. It does show up as 5 times on the apps after reconnecting.
Any thoughts?
      12-19-2017, 05:55 PM   #534
diesel733
Master of one
diesel733's Avatar
Drives: 2018 BMW M3 ZCP IMOLA RED
Thank you.
I know is that on my 2018 X5, it has an option to add Apple car play, but you would have to pay $300 for it. So for the new idrive systems, you can add carplay. The old idrive you probably can't.
      12-19-2017, 06:01 PM   #535
diesel733
Master of one
diesel733's Avatar
Bimmercode is now on version 2.3 just FYI
      12-19-2017, 06:06 PM   #536
diesel733
Master of one
diesel733's Avatar
What I coding on my and verified works would be
What works:
Deactivate Legal Disclaimer
M Splash on Idrive
M Logo on Instrument Cluster
DRL Taillights
HUD Turn Signal
Seat Belt Chime off
Heating Seats temperature raise
Folding mirrors with comfort access and remote
Trunk closing with door button and remote
Start up on Eco Pro always
What doesn't work:
Blinker from 3 to 5 blinks
AC Memory.
      12-20-2017, 01:21 PM   #537
owine
Drives: ‘21 X5 x45e
Originally Posted by xweb10 View Post
It looks like Bimmercode website is directing users to purchase the Vgate iCar Pro Bluetooth 4.0 from Amazon. Will this work with the app? All the other posts here refer to the Wifi version.
Yup that's what i got and works well
Do you use iOS or Android? The iCar Pro BT will not come up on my iPhone.
      12-21-2017, 06:17 AM   #538
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
its "VLINK" turn the wifi on.
      12-21-2017, 11:34 AM   #539
owine
Drives: ‘21 X5 x45e
I purchased the Bluetooth version which was (at a time) linked from the Bimmercode website. It appears they are linking to the WiFi version now.
Anybody with success using the Bluetooth version with iOS?
      12-21-2017, 09:29 PM   #540
CeeTeeX5
Hi All,
I recently purchased a 2018 X5 xDrive35i and I love it! The only problem was that it seemed to be missing some features that my 2012 Jeep Grand Cherokee had that I was surprised were not functional on my X5. Then I found this thread! Thanks to this thread and the Bimmercode app I've successfully coded the following:
Remote open close tailgate
Button close tailgate
Comfort Access mirror folding
Indicators in HUD
Fogs on with high beams and DRL
Door lights in reverse
Removed legal disclaimers
Display temperature and pressure
There are two things i'm having trouble with.
1. I can't the 5 blinks like many others, anyone successfully gotten this to work recently? Any tips?
2. For the mirror folding with remote. Which setting do I need to adjust to not have to hold the lock button? Is it the Comfort closing delay that I need to lower to "no delay"?
Thanks in advance for the assistance!
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
M-Perf Exhaust and lip
2018 X1 28i M-Sport
      12-21-2017, 11:40 PM   #541
Doanster
Doanster's Avatar
627
1. See post #461. I explain why this might be an issue with Bimmercode itself. If the developer is programming module 3068, it'll only work for older I-Step Level cars. Newer ones, module 3069 and a diff function name need to be programmed.
2. Correct. Need to set the delay to zero in Module 3056
KOMFORTSCHLIESSUNG nicht_aktiv aktiv
KOMFORT_SCHLIESSEN werte=0f (~2s) werte=00 (instant)
      12-22-2017, 12:10 AM   #542
CeeTeeX5
Thanks doanster! Coded #2 just now and works like a charm. Now hoping bimmercode comes out with a fix for the 5 blinks.
Doanster626.50
      12-24-2017, 07:25 AM   #543
artem123
artem123's Avatar
250
Drives: G30
I already posted it, but will repeat. I also had problems coding 5 blinks, however, was able to solve in a heartbeat. Code 5 blinks, then go to settings, and chose a new profile, in new profile simply go to lighting and choose 5 blinks.
      12-24-2017, 11:19 AM   #544
///bproden
///bproden's Avatar
286
Drives: 2015 M4
Anyone know how to code the exhaust so both flaps are open for both sides? I hate how exhaust gas is coming out only one side.
2015 ///M4 - Alpine White - My ED
Executive Package / Lighting Package / Black 19's / Adaptive Suspension / Harmon Kardon / DCT
      12-24-2017, 03:04 PM   #545
CeeTeeX5
Tried this today on my 2018 with no luck.
      12-24-2017, 05:24 PM   #546
artem123
artem123's Avatar
250
Drives: G30
Works on my 2017.
      12-24-2017, 08:47 PM   #547
jonboyglx
Drives: 2017 BMW X5 40e
I wish the developer would get the 360 camera and rear camera controls figured out. Its the only thing I havent been able to do yet with the app.
      12-25-2017, 03:09 PM   #548
absolutegtr
Drives: 2015 X5 35i M-sport
How high can you turn up the heated seats?
      12-25-2017, 04:51 PM   #549
CeeTeeX5
Are some of your heated seats really weak? I'm wondering if they have the heat already increased for 2018s. On level 3 after 5 minutes I feel like my ass is on fire.
      12-25-2017, 05:52 PM   #550
Idoktr
Drives: 2015 X5
Is there a code to have the dash gauge lights stay on all the time?
