      03-19-2024, 10:22 PM   #1
DanielN5
DanielN5's Avatar
Drives: Bmw x5 F15 2017 xdrive 35i
Adaptive headlights malfunction
Hello everyone
Im having this issue with my left headlight
The xeno and the signal works fine but the led or angel eyes whatever they call it doesn’t,car never been in a accident and since its a 2017 I doubt the led can actually failed,car has 90000miles so not that much
I took this different mechanic and everybody’s was saying to replace the module for it …I replaced it this morning i took the old one out and put the new one in but nothing still same code and the led wasnt working..not sure on what to do now as the dealer said he want a 199$ dollar for a diagnostic and if they dont find nothing it would go up to 1200$ FOR A DIAGNOSTIC..insane
Is any program like bimmercode or like any instrument that i can use to find whats going on? Like what part is broken? Or if theres something i can try like fuses (i dont know where those are for the lights ) or whatever you guys have had a experience with?
Thank you guys!!!
      03-19-2024, 11:37 PM   #2
Tomcat_F15_STL
Tomcat_F15_STL's Avatar
150
Drives: BMW F15
Got the same fault shortly after bringing home the wife's new-to-us 2018 F15. The fault displayed several times - usually clearing with an engine restart.
Disconnected the Adaptive Headlight Controller cable in the back of each headlight assembly. Sprayed the connections down with CRC QD Electronics Aerosol Cleaner. Allowed to dry & reassembled.
Faults did not return - this has been over two years ago, now.
      03-20-2024, 07:12 AM   #3
DanielN5
DanielN5's Avatar
My code is permanent doesn’t go away…
Should i use bimmerlink or bimmercode or a scan tool? I feel its a little dangerous to spray solutions on the connectors
      03-20-2024, 09:29 AM   #4
crystalworks
crystalworks's Avatar
522
Drives: Many BMW's
It's not dangerous to spray CRC electronics cleaner into connections. IF YOU LET IT DRY. I use it all the time to clean circuit boards and connectors. Amazing stuff.
      03-20-2024, 09:31 AM   #5
DanielN5
DanielN5's Avatar
Ok ill try that and update u guys
      03-20-2024, 09:42 AM   #6
DanielN5
DanielN5's Avatar
Just this connection here? It the connector with a bunch of wires
And how should i spray it and how long it takes to dry? Thank you!
      03-20-2024, 09:43 AM   #7
DanielN5
DanielN5's Avatar
Can i turn off my adaptive headlights so i don’t receive the code on my dash? Like with bimmerlink or bimmer code(?)
2017 X5 xdrive35i
      03-20-2024, 11:40 AM   #8
c00lbeansdude
Drives: x5
I have a 2017 and had a similar warning, but all the lights still worked, but the adaptive part didn’t work. There was a small wiring harness with three green wires that I think went into the motor. One green wire was broken and I had to solder it back.
      03-20-2024, 11:42 AM   #9
DanielN5
DanielN5's Avatar
Where exactly and what it looks like? Also how did u fixed it? Thank you!
      03-26-2024, 09:18 PM   #10
DanielN5
DanielN5's Avatar
This is the code that i got from bimmerlink
I replaced the control module of the headlights but nothing
Should i check the fuse in the domain controller?
How can i open it without braking something??
Thank you
2017 bmw x5 f15
      03-26-2024, 09:45 PM   #11
stocktree
Drives: x5
Did you clean the connector yet?
      03-26-2024, 09:52 PM   #12
DanielN5
DanielN5's Avatar
Which connector?
      03-27-2024, 09:53 AM   #13
stocktree
Drives: x5
Which connector?
Any connector on back of light
      04-08-2024, 08:56 PM   #14
DanielN5
DanielN5's Avatar
Update:
I switched the headlight that is not working (driver side ) to the passenger side and the leds lights work perfectly but when i put it back on the driver side its not working again (works only xenon high beams and signal )
Probably 99.9% it a wiring problem,anybody’s has a idea on what I should look for or has a idea on what’s going on?
Thank you!
