      01-31-2024, 01:42 AM   #1
talba
Drives: m4
Internal Coolant Loss F15 X5 M50d
Hey
My car has been losing coolant after about 100 miles. The light comes on, and the tank is quite empty.
I had it sent to BMW through a "friend" who works there and they claimed to have pressure tested it and there were no external leaks. So they apparently discovered that 3 seals had blown and changed them. They did a coolant flush, oil change and gave the car back to me
I've been https://9apps.ooo/ monitoring the coolant level every morning when cold, and I'm starting to see it getting low again.
The car had the EGR recall done a few months ago. Is it possible that the engine is building so much pressure in the cooling system that brand new seals can blow AGAIN in 100 miles of driving? Would there be any other signs to look for or are they BS'ing me.
Any help or guidance would be greatly appreciated
Edwardsc1255.50
      01-31-2024, 10:10 AM   #2
Edwardsc1
Edwardsc1's Avatar
Drives: 2015 BMW X5 50i
2015 BMW X5 50i  [0.00]
I have a 50i, so little bit different with respect to the engines, but I was having coolant loss issues as well, about as much as you are. I had to have my expansion tank replaced because there was a slight crack in the bottom of it, and I also had to have all my T-joint connections replaced as well because they were leaking.
Could also be a small leak in the radiator if there was a puncture from a rock, but that's probably not as likely.
Some of those plastic pieces begin to break after going through so many heat cycles over the years. I had my T-joints replaced with brass ones and have been good to.
2015 X5 50i - Current
2011 E92 M3 - Sold
2016 F30 340i - Sold
      01-31-2024, 01:09 PM   #3
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Depending on how the coolant was replaced, it might take a while to get all the air bubbles from the entire system out. I would not worry unless the low level warning comes back.
      01-31-2024, 01:15 PM   #4
RED_Y_
Drives: 2014 X5 3.5d
Wonder if this is a real user or a bot, got a URL to malware web site in the text.
      01-31-2024, 10:50 PM   #5
Mo5es786
Drives: F15 X5 M50D, F20 120D
This is definitely a bot post. I'm the author of the original post on Reddit, and actually came here this morning to post for advice and was quite surprised to see my initial post here
Daily Drive - N55 335i
Edwardsc1255.50
      01-31-2024, 10:55 PM   #6
Mo5es786
I would hope that BMW would have filled and bled the system properly. I initially thought this as well but over the last 3 days (+- 150km) it's gone from being just over the max line to below the minimum line this morning
      01-31-2024, 10:59 PM   #7
Mo5es786
Did they discover the cracks by means of a pressure test? Another BMW had supposedly pressure tested the system over a few days and found no external leaks and they also tested the head gasket and found it not be leaking
      01-31-2024, 11:12 PM   #8
Mo5es786
Just to give some insight on how this has developed
I bought this car used, had it serviced and the EGR Recall done, did about 5000km and then one day the low coolant light came on. There was fresh oil in the coolant and my mechanic said the oil cooler had failed and we changed it. I must have driven it for another month and the low coolant light came back on and there was residual oil in the expansion tank and it was dry. Topped it off, drove it for 3 more days and it happened again. At that point my mechanic took it to BMW and had it pressure tested while I was away. They said all is fine and gave the car back. I drove it for another 3 days and yet again the light came on and the tank was empty, filled it up and still noticed residual oil.
It got sent to a different BMW dealer, where it spent the better part of 2 weeks. It came back and they said they had changed the EGR seal, Oil Cooler Seal and OFH Seal and flushed the system. They said the seals had "blown"
The car was jerking on cold start which has stopped now so I'm attributing that to the seals actually having being defective. But the coolant is still leaking internally and nobody can seem to figure it out. I had been getting a burning smell only on a cold start in the mornings from the vents and that's still there (not sure if relevant)
      02-03-2024, 08:17 AM   #9
Edwardsc1
Edwardsc1's Avatar
Yes, the pressure test found the leak when the tank was cracked. They said they pressure tested the system again after replacing the tank and that all was fine, but it took less than a month for my plastic T-joints to fail after that, so I think some of them were probably leaking a little bit already.
As far as the other issues, I won't be able to give any insight as to anything with the EGR since mine is a 50i. I've never owned a diesel car so I'm not sure what temperaments those vehicles might have. With that residual oil and coolant loss, it would seem to me that some rubber/plastic component somewhere is cracked and leaking
2011 E92 M3 - Sold
      02-04-2024, 04:16 PM   #10
suitedcboy
Cattlecar
44
Drives: 2016 X5 50i MSport
EGR coolers in general are well known to have leaks that start leaking only after the cooler has heated up to normal temp. They can leak into exhaust or the boost pressure is higher than cooling system pressure so they also can leak only when boost pressure is high into cooling system and overpressure and open relief valve in coolant tank cap. Is there any dried coolant residue on top of coolant tank? Another way to detect it is with a pressure gauge T'd into a coolant hose. The coolant pressure will jump higher instantly under hard throttle if the cooler leaks and is venting into cooling system
      04-28-2024, 11:29 PM   #11
Mo5es786
Update - The dealership diagnosed a failed head gasket
I've since had them repair it. But it seems like there's still some coolant loss. Approx 100-300ml every 300km. I've only had the car back now for about a week and done around 800km since the gasket change. When I noticed the coolant in the expansion tank getting less I took it back to them but they have pressure tested, refilled coolant and said they can't see any leaks
The EGR was replaced under recall and they inspected the new EGR and said all was fine there as well.
