08-30-2020, 08:23 PM | #1 |
1642
Rep 2,995
Drove somewhere. Parked. Then later restarted,now no air comes out of any vents. I mean any vent. No matter what the setting. The blower is at full blast. What the heck is going on?
08-30-2020, 10:21 PM | #2 |
<3 Flat Four
217
Rep 754
i believe inside the dash is the heating/cooling system that has motorized flaps that controls air flow to each zone. sounds like the flaps go to a closed position when the vehicle is parked for some time, and should reinitialize when the vehicle is started. from what i read, it seems like its functions can be read and checked for errors, u may want to start there.
https://www.newtis.info/tisv2/a/en/f...ols/1VnXXu1gPw https://www.newtis.info/tisv2/a/en/f...front/JITImtWl
2011 335is Le Mans Blue
08-30-2020, 10:34 PM | #3 | |
1642
Rep 2,995
08-30-2020, 11:05 PM | #5 | |
<3 Flat Four
217
Rep 754
not sure if carly is comprehensive enough or only ISTA would be able to read into the HVAC. since newtis mentions reading, and runing tests etc on the hvac system, i suspect ull need ISTA to read into it.
08-31-2020, 09:21 AM | #6 |
147
Rep 334
Carly might be able to read. I know when I use BimmerLink you can look at the HVAC module.
Hopefully its not the 4 zone diverter behind the dash. I went through my vehicles old service receipts after I bought it and it had a 26 hr repair job to swap out the actuator behind the dash under warranty. |
08-31-2020, 06:57 PM | #8 | |
<3 Flat Four
217
Rep 754
