12-18-2021, 02:25 PM | #45 |
Rep 41,154
12-21-2021, 01:33 PM | #46 |
Rep 9
I replaced all the values SWFL and IBAD 007.007.008 to 007.037.001 that I found in TAL then I start the flash.
At the end of procedure the e-sys says: ... [HU_NBT2 - 63 - ibad_00002714-007_007_008] Transaction type: ibaDeploy; Message: 100% progress on ECUId:HU_NBT2_0x63 [100% of ibad_00002714-007_007_008] [TRANSACTION] [HU_NBT2 - 63 - ibad_00002714-007_007_008] Transaction type: ibaDeploy; Message: 100% progress on ECUId:HU_NBT2_0x63 [100% of ibad_00002714-007_007_008] [TRANSACTION] [HU_NBT2 - 63 - ibad_00002714-007_007_008] Transaction type: ibaDeploy; Message: 100% progress on ECUId:HU_NBT2_0x63 [100% of ibad_00002714-007_007_008] [TRANSACTION] [HU_NBT2 - 63 - ibad_00002714-007_007_008] Transaction type: ibaDeploy; Message: TA finished [TRANSACTION] [HU_NBT2 - 63] finalizeECUFlash started [PROGRESS] [HU_NBT2 - 63] finalizeECUFlash finished [PROGRESS] [] finalizeVehicleFlash started [PROGRESS] [] finalizeVehicleFlash finished [PROGRESS] [] prepareVehicleForCoding started [PROGRESS] [] prepareVehicleForCoding finished [PROGRESS] [HU_NBT2 - 63] prepareECUforCoding started [PROGRESS] [HU_NBT2 - 63] prepareECUforCoding error [PROGRESS] [] SVK-Ist does not match expected SGBMIDs for ecu ECUId:HU_NBT2_0x63. Excpected (relevant process classes only): [swfl_00002719-007_037_001, swfl_00002721-007_037_001, ibad_0000270c-007_037_001, hwel_00003a0b-001_003_001, ibad_0000270a-007_037_001, swfl_0000271c-007_037_001, swfl_00002717-007_037_001, swfl_0000271e-007_037_001, ibad_00002711-007_037_001, swfl_00002727-007_037_001, ibad_00002713-007_037_001, swfl_00002718-007_037_001, swfl_00002722-007_037_001, swfl_00002716-007_037_001, ibad_0000270b-007_037_001, swfl_00002720-007_037_001, btld_00001ffd-007_037_001, ibad_00002709-007_037_001, ibad_00002714-007_037_001, swfl_0000271a-007_037_001, swfl_0000271f-007_037_001, ibad_00002712-007_007_008], Actual (relevant process classes only): [btld_00001ffd-007_037_001, swfl_00002718-007_037_001, swfl_00002719-007_037_001, swfl_00002720-007_037_001, swfl_0000271c-007_037_001, swfl_00002727-007_037_001, swfl_00002721-007_037_001, swfl_00002722-007_037_001, swfl_0000271f-007_037_001, swfl_0000271a-007_037_001, swfl_0000271e-007_037_001, ibad_0000270c-007_007_008, ibad_00002714-007_007_008, ibad_00002712-007_007_008, ibad_0000270b-007_007_008, swfl_00002716-007_037_001, swfl_00002717-007_037_001, ibad_0000270a-007_007_008, ibad_00002709-007_007_008, ibad_00002713-007_007_008, ibad_00002711-007_007_008, hwel_00003a0b-001_003_001], Missing SGBMID(s): [ibad_0000270c-007_037_001, ibad_0000270a-007_037_001, ibad_00002711-007_037_001, ibad_00002713-007_037_001, ibad_0000270b-007_037_001, ibad_00002709-007_037_001, ibad_00002714-007_037_001], Surplus SGBMID(s): [ibad_0000270c-007_007_008, ibad_00002714-007_007_008, ibad_0000270b-007_007_008, ibad_0000270a-007_007_008, ibad_00002709-007_007_008, ibad_00002713-007_007_008, ibad_00002711-007_007_008] [THROWABLE] [HU_NBT2 - 63] There was an error during TAL execution, please check the log files. [WARN] [HU_NBT2 - 63] - [Exception - HU_NBT2 - 63] SVK-Ist does not match expected SGBMIDs for ecu ECUId:HU_NBT2_0x63. Excpected (relevant process classes only): [swfl_00002719-007_037_001, swfl_00002721-007_037_001, ibad_0000270c-007_037_001, hwel_00003a0b-001_003_001, ibad_0000270a-007_037_001, swfl_0000271c-007_037_001, swfl_00002717-007_037_001, swfl_0000271e-007_037_001, ibad_00002711-007_037_001, swfl_00002727-007_037_001, ibad_00002713-007_037_001, swfl_00002718-007_037_001, swfl_00002722-007_037_001, swfl_00002716-007_037_001, ibad_0000270b-007_037_001, swfl_00002720-007_037_001, btld_00001ffd-007_037_001, ibad_00002709-007_037_001, ibad_00002714-007_037_001, swfl_0000271a-007_037_001, swfl_0000271f-007_037_001, ibad_00002712-007_007_008], Actual (relevant process classes