      12-13-2019, 11:13 AM   #23
pennsiveguy
pennsiveguy's Avatar
Drives: F15 xDrive50i M-sport
Originally Posted by Fastestcolor View Post
So SA at bmw is telling me that the sensors from the wheels and tires I put on are for another car and cannot be reprogrammed. That doesn’t seem accurate to me.
Recap. I had squared 19” 467 rims with good year tires. I swapped them for staggered 20” 469 rims and continental tires. Bought the set complete with tires already mounted and sensors in the wheel so I just bolted on the new wheels and then tried to reset the TPMS and received a malfunction. New 469 wheels came from a CPO x5 of the same year as mine and sensors worked fine on that car.
Is it possible that that car used different type of sensors than my car of the same year uses? The car the wheels came from was an Sdrive and mine is an Xdrive. Would that matter?
Did you actually see the new wheels on an F15/F16 BMW with iDrive reporting tire pressures correctly for all 4 wheels, or are you taking someone's word that they worked?
Should be fairly straighforward to detect the signal from the sensors if they're working properly.
      12-13-2019, 11:17 AM   #24
djrabbi
djrabbi's Avatar
Drives: G05 M50i
SA blowing smoke. I bought cheap TPMS and works great. Maybe there might be something blocking the signal? I actually had my old TPMS in the trunk and car kept reading those till I figured it out. See if a tire shops can see if all TPMS are working first. Get a reading
      12-13-2019, 11:19 AM   #25
Fastestcolor
Drives: Looking
I’m taking his word. It’s a fellow forum member. He said he drove the car home after purchase and took the tires off and had no issues. BMW wants to move all the sensors from my original wheels to the new wheels and swap. $50/tire x 8 = $400
      12-13-2019, 11:29 AM   #26
Fastestcolor
Drives: Looking
So I thought that might be the issue because I have my old wheels in the garage but it’s been at bmw 3 days and they can’t figure it out
Seller has been helpful and communicative btw.
      12-13-2019, 06:24 PM   #27
Fastestcolor
Drives: Looking
Found the problem. Took it to and independent wheel shop recommended by the seller of the wheels. A bit of a drive from me but worth the trip. At first the owner of the shop couldn’t figure it out either as all the sensors were reading on his computer. We took a guess that one or more might be bad and lucked out it was the first one. Replaced it on the spot and everything is perfect. BMW never attempted to replace one as they all were active.
Seller graciously picked up the tab.
Shout out to ubreakwheelfix.com in North Miami/Aventura. Would recommend them for sure.
r33_RGSport12971.00
      12-13-2019, 07:05 PM   #28
djrabbi
djrabbi's Avatar
Drives: G05 M50i
Found the problem. Took it to and independent wheel shop recommended by the seller of the wheels. A bit of a drive from me but worth the trip. At first the owner of the shop couldn't figure it out either as all the sensors were reading on his computer. We took a guess that one or more might be bad and lucked out it was the first one. Replaced it on the spot and everything is perfect. BMW never attempted to replace one as they all were active.
Yup! Happened to me when I sold my oem wheels to someone. She said her car wasn't reading it so I told her to go to discount tire and one TPMS was "dead"
      12-13-2019, 07:22 PM   #29
turboawd
1636
Drives: 2015 X5 35i
So the sensor was reading ok on his computer but was still bad?
      12-13-2019, 11:25 PM   #30
Your thread title mislead me.
I thought it is a new set of wheels where the TPMS are also brand new. lol
I didn't ask you because it is a common sense to put on a new set of TPMS on a new set of wheels instead of moving the existing one.
New set of OEM TPMS is $140-ish. Dismount tire to take a TPMS out from existing wheel is $25/each.
Glad you got it resolved though.
      12-14-2019, 06:45 AM   #31
Fastestcolor
Drives: Looking
Thanks. I had figured if they worked fine on his CPO x5 that he only drove 15 miles, why wouldn’t they work on my car.
      12-14-2019, 06:46 AM   #32
Fastestcolor
Drives: Looking
Yep. That’s what was odd
      12-14-2019, 08:09 AM   #33
In general, TPMS battery life is about 5 years.
