03-24-2018, 08:56 PM | #4071 |
Rep 41,034
PM sent.
03-25-2018, 09:21 AM | #4072 |
Rep 428
Drives: 2015 X5 35d
03-25-2018, 01:21 PM | #4073 |
Rep 428
Drives: 2015 X5 35d
So to add enhanced Bluetooth it would look like this?
6AR, 6NS, 6WB, Thanks! |
03-25-2018, 07:27 PM | #4075 |
Rep 41,034
Yes.
03-26-2018, 09:56 AM | #4076 |
Rep 428
Drives: 2015 X5 35d
03-26-2018, 10:45 AM | #4077 |
Rep 41,034
03-26-2018, 11:19 AM | #4078 |
Rep 428
Drives: 2015 X5 35d
I did get worried when I wrote it to the car it was almost instantaneous. I didn't think it had worked but it really was like magic.
Thanks for the help guys! |
03-27-2018, 08:24 PM | #4079 |
Rep 47
coding software
Hi Shawn,
Can you send me the latest esys and launcher? had to replace a headlight on the f15 and need to recode it. Cheers and Thanks! |
03-27-2018, 09:11 PM | #4080 |
Rep 41,034
PM sent.
03-27-2018, 11:32 PM | #4081 |
Rep 96
Hi folks- great thread. I really appreciate all the contributors/contributions.
Quick question...I'm going to be VO coding my 2018 F15 for heated steering wheel retrofit when it arrives in April or early May. Which ECUs do I need to code once I've added the 248 to the VO? Thanks in advance! P.S. I'll be swapping the wheel and switch too. I know coding alone won't get me a warm steering wheel.
2018 X5 xDrive35i M-Sport - Traded
2013 X1 xDrive35i - Sold 1986 320i - Sold |
03-28-2018, 01:43 PM | #4082 |
Rep 231
Quick question - I got the Esys cable, and followed the instructions provided. With the VM provided in the instructions. Seeing everyone ask/receive for the latest software, is that something I should/could do as well? Or should I just leave it as is for some reason. Thanks in advance.
03-28-2018, 10:07 PM | #4083 | |
Rep 8,364
03-29-2018, 10:32 AM | #4084 |
Rep 2,590
I've been able to do FDL coding with no problem. Trying to update my FA/VO today to add SBRE for msport brakes but when I calculate FP, I only get blank folders on the right with number references only. When I look in DATA\FP folder, I don't see anything within there.
I've downloaded E-sys correctly and PSzdata lite and as state can do FDL coding, any reason why I can't see FPs? thanks, |
03-29-2018, 10:44 AM | #4085 | |
Rep 41,034
pits200547.50 |
03-29-2018, 11:21 AM | #4086 | |
Rep 2,590
Thanks again |
03-29-2018, 11:23 AM | #4087 |
Rep 41,034
Yes, Right-Click => New => SBRE, then both HO-Wort will be present.
pits200547.50 |
03-29-2018, 01:15 PM | #4088 | |
Rep 2,590
I wrote the new FA, went back to coding, FA showed new SBRE, I read ECU, and it showed DSC2 when people were stating it should show DSC. I activated FA and coded DSC2. Drove the car around and to me the brakes feel the same. I'm not sure if DSC2 already existed prior to adding SBRE. Anymore input is appreciated. Edit: Update I guess DSC2 is correct, I now see that my front rotor size is FN AL 42 /36/395 Rear was set to FN AL 42 /24/385, since I didn't change the rear, I changed those back to FN AL 44/24/345 Last edited by pits200; 03-29-2018 at 01:40 PM.. |
03-29-2018, 07:21 PM | #4089 |
Rep 15
Retrofit TPMS to X5 5/2014
My retrofitted TPMS' are not working. Retrofitted TPMS to my 5/2014 X5 35xi Euro. Sensors are 6855539. Added option 2VB to FA and VO coded HU_NBT and KOMBI. Could not find any relevant RDC/RPA coding in BDC nor DSC. iDrive screen looks like on photo. All TPMS' seem to be connected, but no readings. Anyone has an idea how this could work, what did I do wrong?
03-29-2018, 11:22 PM | #4090 | |
Rep 96
Thanks again.
03-30-2018, 01:16 AM | #4091 | |
Rep 8,364
You can use TM NCD / CAFD tool to give you an idea of which ECU's to code. |
03-30-2018, 05:05 AM | #4092 | |
Rep 96
I.E., Click "External Applications" in the left menu. Click "External Application" Double-click "Transmitter" Scroll to the bottom and double-click "... Clear all DTCs ..." Correct? Thanks again. P.S. I know the newbie questions get tiresome but thanks for your patience.
