11-08-2023, 11:06 PM | #1 |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
F15 50i throttle hesitation from a stop
Hey friends. 2016 50i all stock. 72k miles. Recently had coils and plugs replaced and injectors cleaned. After that, the car developed a frustrating trait that I'm trying to figure the cause.
From a dead stop when I press lightly on the accel pedal, the car will not respond immediately - but rather hesitate and then jerk forward before accelerating normally. Any ideas? Thx.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
11-09-2023, 09:42 AM | #2 |
Rep 2,669
Drives: e92 + f15
Any codes? Reset throttle adaptations after the maintenance?
11-09-2023, 11:20 AM | #3 |
Rep 6,771
Drives: 2016 BMW i8
Just asked the shop and no, they didnt reset adaptations. Thx for the response that's an easy thing to try first. Cheers.
zero2sixtyZ951.00 |
11-09-2023, 01:14 PM | #5 |
Rep 6,771
Drives: 2016 BMW i8
It is worse after a cold start and worse also if in comfort mode. Sport mode the issue isnt as acute. The pedal isnt sticking.
50iXman34.00 |
11-09-2023, 02:14 PM | #6 | |
Rep 106
I do notice after a cold start the idling will "hunt around" a bit after start before she smoothes out. Does yours do this? |
11-09-2023, 04:37 PM | #7 |
Rep 5,002
Did it happen directly after the work you had done? Not a week or a month after I mean directly after…
If so, take it back and explain the issue. If not, I’d looked at changing the fluid in the transfer case and resetting the adaptions for it. You can also trouble shoot the transfer case by unplugging. If you unplug it and the issue goes away then that’s your issue. Most common causes of the issue you’re describing. |
Fknid38.50 |
11-09-2023, 04:48 PM | #8 |
Rep 6,771
Drives: 2016 BMW i8
Sorry no my idle does not hunt around. Does a quick cold start idle above 1,000 rpm for a few seconds and settles down and stays constant. Good luck identifying your issue.
50iXman34.00 |
11-09-2023, 04:52 PM | #9 | |
Rep 6,771
Drives: 2016 BMW i8
11-09-2023, 05:13 PM | #10 |
Rep 111
Could be Neutral Idle Control which is on in Comfort mode. When stopped the tx is decoupled from the engine via a clutch.
If it is that then: BMW is able to turn this off if you ask specifically for it (there is a SIB on this), or you can use xHP flashtool (standstill decoupling) as a paid aftermarket flash. |
Longboarder3430.50 |
11-12-2023, 10:17 AM | #11 | |
Rep 5,002
11-12-2023, 07:30 PM | #12 |
Rep 458
Was my issue |
Longboarder3430.50 Monkeypoop39.00 |
