01-11-2015, 11:04 AM | #112 |
Rep 119
01-11-2015, 01:19 PM | #114 |
Rep 420
usual_suspect239.00 |
01-11-2015, 01:35 PM | #115 |
Rep 7,063
Whys that?
01-11-2015, 02:04 PM | #116 |
Rep 3,990
Some like to lower while some don't. It's all a matter of personal preference. As long as you don't lower on 19"-20" wheels, you're ok. The X5 is just too big otherwise and looks bagged. This is an example of something that just doesn't look right on 20s, unless the new Q7 station wagon is what you're into :
jc-18.00 |
01-11-2015, 02:10 PM | #117 |
Rep 4,112
He needs some spacers and it will look better. I have 21's so it might be better. What's stopping me is I still like taking it off-roading in the mountains and this will not help the ground clearance. I already have the kit sitting in the box though.
01-11-2015, 02:15 PM | #118 |
Rep 3,990
Agreed, but he still went too low for his 20s. It has a ricer look in my honest opinion. The height Ben (r33) lowered his looks perfect on his 22s. I think if you just do that amount you'll be good. However, I agree since you do tend to go off-roading (from your recent picture), it will definitely hinder you. What suspension option do you have in your car? Stock, M adaptive, or DHP?
01-11-2015, 02:19 PM | #119 | |
Rep 7,063
01-11-2015, 02:38 PM | #120 | |
Rep 3,990
01-11-2015, 02:41 PM | #121 | ||
Rep 7,063
01-11-2015, 02:51 PM | #122 | |
Rep 4,112
01-11-2015, 03:09 PM | #123 | |
Rep 3,990
01-11-2015, 05:05 PM | #124 |
Rep 265
01-11-2015, 05:08 PM | #125 | |
Rep 265
jc-18.00 |
01-11-2015, 05:10 PM | #126 | |
Rep 420
01-11-2015, 05:11 PM | #127 |
Rep 3,990
They're stock OEM 20s.
01-11-2015, 05:19 PM | #128 |
Rep 420
ok back to topic, pic of the day
4
jc-18.00 |
01-11-2015, 05:25 PM | #129 |
Rep 420
4
jc-18.00 |
01-11-2015, 08:39 PM | #132 | |
Rep 18,734
My F10 528 lease are up, so was at the dealership bargaining. Ended up with F10 ActiveHybrid 5. Originally wanted an i3, but my wife brought up a good mention regarding the rear door, where she won't be able to open it and take my kids out if the parking spot is too tight. Anyway, my F15 uses H&R spring with my own rear spring combo that I've research. But it is still H&R spring. My X5 have all around springs, not rear self-leveling. greentrbo95gst , since your car has rear self-leveling, you just need to use an adjustable link to trick out the ECU on the ride height. I do have a quiet aggressive setup on the HRE. When I was on the 20", it does screaming for a spacer. paicapo , I know lowering an SUV is not right, but that is why I get an sDrive. Because I know that I am not going to bring the X5 to an off road. Also, I hate the feeling of a high center gravity during a turn, since I don't take my turn lightly. As far as my drop, I believe it was 1.5" front and 1.25" rear. The X5 do have taller gap in the rear by default to compensate when you towing. Taran.J , as far as my experience, Eibach is a good spring, just a little stiffer compare to the H&R. Also it doesn't drop as much as H&R.