only): [btld_00001ffd-007_037_001, swfl_00002718-007_037_001, swfl_00002719-007_037_001, swfl_00002720-007_037_001, swfl_0000271c-007_037_001, swfl_00002727-007_037_001, swfl_00002721-007_037_001, swfl_00002722-007_037_001, swfl_0000271f-007_037_001, swfl_0000271a-007_037_001, swfl_0000271e-007_037_001, ibad_0000270c-007_007_008, ibad_00002714-007_007_008, ibad_00002712-007_007_008, ibad_0000270b-007_007_008, swfl_00002716-007_037_001, swfl_00002717-007_037_001, ibad_0000270a-007_007_008, ibad_00002709-007_007_008, ibad_00002713-007_007_008, ibad_00002711-007_007_008, hwel_00003a0b-001_003_001], Missing SGBMID(s): [ibad_0000270c-007_037_001, ibad_0000270a-007_037_001, ibad_00002711-007_037_001, ibad_00002713-007_037_001, ibad_0000270b-007_037_001, ibad_00002709-007_037_001, ibad_00002714-007_037_001], Surplus SGBMID(s): [ibad_0000270c-007_007_008, ibad_00002714-007_007_008, ibad_0000270b-007_007_008, ibad_0000270a-007_007_008, ibad_00002709-007_007_008, ibad_00002713-007_007_008, ibad_00002711-007_007_008] [HU_NBT2 - 63] finalizeECUCoding started [PROGRESS] [HU_NBT2 - 63] finalizeECUCoding finished [PROGRESS] [] finalizeVehicleCoding started [PROGRESS] [] finalizeVehicleCoding finished [PROGRESS] [] finalizeTALExecution started [PROGRESS] [] finalizeTALExecution finished [PROGRESS] TAL execution finished [TAL_EXECUTION_FINISHED] TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "42min 33s". [C206] Read SVT after TAL execution started. Read SVT after TAL execution finished. After rebooting the Drive, the system had the NBTevo_Y21272I version and the carplay full screen was enabled . Now my question is: Those errors that were generated, what problems could they generate? What values should I change in TAL so that these errors are not generated again in a future update? Thanks in advance |
12-21-2021, 01:40 PM | #47 |
Rep 41,154
12-21-2021, 02:06 PM | #48 |
Rep 9
Shawnsheridan, thank you very much for your prompt responses.
Trying the ID6 graphics version, I discovered that the ID6 version for MINI is the all new 2021 interface. Now, if I want to upgrade the map, how I do to patch the Head Unit or load a custom FSC Code to make the map upgrade?. JC |
12-21-2021, 04:33 PM | #49 | |
Rep 41,154
12-22-2021, 12:03 AM | #50 | |
Rep 46
Drives: 2020 G20 330i
Thank you for the very informative post I come for the G20 series, I was working on Esys for that and Shawn was a big help But I've since purchased an F25 X3, and now want to make some changes to it... so let's see if you can help answer these simple questions for me. The car is a 2017, and from my looking has NBT EVO - ID5, software version Y. I am a little confused but hope we can clear it up, to upgrade to ID6 and enable full screen carplay, do I need to code anything requiring plugging into a battery charger and all that jazz, or is it just a simple change of ; ID5 to ID6 Skin HMI_ID_VERSION change this to id6_light Apps : HMI / HMI_39_39_128 => aktiv or HMI / CARPLAY_FULLSCREEN => aktiv as you stated, I believe I have the final if not 2nd final version of ID5 installed , from what I can read I also was not entirely sure if I needed the WIFI antenna, and ordered one which should be here in a week or two, so I will add that to my HU I Do have esys as I stated and enet cable, I am quite familiar with using it all for my G20, but I have never had to have the car plugged in while coding before, I could do it all with the engine running Thanks!!! |
12-22-2021, 07:43 PM | #51 | |
Rep 1,353
If you already have version Y, you can simply code the system for id6 and also full screen car play without charger. Just hook up the ENET and Laptop. I do also have G20 with id7 as well which is MGU.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 01-31-2022 at 08:21 PM.. |
12-23-2021, 11:12 AM | #52 | |
Rep 46
So if what you're saying is true, adding the antenna and then coding the 2 options to activate carplay and full screen, should be all i have todo? |
12-23-2021, 02:39 PM | #53 |
Rep 41,154
No. If car does not already have CarPlay, it cant just be coded. You need an FSC Code. PM sent.
