04-20-2021, 10:35 PM | #23 |
Rep 239
Ok, I was stupid today. I did the oil change myself for the first time. There was two rubber o rings from the oil filter. So I put the larger one on the oil filter cap, and the smaller one on the oil drain plug(on top of the metal ring).
Now, I was told that the oil drain plug isn't supposed to have the rubber ring..... So now, what issues it may caused? No leak or anything, but I hate to go under the car and do the oil change again.... |
04-20-2021, 10:57 PM | #24 | |
Rep 97
2018 X5 35i
04-20-2021, 11:26 PM | #25 | |
121
Rep 359
04-22-2021, 02:00 AM | #26 | |
Rep 7,485
If the small rubber o-ring you installed on the drain plug fails...you will start leaking oil since you have it above the crush washer. I would recommend draining the oil (into a CLEAN drip pan) so that you can removed the small rubber o-ring and leave the crush washer installed on the drain plug. Then reuse the oil that drained into your drip pan. Good luck.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-22-2021 at 02:12 AM.. |
04-22-2021, 05:36 PM | #27 | |
Rep 7,160
What I would do is go buy 1-2 more quarts and then take the plug out and replace it with a new one from the dealer. If you do it quick enough you will only lose a little bit. Then measure and add new oil. Or take the new plug to a jiffy lube and ask them to do it for you and again, measure what you loss and add new clean oil.
04-22-2021, 09:01 PM | #28 | ||
Rep 1,179
04-22-2021, 09:15 PM | #29 |
147
Rep 334
Loosen the plug but only enough to expose the o-ring. I'd use a fine edge pair of side cutters or electrical cutters, snip the o-ring then just screw the plug back in. Once the plug is loose, keep upward pressure as you cut it and that should help block/slow the oil flow.
That's what I'd do to save the oil anyways. Top up as needed. |
Maverik2594140.00 |
04-23-2021, 02:08 AM | #30 | |
Rep 1,179
11-07-2023, 08:01 PM | #31 |
Rep 1
Hi Everyone,
I attempted my first DIY oil change after owning the car for ten years, following the engine replacement due to the lawsuit. However, when I checked the oil filter cover, it does not seem to be the standard. Does anyone know which type of cover this is, and what size oil filter wrench I need? Thanks! |
11-08-2023, 02:12 PM | #32 | |
Rep 7,485
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-08-2023 at 02:42 PM.. |
