      12-22-2017, 06:17 PM   #1
turboawd
1636
Drives: 2015 X5 35i
is swapping seats plug and play?
i have the standard seats and was tossing the idea around of getting comfort seats. would they plug in direct? require coding?
      12-22-2017, 07:34 PM   #2
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Features like lumbar support, side bolsters and other extra power adjustments only require power, no coding, so depending on the socket pins configuration may need to provide extra pins for power/ground (relatively easy)
However, things like ventilation will need coding and extra physical buttons/control module on dash panel
Physical seat removal isn't hard - just 4 torx bolts for seat base and couple seatbelt bolts
It's worth it imho as comfort seats are indeed more comfy especially for longer trips
Finding matching color seats in good condition and not for sky high price can be a pain
      12-24-2017, 01:31 AM   #3
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
I'd love to swap out my ventilated comfort seats for simply heated and see how much more comfortable they are
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      12-24-2017, 03:39 AM   #4
turboawd
1636
Drives: 2015 X5 35i
i seen a place selling non-vented comfort seats for 2,000. seems a bit high, but i should be able to sell mine to offset the cost some. hmm...
      12-24-2017, 08:19 AM   #5
boosted43
boosted43's Avatar
Drives: 2017 C43 AMG
2015 BMW 335i  [0.00]
I haven't been able to find anything, I was considering replacing my crappy "sports" seats with the multi contour ones if only I could manage to come across one in the same color. Would you mind sharing where you found yours?
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
      12-08-2018, 09:19 PM   #6
Zamorskii
Zamorskii's Avatar
186
Drives: '23 M3CX
Has anyone actually done this swap? I'm thinking of possibly passing my X5 to the wife and she wants more support as she's driving with sport seats in her 3-series now.
      12-09-2018, 11:15 AM   #7
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Hardest part is to find matching color, but the swap is possible.
Easiest would be to find just drivers seat of same color and without ventilation - in that case swap it yourself as there will be no coding required, just 4 torx bolts for seat. Literally just unbolt 4 torx bolts and unplug 1 socket under the seat. The seat runs about $900 (used in good condition), so it's not cheap.
      01-08-2019, 06:19 AM   #8
fred9035
France
4
Drives: X5 F15 4.0d 2016
What about seat belt and airbag? In most of the offers for seats found on famous auction sites, seats come without airbag. is it easy to transfer the existing airbags to the new seats?
      01-22-2019, 01:08 PM   #9
larsbs79
Norway
Drives: F15, 25dXdrive M-sport
Hi,are You sure this i possible?There are different wiring and seat modules in sport seats and comfort seats.
      01-22-2019, 05:53 PM   #10
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
The modules are on the seat and it's just one cable that plugs in to power it I think is what he's saying.
'06 C55 AMG (sold)
DuSh2113.50
      01-22-2019, 07:37 PM   #11
TheUltimateDrivingManiac
Freude am Fahren.
Drives: F15 X5 xDrive35i
Everything is possible.
Freude am Fahren.
      01-22-2019, 07:43 PM   #12
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
also disconnect the battery ground before unplugging any seat plugs. else you might get airbag (SRS) light on the dash
      02-14-2019, 03:12 PM   #13
larsbs79
Norway
If you dont have memory seat on passenger side there is some cabling involved,you need the canbus for example....
      02-18-2019, 09:44 PM   #14
srikeshgs
Drives: BMW X5 30D XDRIVE
i have fitted msports seats to my x5, passenger seats work without the heating. driver seat does not even move. any suggestions are welcome. not bothered about heating just need the motors to be working. driver seat is memory seat
      02-18-2019, 10:22 PM   #15
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
You need pinout for m-sport and non m-sport - they differ slightly. You are probably missing extra power pin for m-sport socket. If you can find color coded numbered pinout (table or picture) - you should be able to rewire. Everything should work, including heating.
Best way to do it is to get pinout from ISTA - there are ALL pinouts with photos and diagrams, everything is numbered and explained etc. Check the Maverik259 thread about ISTA and how to install it: https://f15.bimmerpost.com/forums/sh....php?t=1568962 I don't have ISTA, otherwise I would have posted m sport seat module wiring diagram. So you'll have to do some leg work. Or you can bring it to some reputable local auto electrician and he'll be able to wire it for you.
HJ478.00
      04-05-2019, 03:22 PM   #16
Tugster1
Drives: BMW X5 f15
Hey man did you manage to get your seat working. I have exactly the same issue. Any assistance you can provide would be greatly appreciated.
      04-05-2019, 08:31 PM   #17
parkstr8
parkstr8's Avatar
Drives: 2020 BMW X5 MSport Arctic Grey
I'd like just the upgraded driver seat - same leather color and plug and play. Other than Ebay not sure where to find them....
      04-07-2019, 03:27 PM   #18
LilaIulian
Drives: f15,e71,f30
Hello, i have the standard seats too, i wanna know how expensive is the extra cable management i find f85 sport seats and i wann buy them, but first i want to know if its possible plug them.
      06-30-2020, 03:11 PM   #19
fred9035
France
4
I have the standard leather dakota black seats and bought on famous auction site a pair of comfort seat in fantastic condition.
When i tried to remover the 4 bolts of the standard driver seat, it was quite difficult but succeeded for 3 of them. Remaining 4th was so hard that i damaged the bolt shape and the torx key does not fit in anymore. tried different way to extract the bolt without success.
Any idea how to remove it$? sounds like being glued with loctite¨!
      06-30-2020, 03:35 PM   #20
turboawd
1636
Drives: 2015 X5 35i
Try vise grips.
And how the heck did you mangle it so bad? Lol
      06-30-2020, 03:43 PM   #21
fred9035
France
4
I try to make a mark i order to hammer the screw with a flat screwdriver and hammer. did not move at all ..
vise grips may not give me enough torque..
      06-30-2020, 04:14 PM   #22
turboawd
1636
Drives: 2015 X5 35i
Got access to a welder? Weld a nut on it.