SaNGRia996.50 |
12-27-2021, 05:41 AM | #54 |
Rep 14
5- Go to C:/EDIABAS/Hardware/ENET Double Click ZGW_SEARCH
Curious about the above step when flashing. If I am using an ENET cable do I have to use Ediabas software? And is the ZGW_Search required for connection or is it just verification? Thanks |
12-27-2021, 09:46 AM | #55 |
Rep 41,154
Not needed.
SaNGRia996.50 |
01-01-2022, 06:39 AM | #56 |
Rep 14
Hey guys. So last night I went ahead with the flash. I thought everything went well: There were no errors, flash took about 36 mins, I updated dependencies accordingly, etc.. I must have done something wrong because when my HU rebooted it was still the same istep as the shipment. Some of the previous codes I had were still there however apple car play was gone. But the biggest problem is that now is that my navigation wont load, my sirius xm is gone, and when I did a quick read on my bluetooth obd it said all my hu activation codes were bad (in red font) and it is still the same version as it was previously.
I have a 2018 330ix with NBTevo-L. the istep ship is F020-17-07-504, I followed the instructions, I thought without fault, but apparently I missed something. One part that I couldn't seem to find the answer for was which targetSelector to choose in the very beginning. I did not use direct, however I used the one that was F020_21_11_535 and not the same as the ishipment. I was unsure. I am at a loss and could really use some advice. Thank you in advance I can provide the log file if that helps. |
01-01-2022, 08:45 AM | #57 | |
Rep 41,154
Question is if car is NBTevo-L before and after flash? It should not be if flash ran 36 minutes. As for nothing working, I presume this is because you use aftermarket CarPlay solution, and flashing removed EVO Patch, and now all the fake FSC Codes in EVO are Status = Rejected.
01-01-2022, 10:23 AM | #58 |
Rep 14
I understand. Thank you Shawn.
As for the FSCs, I assume there is likely no way to get the originals back since the company did not give me any backup. Am I able to find those somehow? Or is my only option just to reload the patch..? As you already know, Bimmercode wont allow HU coding without factory install. Is there any way around this or am i out of luck? Thanks again. |
01-01-2022, 10:29 AM | #59 | |
Rep 41,154
01-01-2022, 10:47 AM | #60 |
Rep 14
And once I make connection which target selector should I choose. I would assume the newest correct? So the selection nearest the bottom, and not DIRECT of course.
Choices are F020_21_03_545_v004_000 Or F020_21_11_535_v004_000 |
01-04-2022, 09:00 AM | #62 |
Rep 41,154
Not quite. You need to manually create Flash TAL.
03-05-2022, 07:20 PM | #63 |
Rep 146
Huge thanks to shawnsheridan and SaNGRia for this thread, as well as netinvader for his thread at https://f80.bimmerpost.com/forums/sh....php?t=1585726
I successfully flashed my F30 with NBTEvo_J to NBTEvo_Y tonight and then retrofitted CarPlay via an eBay seller's ENET activation method for ~$35. I'm not sure if it's because I'm using an ancient ENET cable or the $8 USB ethernet adapter, but somehow this flash took 3 hours. On the topic of power supplies, for future reference, I used a $55 STANLEY BC25BS with 25amp of constant output and I only saw it go to ~15 amps during the flash, and it held at 13.9-14.0V the entire time. For anyone that wants to play it safe but do not want to spend hundreds, you can buy a 66.7amp (800W) power supply that can be adjusted up to 14.6V on Amazon for $80. If you want to really play it safe, I found 100 amp power supplies from PowerMax on Amazon and eBay for $180, and you can adjust the voltage on those as well. Just search "PowerMax 100". I actually found a PowerMax PM3-100 at an RV supply store locally that price matched. |
03-05-2022, 07:52 PM | #64 | |
Rep 1,353
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
03-16-2022, 04:47 PM | #65 | |
Rep 85
I would like to try to update my idrive 7 (g20) with M3 vehicle for obtain M widget. I know that i need the FA of M cars by 2020 (i have). Can you help me to understard in which way i can flash HU_MGU with M correct software? i hope that you can help me Thanks please |
03-18-2022, 09:11 PM | #66 | |
Rep 1,353
But if the TAL calculation completes without an error it might be done succesfully.
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 03-18-2022 at 10:16 PM.. |