Currently I'm monitoring the level every morning after the car sits overnight (8-10hrs). Is it possible that there's a lot of air trapped in the system causing the level to appear to drop in the expansion tank? I mean the entire engine and cooling system was essentially opened. The cars temp seems consistent and isn't overheating and I haven't let the tank get so empty that it's given me a low coolant warning
Pretty much at a loss here as to what to do next if it's still taking coolant. Is there anything else left to test or should I take it to an Indie instead. I just feel like if I paid the dealership to fix the problem then I shouldn't have to pay an Indie to diagnose and fix essentially the same symptoms that it went it for the first time
      04-29-2024, 09:16 AM   #12
CatalinP
I can only say that, after the EGR cooler was replaced at the Dealer, it took me 1 week of daily coolant level check and about 1 liter of it until the level became steady. It is very difficult to get all the trapped air out even if you vacuum fill it. It bleeds itself over time.
      04-29-2024, 01:21 PM   #13
Mo5es786
Thanks, that reassuring. I'm hoping trapped air is all it is
      05-05-2024, 11:29 PM   #14
Mo5es786
Today hit the 1L mark. I'm going to run it another week and see if it still drops. Were you having consistent daily drops in the expansion tank level?
      05-06-2024, 01:50 AM   #15
CatalinP
More or less constant drop. Please bear in mind we do not have the same engine, as mine is a 30d only. I would expect more coolant intake on yours.
      05-06-2024, 02:30 AM   #16
Mo5es786
15.4 Liter Coolant Capacity
I'd find it hard it to believe that it could have anything more than 2-3L of air trapped inside after being vacuum filled and bled
I'm probably going to get some UV Dye and drop it in to be sure there's no leaks
      05-06-2024, 08:01 AM   #17
m4forum
85
Drives: M3
I spent few months trying to figure out an internal leakage on my 2014 X5 35d ... different engine but same approach which can be used.
Identify the potential leakage path, consequences/how to identify it.
1) coolant on combustion chamber (constant white smoke on exhaust, smell, bubbles on
coolant expansion tank - there is cheap test which analysis coolant and exhaust gas)
2) coolant on oil (after engine is off coolant remains pressurize but oil system has no pressure. Coolant gets into oil (oil analysis -> look for signs K or P)
3) Oil on coolant (when engine runs oil pressure is 4-5x higher than coolant). Milky coolant is an indication (this is really severe)
4) EGR leakage (internal leakage to the EGR, visual inspection on EGR or intake manifold)
5) transmission cooler (cross contamination, milky oil)
6) SRC urea injector (believe or not there is coolant going through this injector)
7) turbo cooling (on your case there are a lot of turbos)
8) others.....
Unless engine got overheated head gasket rarely fail ... sometimes identified as root cause of internal coolant leakage but not always right.
In my case was a bad EGR (35d has 2 EGRs) replaced the EGR next to the exhaust manifold. What I found very interesting was that oil analysis when EGR was leaking shows coolant contamination on engine oil. In some way the coolant got into the oil.
      05-06-2024, 09:59 AM   #18
Mo5es786
8) others.....
I bought this car used and the dealer feels that the previous owner used some kind of stop leak to temporarily seal the gasket. When I got the car I did the EGR recall and would've had new coolant and subsequently washed out the stop leak and that's when I started having trouble with the cooling system.
They also said that they physically saw the deteriorated Head Gasket when they stripped the engine. When I took it back after I found the coolant had been decreasing they kept it overnight and did a few pressure tests the next day and apparently all were fine. They also inspected the new EGR to rule leakage out.
My oil level seems to be between min and max and if the coolant was being lost in the oil I'd expect it to have increased a bit.
Until I get the UV Dye I'm going to continue to bleed and top up. I do notice that the passenger front vent blows bursts of cold air when the heater is on but I also have a stratification motor error so it's likely unrelated.
      05-06-2024, 02:30 PM   #19
m4forum
85
Drives: M3
At least the most expensive repair was done ... everything else will be much cheaper from here.
If this is an internal leakage how the UV Dye will help? Maybe can help identify cross contamination but unless each part is evaluated individually it cannot pin point to a specific component.
Keep us informed.
      05-06-2024, 02:42 PM   #20
Mo5es786
I'm hoping the dye will rule out any external leakage. It might be that's it leaking externally but only when up to operating temperature
Also as far as possible I'm trying to avoid leaving at the dealer just to have more pressure tests done and be told that they're all fine. If I don't come right within the next week and I have to fill another liter of coolant then that will rule out air in the system for me. I can't imagine having over 2L of air trapped in a system that was vaccum filled
      05-08-2024, 05:22 AM   #21
Mo5es786
I had a block test for exhaust gas and a pressure test done independently. The block test was negative for exhaust fumes but the pressure gauge dropped almost immediately
The lower radiator hose/Coupler was weeping and there was dried coolant around a hose above the oil cooler. I'm going to get the car back to the dealer and ask them to verify the test and put new pipes all around
      05-17-2024, 12:24 AM   #22
Mo5es786
Update - I put the UV Dye in the tank. It seems like there are some parts that glow under UV Dye in most BMWs. What was different on mine was the auxiliary water pump return hose that connects around the oil cooler.
Sent it back to the Dealer, and they pressure tested but did not want to change any parts because they cannot see any pipes leaking when under pressure.
Is it possible that there is a valve or something that would prevent the flow of coolant to that hose if the car is off? Eg. If pressure testing cold with the ignition off the AC wouldn't be on and hence no flow to the leaking hose because of a valve that's closed?
https://ibb.co/rtZJjFj