So, it is depending where that wheels coming from originally. 2014 model? Then it is about time since 2014 model is manufactured around late 2013.
      03-26-2024, 07:24 PM   #34
1004ron
Drives: 2015 BMW X5 xDrive35i
I have a few TPMS questions I hope you folk can help me with.
I just installed a set of new wheels, tires and TPMS sensors.
I went from the 255/19 to staggered 315/20 and 275/20 and did the initial run with the pressures set at rear 39 and front 35 which the Owners manual suggests for the larger tires.
The pressure for the 255's is rear 44 and front 36.
I initiated the tire pressure reset and took it for a run mostly at 70 mph on the interstate - the progress stalled at 49% and then later failed.
Could it be that the pressures weren't what the system needed for the reset?
Tomorrow I'll give it a try at 44 and front 36 psi.
Edit: How can I code the system for the pressures needed for the wider tires?
See attached image of the sensors - the seller re-confirmed that they're correct for my X5.
If this doesn't work I'm considering the Autel MaxiTPMS TS508WF with Autel/Ascot MX programmable sensors and program the original sensors ID's into the new ones.
Can anyone confirm if this will work?
https://autel.com/us/product/maxitpms-ts508wf/
https://autel.com/us/product/adjusta...nsor-aluminum/
      03-26-2024, 09:49 PM   #35
Qsilver7
Qsilver7's Avatar
Can you verify the sensors are for the f15 X5 and not the G05 X5?
      03-26-2024, 11:04 PM   #36
1004ron
This is what the seller listed, but not sure if I can trust that.
https://www.ebay.com/itm/395114350821
      03-27-2024, 11:09 AM   #37
RED_Y_
Drives: 2014 X5 3.5d
Part number seems to be correct, 36106881891 but there are multiple versions of the TPMS sensors. Did you buy these as new or they are take offs?
      03-27-2024, 11:22 AM   #38
1004ron
Bought new, to go with the new wheels and tires.
My wife is out and about with the pressure at 44 and front 36 psi - if it's still not reset by the time I get home this afternoon I'll purchase the Autel MaxiTPMS TS508WF with Autel/Ascot MX programmable sensors.
      03-27-2024, 02:06 PM   #39
RED_Y_
I don't think its about the pressure, if it gets stuck at certain point usually it means that one of the sensors is faulty.
      03-27-2024, 02:56 PM   #40
Qsilver7
Qsilver7's Avatar
Ditto RED_Y...the TPM sensors used on the f15 X5 are not as complex as the newer G05 X5s.
Just make sure you're following the instructions and if the system still won't reinitialize...then perhaps something is wrong with one or more of the sensors.
FYI: Starting with the f15...the RDC control module is incorporated into the DSC control module...it is no longer a stand alone module.
      03-27-2024, 07:52 PM   #41
1004ron
Thanks for all the help and suggestions.
When I got home today it displayed the system is active but no pressure values displayed.
I then started the reset again and went for a drive - it went smoothly all the way to 99% and hung there for a while and then displayed Active but again no values.
I'm going to buy the kit so that I can assess the existing sensors and if need be clone the old sensors and use those ID's in the new programmable sensors.
      03-28-2024, 10:52 AM   #42
RED_Y_
You don't need to clone or code sensors, as far as they are working and compatible-it should display pressure.
      03-30-2024, 01:54 PM   #43
1004ron
Received the MaxiTOPMS TS508WF today and scanned the sensors currently installed all four responded instantly with the below example image.
This has me more puzzled and unsure of what to do next - I had planned on installing the 4 new MX programmable sensors, but now doubt that will resolve the issue.
Could it be that the existing sensors hex code aren't in the correct format?
      03-30-2024, 02:39 PM   #44
1004ron
Further progress.
A few error codes recorded for all wheels, cleared and the next relearn activity came up with no codes.
Connected to the OBD port it shows pressure for all four sensors, and the LF ID matches what's in the cars ECU. The ID's don't match the ECU for the other three sensors.
Going to head out for a drive and see if the ECU learns the ID's of the other three - will report back after that.
Autel states that the speed should be kept between 19 and 64 mph.
